Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. Bandit Billy
    Bandit Billy
    I have used tire black to paint white letters. It comes in a spray can and adheres well. Just a light coat, too much will crack making you think the side wall is cracking.
    Splitbudaba likes this.
  2. I've used SEM trim black to cover white letters. The rear tires on my Roadster had white letters on the inside, I sprayed the trim black on them and it never cracked or came off. I drove on those tires for way more years than I should have. I think I've used SEM black upholstery spray too in the past.
    Splitbudaba and loudbang like this.
  3. Splitbudaba
    Splitbudaba
    Getting ready to groove the slicks. But I made a find in the voltage regulator issue. Seems the D618 has been the issue, it is the newer version, however it is made for higher amp generators. Precisely 26 to 35 amps.Well mine is a 25 amp generator. So did some digging, found I need a D617. No longer made!! eBay to the rescue. Found a never opened D617 regulator in the box. Got brave and bought it. Nice part it is easily adjusted. Like that idea. I get it next week, fingers crossed!
    brEad, loudbang and Weedburner 40 like this.
  4. Splitbudaba
    Splitbudaba
    Got my voltage regulator today. Two days late, USPS delayed. Kinda fun opening a piece of the past. Pulled the string and popped the top. The smell was familiar, everything inside is mint. Next bolt it on and hope for the best!! PXL_20250312_154923381.jpg PXL_20250312_154916309.jpg PXL_20250312_154919585.jpg
    shortypu, brEad, swade41 and 6 others like this.
  5. DDDenny
    Like peeling the red wax seal off a bottle of Makers Mark!
    Splitbudaba and Bandit Billy like this.
  6. Bandit Billy
    Bandit Billy
    Well let's not all crazy up in here!
  7. Splitbudaba
    Splitbudaba
    That did the trick!! Love the adjustability, second time set it right in, plus I am going to add another ground to the regulator case for extra measure! No hot spots, sparks, etc. Gen and regulator stay cool!! Next thing is groove the slicks!
    brEad, swade41, loudbang and 2 others like this.
  8. Splitbudaba
    Splitbudaba
    Finally getting back on the coupe. Had more generator issues. Had to replace the field coils, all is well now. Here's my idea for grooving the slicks. Big long hose clamp, tighten down where you want it, use it for a guide for the grooving tool. Will try it tomorrow, wonder how bad it will smell? PXL_20250417_225608492.jpg
    shortypu, brEad, swade41 and 4 others like this.
  9. Tim
    Tim
    from KCMO
    That’s clever, I’m curious if it would be easier to keep uniform depth if you hold steady and have a helper turn the wheel?
    Kelly Burns and Splitbudaba like this.
  10. Splitbudaba
    Splitbudaba
    That's what my wife is doing!!! See more tomorrow!!
    Tim and brEad like this.
  11. big duece
    big duece
    from kansas
    That's outa my pay scale, but watching from the sidelines!
  12. Weedburner 40
    Weedburner 40
    It doesn't smell too bad. I have done several sets for sand rails when I was younger. Just do it in a well ventilated area.
  13. Splitbudaba
    Splitbudaba
    Two fans and a Idaho breeze! Thanks for the info! I'm sure my wife won't like it!!!!
  14. Bandit Billy
    Bandit Billy
    A few of those clamps would come in handy in that Idaho snow. :cool:
  15. Splitbudaba
    Splitbudaba
    I doubt seriously my coupe will ever see snow while I own her! That would be fun but messy!
    brEad and loudbang like this.
  16. Splitbudaba
    Splitbudaba
    Tried a small section. Went like ****er, speed is the main thing. Now it's time for the long cuts. My wife agreed to turn the tire. Smell wasn't bad, fan helps. PXL_20250420_164304443.jpg PXL_20250420_164400585.MP.jpg
    shortypu, Tim, brEad and 4 others like this.
  17. Bandit Billy
    Bandit Billy
    That looks great! My TC tires have a little hole in the tire, dead center, at 12:00 and 6:00 on each tire. Obviously, a mould mark or something. It is the only thing I don't care for. I tried filling them with black RTV but it doesn't stay in under driving conditions. Do your tires have such a thing?
  18. Splitbudaba
    Splitbudaba
    I have holes around both tires. They are a certain depth. When the holes disappear from loss of tread, it's time for a new set tires soon. That's the depth I made the grooves. PXL_20250420_174924389.MP.jpg PXL_20250420_174915355.jpg
  19. earlymopar
    earlymopar
    Those blind holes are usually wear indicators.
    Bandit Billy likes this.
  20. Bandit Billy
    Bandit Billy
    I never thought about them being wear indicators. Thanks guys.
    Tim and Tim_with_a_T like this.
  21. chicken
    chicken
    from Kansas
    Yep, referred to as "check holes" by drag racers. Shallow check holes mean your wallet is about to get thin.
  22. JD Miller
    JD Miller
  23. Splitbudaba
    Splitbudaba
    Went around turning the tire myself. Didn't like the way the groove came out. So next try will be the 1/2" blade between two clamps and my wife turning the tire. I learned the angle which you hold the cutter must stay consistent or the depth varies. PXL_20250420_201822066.jpg PXL_20250420_201814249.jpg
    shortypu, brEad, Kelly Burns and 2 others like this.
  24. Tim_with_a_T
    Tim_with_a_T
    Looking good!!!
  25. Splitbudaba
    Splitbudaba
    Update, didn't do so good on grooving the Radirs. My wife stepped in.
    No illegal drag only slicks. OK, ordered two 1000x15, 29.5" Towel City Cheater Slicks, 4 grooves with angled cuts. I should get them by June. Guys at Towel City we're great! DIT number and all. New casings made by Goodyear! That will be the last piece, and I am on the road. Can't wait!! Oh yeah, black walls only!!!
  26. Bandit Billy
    Bandit Billy
    TC is very good at what they do and what they sell. You will not be disappointed.
  27. Splitbudaba
    Splitbudaba
    I could tell just by talking to them. Honest straight forward answers. Plus they won't run my credit card until they are ready to ship. Besides I love the way yours look!!
  28. Bandit Billy
    Bandit Billy
    Good folks, good tires. They'll groove them to your specs.
  29. Splitbudaba
    Splitbudaba
    Ordered the custom grooving, love the look. Tried to convince myself to get different tires. The cheater slick look is for me. 1000x15, 29.5 diameter, plus the custom grooving, should look pretty bad ***. That tire is the same measurements as the old Radirs.
  30. Bandit Billy
    Bandit Billy
    I have no complaints regarding mine. You should love them.
