1966 Nova Wagon (are we ever really done?)
Discussion in 'Off Topic Hot Rods & Customs' started by rob-redm, Sep 11, 2024.
  1. rob-redm
    rob-redm
    went for New Year's 2025 drive yesterday. that was a blast. already have a new 2025 list started... out with HEI, going with an MSD 6AL Box ( with rev control) MSD Pro Billet Dist, and Blaster coil... new plug wires ( MSD) or if anyone has a suggestion what better ... Blue print 396 crate engine has headers... but the plug connectors are close.. should I use some type of heat protection.. ? also a few friends have pointed out the fuel supply line to the carb... we will be changing that .. also put an metal inline fuel filter at the back.. can see it in the picture .. but there is a rubber hose running to a either gl*** or plaster visable filter... .. going to change this a solid line... output_image1726093786672.jpg
    Okie Pete, 1Nimrod, swade41 and 4 others like this.
  2. AHotRod
    AHotRod
    Love your Wagon brother, it's got to be a riot.
    My daily driver for the past 15 years is also a '66 Chevy II Wagon that I thought I'd share a couple of pictures with you so you don't feel like a lone ranger around here.
  3. ***Area-51***
    ***Area-51***
    from Ohio
    Nice little wagon!! Nice daily driver....
    1Nimrod, porkshop and AHotRod like this.
  4. rob-redm
    rob-redm
    1Nimrod likes this.
  5. rob-redm
    rob-redm
    not much to report.. MSD parts are on order , going with 6al box, blaster2 coil and pro billet distributor.. need to figure out what wires to run.. header and spark plugs are really tight... finally got the carb fuel line that was on back order for a month...
    1Nimrod, AHotRod and porkshop like this.
  6. 6sally6
    6sally6
    Gonna keep all 4 doors ?!?
    6sally6
    porkshop likes this.
  7. rob-redm
    rob-redm
    yep.....why mess with it..
  8. 6sally6
    6sally6
    6sally6
    1Nimrod and Deuces like this.
  9. rob-redm
    rob-redm
    two thumbs up for the win..
    1Nimrod likes this.
  10. DDDenny
    Chevy II thumbs up!:D
    1Nimrod, rob-redm and Deuces like this.
  11. rob-redm
    rob-redm
    yes sir !
  12. Love you're wagon.....following!!
  13. rob-redm
    rob-redm
    Thank you !
  14. rob-redm
    rob-redm
  15. Racingsnake
    Racingsnake
    from So Cal
    Very nice! Much improved with the changes you’ve made too. The wheels in particular look great, what gold do you use on them?
    1Nimrod and rob-redm like this.
  16. rob-redm
    rob-redm
    So a friend of mine... did this color on some American's on his Dad's 56 Chevy... It's Eastwood's Carb Renew paint.. The color of the gold is great... I've contacted @eastwoodco , it's not available right now... Need to replace his can of paint... Its being reformulated per the Rep I spoke with .
    1Nimrod, porkshop and Phillips like this.
  17. Tim
    Tim
    from KCMO
    Looks great, dig the upgrades
  18. Racingsnake
    Racingsnake
    from So Cal
    Thanks, hopefully the reformulated stuff looks the same
  19. rob-redm
    rob-redm
    I hope so also.. I want to buy about four, give my friend back two for his help.
    1Nimrod likes this.
  20. rob-redm
    rob-redm
    Thank you ! its getting there.. Still haven't got around to installing the geen line SW gauges ( non heated garage ) Waiting on MSD 6AL box and MSD Pro-Billet Distributor now... remote oil filter coming Canton Racing ..still running break in oil...
    1Nimrod, porkshop and Tim like this.
  21. rob-redm
    rob-redm
    nothing really much to report.. been way to cold the last few weeks.... Did get my window lace for the upper driver door frame. door gl*** rattle
    1Nimrod, porkshop and loudbang like this.
  22. rob-redm
    rob-redm
    scored a great deal from my friend on a new MSD Dist & 6AL box.... Need to order some rev control chips for the box... 6000-6500 rpm . My shift skills aren't that great these days ( ie getting old ) .. so could I go maybe higher on the chip ? thoughts.. its again a 396 SBC ( Blueprint crate engine) Muncie M20 4 Speed
    1Nimrod, Deuces, loudbang and 2 others like this.
  23. rob-redm
    rob-redm
    picked some original LT1 Valve Covers for the Wagon... Now can ditch the Blueprint Valve Covers.. ... next Blueprint lettered dipstick.. sand off the lettering and paint it red.... lt1.jpg
    rockable, Okie Pete, 1Nimrod and 4 others like this.
  24. Deuces
    Deuces
    Actually those are cross ram valve covers for a 1969 Z/28 Camaro..... WoW!....:eek::cool::)
    1Nimrod, rob-redm and porkshop like this.
  25. ekimneirbo
    ekimneirbo
    Great looking DD..........my only suggestion is to upgrade the Muncie while it still works well and get a Tremec 5 speed to replace it. The Muncie is probably worth $1k in good shape and would ease the sting of a new Tremec. Probably never tear it out with your 396, while the Muncie will be expensive to repair and lose value if you break it. The overdrive will make your daily driving much more enjoyable. :)
    Muncie variations: https://www.motortrend.com/how-to/1808-guide-to-muncie-m20-m21-and-m22-four-speed-transmissions/
  26. DDDenny
    How did we get by with the lowly four speed?
    rob-redm, 1Nimrod, vinfab and 4 others like this.
  27. ekimneirbo
    ekimneirbo
    55 mph highways and lots of rebuilds along the way.........:D The 350/350 was the most popular hot rod automatic transmission until highway speeds became 70-80 and gas prices went up.....then an awful lot of people saw the benefit of using a trans with overdrive. Same thing with the manual transmissions today, almost every manual transmission produced for cars and 1/2 ton trucks has more than 4 gears.
    4 speeds work today but usually at some compromise in acceleration vs cruise speed. Personally I have always felt that the choice of a transmission should get way more consideration than most people give it. It can often mean the difference in whether someone drives a car a whole lot...........or not.:)
  28. rob-redm
    rob-redm
    It's not a daily driver... have my other two off topic cars I drive daily... lol... The Muncie was just rebuilt by the previous owner... all the drive train is new.... I'm not one to abuse my stuff. I drive pretty easy. lol .. but a little spirited moments due come up ...
    1Nimrod and porkshop like this.
  29. rob-redm
    rob-redm
    I was told they were off a LT1.... will check the cast part numbers...
    1Nimrod, porkshop and Deuces like this.
  30. Dick Stevens
    Dick Stevens
    I had a 63 Impala with M21 trans and never had to rebuild it in 70,000+ miles of spirited driving including a lot of drag racing, both on the street and drag strips! Cars today benefit from more gears as they are in cars powered by 4 cyl engines that lack torque. If the car has a 4 speed or 5 speed will make you decide whether or not to drive it much I'd say that you aren't much of an enthusiast!
    SS327 and porkshop like this.
