Projects A New England Drag Coupe
Discussion in 'Traditional Hot Rods' started by 51box, Apr 22, 2025.
  1. 51box
    51box
    from MA
    So I’ve been daydreaming about an early style drag coupe for a while now and finally pulled the trigger on a 30 coupe to get the ball rolling
    First order of business was to chop it before removing it from the stock ch***is. It came out to about 4.5”s
    Because the engine will be set back to the A pillar, I decided to put louvers in the cowl top to help get rid of some heat.
    I built a really simple 4x2 frame tapered and swept up 2”s in the front and pinched to fit a 32 shell.
    With the 283 set back as far as I could go and still fit in the car.
    Trans is a Dearborn toploader 3spd with a Ram slipper clutch. 9” rear solid mounted with spool and 5.29 gears.
    Steering box is a mid 50’s f100 with a mix of original ford and aftermarket parts to complete the suspension.
    After sectioning the shell a couple inches I Made up an aluminum insert for it that will have the cars name painted on it.
    The steering wheel is out of a 57 corvette
    This is basically where I’m at on the project, will try to keep things up to date as progress happens.
  2. NoSurf
    NoSurf
    Pretty cool. I like the idea of a 283.
    You gonna drag it up to Oxford for NEVD?
    Stogy and mad mikey like this.
  3. Hollywood-East
    Hollywood-East
    That is Bad A$$ !
  4. Bentrodder
    Bentrodder
    from Cotati
    Subbed!
    Stogy likes this.
  5. flamedabone
    flamedabone
    Looks like you are pretty handy with the fabrication.
    Neat little car.
    -Abone.
  6. GordonC
    GordonC
    That is going to come out nice! Keep up the good work.
  7. mad mikey
    mad mikey
    Wicked! I love it! Keep us posted.
    deathrowdave and Stogy like this.
  8. Dave G in Gansevoort
    from Upstate NY
    The chop is perfect. Okay I’m in
    mad mikey and Stogy like this.
  9. 51box
    51box
    from MA
    Thanks guys, it’s been a fun project so far. I hope to have it finished for next season and will definitely run it at the NEVD events
  10. Russco
    Russco
    from Central IL
    I’m digging the hell out of it so far. Well done….
  11. 1971BB427
    1971BB427
    from Oregon
    Nice start so far! Great choice on the 283 engine.
  12. Stooge
    Stooge
    Damnit thats looking cool! Great chop and love to see other M*** cars getting built
  13. 51box
    51box
    from MA
    Whenever I’d see a photo of the top hat coupe or the loaded toad it would just feed the fire on wanting to build a coupe in that style. I’m not building a replica of either of these, just sharing the inspiration.
  14. oj
    oj
    What'd it be, D/Altered? 'S'?
    Stogy likes this.
  15. 51box
    51box
    from MA
    Im not really sure what it would be considered, haven’t looked into it yet. The S is my last initial, something I add one way or another on the cars I’ve built.
    mad mikey, Stogy and oj like this.
  16. The37Kid
    The37Kid
    Really like the chop. For some reason it looks like you made the cuts in different locations than others. Nice that you started with a solid body.
    Bob
  17. Malcolm
    Malcolm
    from Nebraska
    Oh man, this is gonna be cool!
  18. Stogy
    Stogy
    I like your style 51...;)
    oj and mad mikey like this.
  19. Looks awesome! Good times ahead.
    The37Kid and mad mikey like this.
  20. BigJoeArt
    BigJoeArt
    I've been following as you hint at it on Instagram, I'm glad you're doing a thread on it here too!
