Technical What's the neatest/coolest/cleverest/pretty way to route plug wires on a SBC?
Discussion in 'The Hokey Ass Message Board' started by atch, Apr 13, 2025.
  1. atch
    atch
    Yep; really nice. Maybe I need to go back to ramhorn manifolds. I gave away the ones I used to use but it's not like there aren't more out there.
    Tow Truck Tom likes this.
  2. lostone
    lostone
    from kansas
    Just be glad it isn't a bb Mopar. I've never seen a way to really run those plug wires and keep them nice and manicured looking.
    osage orange likes this.
  3. X-cpe
    X-cpe
    When mine is done it is going to be very much like pprather's. Looms on the back of the block and the 2 wire clips at the top of the block between the plugs. The front two wires will run down to a retainer on an oil pan bolt and up under the motor mount.
    I'm wondering, is there enough clearance down lower between the oil pan and the exhaust pipe to make a bracket for a loom and run the wires forward there?
    bschwoeble and Tow Truck Tom like this.
  4. patsurf
    patsurf
    how long are some of these wires that some of you are doing--must be a foot or two longer than the 'easy' way..
  5. 19Eddy30
    19Eddy30
    from VA
    Best Way , & your Not Short !:)
    $150- 200 ish
    verno30 likes this.
  6. patsurf
    patsurf
    Moriarity and deathrowdave like this.
  7. 19Eddy30
    19Eddy30
    from VA
    I'm ***uming Sarcasm ? !
    If not 100 ft roll , more then enough to do a few 440s
  8. 2OLD2FAST
    2OLD2FAST
    from illinois
    These are nice & neat , however , a leaky valve cover , a leaky exhaust gasket , a valve lash adjustment become a bit of a pain having to undo & move all that is now in the way , especially on a hot engine , BTDT .
  9. patsurf
    patsurf
    packard 440 wire--back when
  10. 19Eddy30
    19Eddy30
    from VA
    Gotcha ,
    I missed the Packer Reference,
    When in doubt always a Dodge !!
  11. Kerrynzl
    Kerrynzl
    Use 57 Chevy banana shields [they need t******* for side mounts]
  12. X-cpe
    X-cpe
    On mine I'm just using standard length early 60's ram horn wires. Last time I bought some they came with a little extra length and you crimp the coil end terminals.
  13. 57 Fargo
    57 Fargo
    @atch i can’t help since I’ve never owned a small block Chevy of any sort but I’ll admit most of mine the plug wires are visible, it doesn’t bother me.
  14. Stock Racer
    Stock Racer
    These are chrome which I like better than the billet ones. Can't remember the brand, Summit sells them.
    Tim likes this.
  15. jnaki
    jnaki
    Hello,
    The video of the curved tube is fine, if there is a lower water/moisture drain away from the plugs . Road grime, car wash, rain, and puddles, all contribute to the water incursion into the motor compartment. So, proper drainage is necessary. The bottom of the tube could have holes drilled so it allows seepage straight down before it gets to the plug wires.
    We used all sorts of separators to keep the 440 wire and Rajah End Plugs from touching the hot exhaust pipes. The ones that eventually were placed under the header system worked the best. No tube or shield necessary. In various curving points, they were clipped together. The wires were routed under the headers and came up with the 90 degree Rajah Clips. But, like all things, changing plugs after a warm up run or run(s) required long sleeve shirts and care, otherwise a nasty burn was on your fingers or hands.
    Where are those black Packard 440 Wires with Rajah End Clips? All coming from a Joe Hunt Vertex Magneto…
    The photo below from @Donut Dave is the type that works for headers and Y exhaust headers. Very neat arrangement. The underneath route is the safest and cleanest in any compartment.
    Jnaki
    But, for those that had different problems with their own plug wires, the alternative would be to modify the one in the video to fit the SBC motor.
    If one were to make a tube system for an SBC motor, it could be almost the same as the video, with the drainage holes for drainage. Or, the “L” bend with a hole or two, would be lower than the tube going to the plugs…YRMV
  16. chevyfordman
    chevyfordman
    Here is the way I'm going on a 327 with cast ram horn headers. I didn't want to go behind the manifolds as it is too close and makes the wires longer and hard to remove if you have too. IMG_2810.jpeg IMG_2809.jpeg
    Paul B likes this.
  17. rustydusty
    rustydusty
    F8FA69BA-951D-4E8A-960E-AD4D65BF9D81.jpeg AE7FECBE-FA85-4F3E-8D92-FE48F4051845.jpeg Here’s a before pic of my “T” when I acquired it, followed by an after shot when I cleaned it up a bit…
    Just Gary and lurker mick like this.
  18. Lloyd's paint & glass
    C'mon Mike, just go back to the ramhorns :cool:
    Moriarity likes this.
  19. swade41
    swade41
    from Buffalo,NY
    Not really a big deal, the wires stay together and you just move the whole thing over out of the way
  20. hotrodA
    hotrodA
    That’s perfect!
    What’s the story on the manifolds? Lots of sanding? Alumicoat?
    Thx.
  21. atch
    atch
    @Donut Dave,
    I'm liking this too and wondering how many hours it tool to get them looking like this.
    OR, are these aftermarket that came looking this good?
  22. Donut Dave
    Donut Dave
    Purchased 2-1/2” after market ram horn manifolds which are somewhat smoother than stock. Then I ground/sanded off all the casting lumps, bumps and numbers. After that I lightly bead blasted and applied Cerakote glacier gray. Time consuming but worth the effort! Donut Dave
  23. hotrodA
    hotrodA
    ^^^^^ Thanks for the response Dave. They’re great! I really like the flat shape. Looks like they’re pretty inexpensive on E-Bay.
  24. okiedokie
    okiedokie
    from Ok
    chevyfordman likes this.
  25. chevyfordman
    chevyfordman
    Yes it is okiedoie
  26. okiedokie
    okiedokie
    from Ok
    Nice work on the head pipe.
  27. verno30
    verno30
    My exper4ience has been that you need to make the wires for a truly neat appearance.
    Granted, it's a BBC in my 55 Chevy but you get the point. I ordered the parts from Ton's on eBay.
    ekimneirbo likes this.
  28. D-Russ
    D-Russ
    I used 90° terminals at the cap and spark plugs and cut my wires to exact length to keep them tidy. I made some little 1/8" tabs to position the wires where I wanted them along the block and oil pan and bolted them on using existing holes in the block. I used black plastic looms from MSD to hold the wires and screw them to the tabs I made and black zip ties keep the wires separated but neat along the back of the block.
  29. Rice n Beans Garage
    Rice n Beans Garage
    Nice work, took some thought.
    D-Russ likes this.
  30. bjinx
    bjinx
    I’ll play
    On my OT C-10 W/****** Super Comp headers. I believe they are Moroso BBC seperators. It is hard see, but I have a loose 4 wire seperator where they come off the distributor.
    Blues4U likes this.
