Technical ***April 2025 Banger Meet Thread - April Showers Bring May Bangers***
Discussion in 'Traditional Hot Rods' started by Jiminy, Apr 1, 2025.
  1. Man, you guys with the sedans are giving me motivation! Still stock height, but I threw some steelies on the old girl. I promised myself I wont hop up the engine until I figure out whats the issue with my B distributor. It'll be KONG equipped! IMG_0150.jpeg
  2. Outback
    Outback
    from NE Vic, Oz
    Still here, not doing alot with the A, but it is Parked outside the kitchen window! IMG_20250420_082059.jpg
    Al this Fronty talk is interesting,
  3. Dedsoto
    Dedsoto
    from Australia
    Picked up this quick change a week back for $100, hoping it was early ford compatible, unfortunately it's midget so will look at selling it on or trading for parts. Had to take the gamble on $100 though (around $65USD)
    Outback and jet996 like this.
  4. choptop4
    choptop4
    winduptoy likes this.
  5. Fabber McGee
    Fabber McGee
    A midget quick change should be plenty strong for a banger. Some sprint car racers are using midget QC's reliably in the 307" cl*** and saving 25 pounds. Check in with the Quick Change threads to see what it takes to put a differential and Ford axle housings on it.
    jet996 likes this.
  6. 29Sleeper
    29Sleeper
    from SoCal
    Use it. Hot Rodding is all about adapting what you have or bought cheap to make it work on your car. The only thing that may disqualify it is width. If it's too narrow the cost to widen it may exceed an alternative.
  7. Super88
    Super88
    spendingtheirinheritance I saw your car at the Miller Meet in Milwaukee years ago. I enjoyed seeing the car and the story about how you acquired it.
  8. 29Sleeper
    29Sleeper
    from SoCal
    jet996, winduptoy and GuyW like this.
  9. Dedsoto
    Dedsoto
    from Australia
    The width is spot on for the 36 rear ends I have, diameter is the issue, this thing is tiny, smaller than A model. Other problem is even with cutting bells and making smaller diameter rings for them to bolt up I'd only be able to run the spool and 5:1 ring gear it came with. Juice isn't worth the squeeze I'd say.
    That's a 36 ring gear, and the spool
  10. Dan from Oakland
    Dan from Oakland
    Any reason not to put a Model A ring and pinion in it with Model A center section and axles? Just asking...
  11. Dedsoto
    Dedsoto
    from Australia
    I don't have any A rear ends apart but I believe this is even smaller than an A, ring gear measures 7-1/8OD 4-3/8ID
  12. I was thinking it looked too small also
    It looks like a Speedway Engineering Mini Stock QC, not sure
    J
  13. 29Sleeper
    29Sleeper
    from SoCal
    Yes Speedway. They offer the MiniStock for street rods. Those tubes take regular Ford car backing plates and brakes with your choice of axles. You'd probably be better off just sourcing the tubes down under to save shipping etc.
    They also offer the center section to accept early Ford bells.
    7803-10 Street Rod Large Bearing Early Ford Bolt Circle N/A .188”
    7803-10-1 Street Rod Large Bearing Torino Bolt Circle N/A .188”
      97.5 KB
  14. Dedsoto
    Dedsoto
    from Australia
    Thank you for the info, it is indeed a speedway engineering piece. I don't like my chances but I'll see what I can turn up down here.
    Outback and winduptoy like this.
  15. BeaverMatt
    BeaverMatt
    I received an e-mail today the Virginia City Hill Climb in May has been canceled. Does anyone know why?
  16. drtrcrV-8
    drtrcrV-8
    Virginia City Hill Climb has been canceled because the city hasn't fixed the hump in the street that almost launched one of the racers into the crowd, & the FAST club is not going to race on a known dangerous course. We would like to go back AFTER they fix the street.
  17. BeaverMatt
    BeaverMatt
    Thank you! Great explanation drtrcrV-8
  18. Jiminy
    Jiminy
