Technical 454 BBC Casting Date?
Discussion in 'The Hokey Ass Message Board' started by '34 Ratrod, Apr 17, 2025.
  1. I understand the casting date for a 454 is in the back by the intake manifold but nothing I can find looks like a casting date . I would like to know so I can sell this engine. It's been in my shop for 20+ years and I'm just not getting to it. I just as well use the money for a current project. Any help is appreciated. Thank you in advance.
    Larry
    Edit: I have this information:
    www.nastyz28.com: (copied directly from their page)
    1401544 1975-87 454 truck
    Mortec.com: (copied directly from their page)
    14015445...454.......78-90...2 or 4 bolt
    PXL_20250416_175014924.jpg PXL_20250416_175010572.jpg PXL_20250416_175005793.jpg PXL_20250416_174947442.jpg PXL_20250417_020322292.jpg
    Sorry, I can't read all of the characters of this one..
  2. gimpyshotrods
    gimpyshotrods
  3. Fordors
    Fordors
    That is an ‘86 454/240 horse engine, it may have come from a C-20 or C-30 truck, or the AKS suffix engines were also sold to MercCruiser for marine use.
    Moriarity likes this.
  4. I'm not questioning your knowledge one bit, I really appreciate your help, I would just like to learn where you determined it's a '86?
    Larry
  5. Fordors
    Fordors
    No problem, I should have mentioned that I used the AKS engine suffix located behind the timing cover.
  6. Ok, awesome! Thank you sir
    Larry
  7. squirrel
    he found the listing for the AKS suffix
    https://nastyz28.com/gm-chevy-codes/chevy-engine-codes-suffix-12.php
    The partial VIN would help if you'd clean it up some...but it looks like CG3... C means Chevy Truck, G is the year 1986
    you might find a casting date on the side of the block, above the oil pan rail, look for a letter followed by a few numbers, such as B 22 6
    gimpyshotrods and '34 Ratrod like this.
  8. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Yup, found one of these at Pic-N-Pull out of a C 30 School District truck. One of best deals we ever got cheap.
  9. This is the only thing on the p***enger side:
    This is the only thing on the driver's side, it's above the oil filter: PXL_20250418_011757850.jpg
    Larry
  10. squirrel
    may not be a casting date on it, hmmm...
    but anyways, it's a 80s Mark IV 454 block, not much special about that. You can also pull the valve covers and see what's inside, the heads should have a casting number and casting date code also. They should be peanut port heads, open chamber with 2.07/1.72 valves, I think.
    Some time in the late 80s they started putting 4 bolt mains on these...I had one in Plan II, it went pretty darn quick with some different innards, heads, blower, etc.
  11. Tomorrow I'll pull the valve covers and drop the pan, maybe I'll have a 4 bolt..
    Larry
  12. swade41
    swade41
    from Buffalo,NY
    There'll be a date on the head when you pull the valve cover, that should help too
    '34 Ratrod likes this.
  13. Pav8427
    Pav8427
    That K24 may be a casting date.
    Nov. 4th 84.
    Kinda early for a 86 application.
    But if you think first in last out, it could have been pulled from bottom of pile for a early 86 usage.
    squirrel and '34 Ratrod like this.
  14. squirrel
    but I've never seen a casting date near that type of foundry mark.....
