Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. dana barlow
    dana barlow
    from Miami Fla.
    UpDate on post here #4983;
    Back ground zero,again !
    Got back together,but not really=Runs bad n leaks water !
    Still have no idea why it over heated back at the begining of this?
    Now,things I do know,upper ThemO home made housing is a prob,as it is not as straight on it's gasket contack place=will need to flaten that out.
    Running bad; My best guess>Must of ****ed a intake gasket from all the heat ?= Will pull intake n replace gaskets< is a homemade intake / Log type with 4x2's= first time it had leaked? Between heads n intake?.< If so,this could of been making run lean/hot?
    We'll see,more up dates later.
  2. That's the story of my life!
  3. PBRdstr
    PBRdstr
    Spent the last couple of days replacing (+ slightly modifying/tweaking the new ) front springs in my PB Roadster.
    The original, 93 y.o. springs or more specifically the right front main leaf with who knows how many miles beyond +/-100.000 I’ve driven on it/them in past 35 years broke (due to aging & metal fatigue) sometime during my Saturday morning drive to GNRS '25, prompting not only a call to AAA to get the car & me back home later that afternoon, but also a few weeks later, after first trying something experimental & temporary by welding the broken leaf and carefully drive around town to see how long it will hold up, couple of calls to Detroit Spring to discuss availability, confirm specs and place an order for new OEM-type replacements which finally arrived last week.
    Once I’ve driven a bit more and verified they work as expected, I’ll order a pair of replacements for the rear since those are also now 93 y.o., have 100.000+ miles and likely right on the verge of expiration.
    The second image shows how I prepped and tied the broken spring together for the drive from home to my shop (only about 3 miles and using back streets).
    Yeah, I could’ve called a AAA flatbed, but this was quicker and more interesting experience.
    61EA133C-42FD-4399-9ADF-7FE57D4E0664.jpeg E314102B-E2E6-4790-A6AE-9E54AD885E8E.jpeg
  4. tomcat11
    tomcat11
    porkshop likes this.
  5. 57 Fargo
    57 Fargo
    Put some 2.5 degree caster shims in the Fargo, trying to gain a little more road feel
  6. alanp561
    alanp561
    And???
    Bill's Auto Works and porkshop like this.
  7. deathrowdave
    deathrowdave
    from NKy
    I have the OEM bolts in mine . The are not the same design and have a hole and castled nuts, along with the springs . The bolts you have used are nice , are they replacements for this purpose ? If so where did you purchase them . Thanks and be safe
  8. 57 Fargo
    57 Fargo
    Let you know after I drive it tomorrow, got it done and came in for Easter dinner
  9. nochop
    nochop
    from norcal
    The bolts and spring are some sort of exhaust bolt. I saw them at Auto Zone. I fabbed up the bottom keeper and added the nylock nut IMG_8228.jpeg
  10. 57 Fargo
    57 Fargo
    Drove the truck to work today, big difference with more caster, could probably use another degree or two
  11. swade41
    swade41
    from Buffalo,NY
    Me looking for something
    That wasn't there
    So I had to make one
    Okie Pete, rod1, Jkmar73 and 18 others like this.
  12. deathrowdave
    deathrowdave
    from NKy
    Thank you for the help , my Friend
  13. Sandcrab
    Sandcrab
    Like swade41 I was looking for something that wasn't there so I had to make one. I couldn't reach the shift lever on the T5 without leaning forward so I turned a taper on a chunk of bar stock and threaded it on. The ball is in the mail, so I'll thread the extension when it shows up.
    simplestone, Okie Pete, rod1 and 10 others like this.
  14. Building another blown flathead using an Eaton lung, curiosity has got the better of me. Block is at the machine shop so started with initial mockup and carb adaptor fab. Will also need to mock up/machine pulleys/idler and hone out a SBC balancer to make it fit the flathead crank snout.
    Blower is a new Eaton M90 off a 90s T Bird Supercoupe.
    Should be interesting :)
  15. swade41
    swade41
    from Buffalo,NY
    Foiled by the delivery system to finish this job up, one of the downfalls of a 2x4 system is that you need twice as many jets. I had ordered them ahead of time to coordinate with the timing of this job but so much for that strategy.
  16. Sandcrab
    Sandcrab
    I had widened the Ruby by four inches and today I soldered up the two windshield frames to fit the opening. I lost the latch to open it when I mounted the '32 Chevy dash, but I kept the flange on the frame so I will fabricate another.
    I had cast a fixture to weld the tooling for my Pullmax and it turned out to be just what I needed to hold the pieces ****ed together so I could silver solder a tie strap in the bottom of the channel.
    Resized_20250422_150419_1745370000846.jpeg Resized_20250422_164742_1745370051432.jpeg
    Sharpone, Okie Pete, rod1 and 14 others like this.
  17. F-head
    F-head
  18. dana barlow
    dana barlow
    from Miami Fla.
    Update from post# 5106.
    The intake gastket on left side,was for sure gone bad,bottom lip of intake port was no seal/could even see were it had been going p***ed,for the hole bottom of lower port.
