Hot Rods 700r4 Oil pump bushing loose
Discussion in 'The Hokey Ass Message Board' started by Motoriac, Apr 18, 2025.
  1. Motoriac
    Motoriac
    Hi guys after you helped me with the overhaul of my 235 chev two years ago (it still runs fine), I turn to you with a new problem.
    My th700r4 has been making whining noises in all gears for some time. After some internet research, I suspected the torque converter. (only one year old after overhaul) But after dis***embly I realized that the oil pump input bearing was rotating in the pump housing and demolished the torque converter shaft.
    How can I get the bearing firmly back into place?
    Please give me some repair suggestions. In Germany such oil pump housings are hard to find and expensive.
    Thanks in advance
  2. squirrel
    Replace the pump. Sorry.
  3. Motoriac
    Motoriac
    my gearbox is from 1990, can i swap with an oil pump from a 4l60e?
  4. Last edited: Apr 19, 2025
  5. Rich796
    Rich796
    The 93-94 4l60e pump body ( holds the front bushing / rotor ) last 3 casting #s 132. Will retro to your 90 pump cover.
    If the only issue, is with the front pump body bore. A local transmission shop, that rebuilds/reconditions 700r4 pumps. May possibly, be able to repair it. Or a competent local machinist.
