9s for $9k
Discussion in 'Off Topic Hot Rods & Customs' started by squirrel, Mar 18, 2025.
  1. squirrel
    went shopping, after hauling a load of s****.
    1989 2wd front axle, 99 exploder 3L73 rear axle
    Chavezk21, Thor1, dwollam and 14 others like this.
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It’s official when a straight axel is up front. ;)
  3. RodStRace
    RodStRace
    Did the yard paint pen the parts? Always a low-buck sign!;)
    Of course if they match the underside, it might look like it's all OE junk...
  4. squirrel
    yeah, they mark them. the rear got the dremel tool treatment to really mark it well.
  5. squirrel
    Got the front end swapped in today, and the old rear out, and both old axles on fb marketplace for sale.
    So far I've sold about $600 or so of stuff locally and on ebay, amazing what a few thing sell for...I got $95 for the valve cover off the 4 cyl, and the dipstick and tube from it sold for $62. Weird.
    Thor1, dwollam, Rawrench and 23 others like this.
  6. AmishMike
    AmishMike
    What front axle did u use? Always like idea of move axle forward a few inches
    41 GMC K-18 likes this.
  7. squirrel
    I used the original 2 wheel drive front axle from a 1989 Cherokee. These things were made both 2 and 4 wheel drive. The 2wd are pretty rare, but I found one at a junkyard. I wanted to move it forward, but that's time and money that I don't need to spend...they sell all different length control arms for guys who lift them, so that part isn't too hard. The vertical coil springs and shocks will kind of limit how far you can go.
    dwollam, 1Nimrod, Sharpone and 7 others like this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    My son yesterday for giggles ran his stock Yukon down the track. Is “Cheep” coming out to LS Fest next year? IMG_4029.jpeg
  9. squirrel
    I haven't planned that far ahead, but I'd like to go to Drag Week...which is two weeks later...so probably not gonna happen.
  10. squirrel
    set the new rear in place...still some work to do on shock brackets, and finalizing the pinion angle, and making the traction bars.
    I also did an experiment with the parking brake cables, to see if it works. Welded a washer to the ****on, so it can pull the lever.
    Sold the old axles today...and ordered a whole bunch more parts. They sure add up, maybe I'll make the $9k goal, maybe not, but if I don't do the accounting properly, it won't really matter, eh?
    dwollam, Rawrench, 1Nimrod and 13 others like this.
  11. snoc653
    snoc653
    from Iowa
    Speaking of adding up. Are you going to leave the skid plate on the gas tank? All those unnecessary parts add up and I think you have a weight goal.
    porkshop, Sharpone and squirrel like this.
  12. squirrel
    This one seems to just have a plastic cover under the gas tank. I just glanced at it. If it's not much work, or I have to pull the tank for some other reason, I'll take it out, but if it only weighs a pound I probably won't bother.
    There are a bunch of other things I've taken off to save weight. I do think about every part I look at, if it's really necessary or not. And there's a tradeoff of work for weight, I'm also lazy!
    dwollam, 1Nimrod, bobss396 and 4 others like this.
  13. Sharpone
    Sharpone
    Yeh I’m thinking lazy You’re not.
    Dan
  14. 41 GMC K-18
    41 GMC K-18
    As a person that had a history with a couple of cool checker marathons, I still miss them and the short time period that @squirrel had his adventure with the Black and Blue warrior.
    I have to admit, now with the birth of "CHEEP" I am indeed a big fan of Jim's latest project !
    Thanks from Dennis.
  15. Dan Hay
    Dan Hay
    This thread rules! Subscribed!
  16. squirrel
    thanks!
    I ordered a bunch more parts over the weekend. now I'm off camping for several days, but there's good phone connection, so I get emails about all the stuff being delivered, that my kid is bringing into the house for me, and I don't get to play with it till Friday.
    dwollam, Rawrench, porkshop and 8 others like this.
  17. Johnny Gee
    Johnny Gee
    from Downey, Ca
  18. Crosley
    Crosley
    from Aridzona
    We hang this out when 5th wheel is parked.
    porkshop, SS327, Baumi and 4 others like this.
  19. Zuffen
    Zuffen
    from Sydney
    Did Zephyr or Aardvark miss their signs?
    What did you do with the rest of the alphabet?
    Great thread and like all your threads, following along.
    squirrel likes this.
  20. squirrel
    I closed aardvark a long time ago. Zephyr s owner died 20 years ago. No worries.
    TrailerTrashToo likes this.
  21. squirrel
    I got back from camping, there was a big pile of boxes waiting for me.
    I've been going through all the parts and figuring out what else I need...put in another order today from summit...it never ends?
    Took one of the heads apart, they need stiffer springs for the new cam. I decided to do a little lapping on the exhaust seats to take away the carbon, just because. But I probably won't do much else to them, just some more cleaning, and probably new valve stem seals.
    Thor1, dwollam, 1Nimrod and 15 others like this.
  22. Some pac1219 springs or something else?
    porkshop likes this.
  23. squirrel
  24. AmishMike
    AmishMike
    No clean up of ports or even a gasket match. Grinding easy just time
    Sharpone likes this.
  25. squirrel
    They did a really good job building these engines, there's nothing to be gained by doing all that fun work. And this is the non-traditional forum :)
  26. squirrel
    A before and after the 320 grit ball hone. There are still a few rusty areas, but they're down low and minimal depth. I think it'll be fine.
    Ring gap check says they're right where they want to be after 147k miles.
    Thor1, dwollam, 1Nimrod and 11 others like this.
  27. RodStRace
    RodStRace
    Yeah, I saw the ports and thought, hmm. Then remembered forced induction. Other gains elsewhere.
    Glad the project seems to be going well for you, Jim.
  28. AmishMike
    AmishMike
    Saw LT motor aluminum heads. Looked like machined for steel value seats 1” into ports left huge ridge up into ports. I always did my own porting to at least smooth out ports. Will have to check iron LS 5.3 see what I think
    dogwalkin and porkshop like this.
  29. squirrel
    Older chevy heads needed a lot of smoothing work! but the LS engines were designed after Chevy figured out how flow works, and that it's important to build in good flow from the start.
    dwollam, 1Nimrod, rod1 and 9 others like this.
  30. squirrel
    putting parts back in...crank and cam are in, and I set a head on to check piston to valve clearance with the new cam. Looks like there's plenty of room.
    dwollam, 1Nimrod, Deuces and 10 others like this.