    Up tell now,nothing I had looked at "Screamed" I'm screwed up right here"> But now found a real prob o_O:D:cool:
    Sharpone, Okie Pete, enloe and 13 others like this.
  19. J. A. Miller
    J. A. Miller
    from Central NY
    Good to hear Dana!
  20. Robdski
    Robdski
    I hit a major milestone yesterday!
    This is the ch***is I started in July of 2024. I was able to strip the parts off the old frame down to just the original 1934 Ford outside frame rails. I was able to straighten the bent rails and add IMG_2696.jpeg IMG_2910.jpeg IMG_2980.jpeg IMG_2981.jpeg IMG_2986.jpeg IMG_2998.jpeg IMG_2997.jpeg IMG_3395.jpeg IMG_3530.jpeg IMG_3530.jpeg IMG_3612.jpeg IMG_3613.jpeg IMG_3618.jpeg full boxing plates from Speedway. Then fabricated all the round tube crossmembers from 1 1/2” x 1/8” wall, DOM.
  21. Wiring, wiring, wiring, waiting on some more wire and then wiring, wiring . . . You get the idea. Also, spending hours looking for the Duraspark II ignition wires I've put in a safe place, but which I couldn't remember where. After spending hours looking for it and starting a monumental garage cleanup, I found it exactly where I put it so that I wouldn't lose track of it. My memory is obviously not as good as it used to be. That's the bad news. The good news is I'm closing in on getting this project to the start-up point. I'll have all summer to get it there.
    Sharpone, Okie Pete, enloe and 5 others like this.
  22. swade41
    swade41
    from Buffalo,NY
    My parts came in, they were nice enough to deduct $4.99 off my bill since I let them know they were late. Lol Anyways I finished up the carbs and got it all back together.
    I went to the other end of the car and moved the alternator charging wire to the other post on the battery cutoff switch, hopefully that shuts the car off now. The only thing yet to fix is the pesky leak on the line lock, which I've addressed a couple times already.
    With the wire moved I jumped over to the shrunken head that rides in the 41, his bone was to long so I took a little section out of the middle. I epoxed it back together with a stiff copper wire where the marrow used to be, should be good.
  23. Paul
    Paul
    Editor
    tore down another Olds engine
    this one a '57 371
    standard bore, crank rod and mains.
    cam, lifters and whole valve train look real good.
    it's borderline per spec on the crank but I'm going to hand polish it, hone the cylinders and give it fresh bearings, rings and gaskets.
    may not last a 100 thousand miles but it should hold together a little longer.
    PXL_20250424_002931335.jpg PXL_20250424_003015689.jpg PXL_20250424_003303289.jpg
  24. rusty_bits
    rusty_bits
    Squablow, Sharpone, Okie Pete and 5 others like this.
  25. PBRdstr
    PBRdstr
    Finally, after spending countless or dare I say too many hours over past several days tweaking and fine tuning the front suspension, including ride height, caster angles & other handling characteristics, I think it's as good* as I can make it and while preliminary, short road tests seem to support that, I can hardly wait to take her for a "spirited" +/-100 mile Sunday morning drive up to local mountains to confirm success.
    And if everything goes well, I'll look into ordering new rear springs soon.
    * This was one of those countless instances where the famous quote "Perfect is the enemy of good enough" turned into my own interpretation or version of it: "Perfection can become a victim of good enough".
    Sharpone, rod1, 26 T Ford RPU and 2 others like this.
  26. dave agosti
    dave agosti
    My latest project, original 32 Ford 5 window. At one time in Salt Lake City area, found 1954 SLC newspaper in trunk lid. Installing 241 Dodge Hemi, T5 transmission, QC, Buick front brakes.
    tempImageDzdaH0.png tempImageSlzw0X.png tempImage5boN7b.png tempImagelUBJe2.png tempImage09zHuG.png IMG_1660.jpeg IMG_1659.jpeg IMG_1657.jpeg
  27. Sandcrab
    Sandcrab
    I started work on the Ruby hood to fill the gap from the 6" engine bay extension and the 4" widening then added the third vent. Resized_20250424_175112_1745544722078.jpeg Resized_20250425_110024_1745630176045.jpeg Resized_20250425_171332_1745630180297.jpeg
    I'll trim the bottom edge after mounting the fenders to deter,mine the placement of the hood latches.
  28. saltflats
    saltflats
    from Missouri
    That looks like old school torch welding to me, good on you.
  29. snoc653
    snoc653
    from Iowa
    Finally got the rear end out of the 51. Now I’m drilling out the rivets holding the rear spring hangers on the frame. Transmission and Engine will be out by Monday (barring complications) and then I can pull the front suspension and brake master cylinder. I am now wondering if I should take the body off and have the frame blasted or just paint it and call it good. I still have to do some supports for the roll cage and a crossmember for the transmission as well as a driveshaft loop. If I have the frame blasted, I could leave it bare while I build and weld then paint it. Or I could just wire wheel it and paint it and call it good enough for the girls I run with.
    Shot of spring hanger shows the lack of rust on the frame. upload_2025-4-25_23-12-4.jpeg
  30. saltflats
    saltflats
    from Missouri
    Strange looking arms on that lift.
    Tickety Boo and Sharpone like this.
