Technical Model A wheel alignment......
Discussion in 'Traditional Hot Rods' started by chopped51, Apr 23, 2025.
  1. Okay, so it's been a long, long time since I've posted anything. But I'm looking to get some information from people smarter than me. I know there's lots of them here. My latest build, the 1928 sedan. With the usual four inch drop axle, Vega box etc etc.
    No different than any other Rod I've 20250308_144155.jpg built before. The problem with this one is it really likes to wander. Anything over 50 miles an hour on the mildly twisty road and it hunts all over the place. I've done the wheel alignment three times. (Caster) The last time with the wheels off and angle iron bolted to the rotors. Running approximately 1/8" toe in. Put all new tires on (radials) steering is tight and responsive regardless of speed. But anything over 50 miles an hour and it's both hands on the wheel and white knuckles.
    Any ideas?
  2. Tim
    Tim
    from KCMO
    Try a different road?
  3. ALLDONE
    ALLDONE
    if it doesn't have a panhard bar, thats what it is supposed to do
    GordonC and gary macdonald like this.
  4. 05snopro440
    05snopro440
    • What's the caster setting?
    • Does it have a panhard bar?
    • If you have a panhard, does it attach to the axle on the passenger side and frame on the driver's side?
    • Are the king pins tight?
    • What's the king pin angle on both sides of the axle?
  5. gary macdonald
    gary macdonald
    Sounds like the caster is zero . Do you have any way to measure the king pin inclination or caster ? is it split bones , 4 link or ?
    was the frame kicked up in the rear with parallel leafs or stock ?
    the higher your rear frame is the less caster you have , I usually shoot for 7 degrees.
    taller rear tires can make the situation worse . When checking caster , make sure its at ride height .
    I type slow ….
  6. All good questions. Try to answer as best I can. A different road. Great idea. Not. It has split bones front and rear with a triangulated setup as well on the rear. And a panhard bar. Caster is currently at 5°. Positive. Frames stock, boxed, no kick up in the rear.
  7. twenty8
    twenty8
    Can you put up a pic from front on so we can get an idea of what scrub radius it is running?
  8. ALLDONE
    ALLDONE
    is there a track locator on the rear... sometime if the panhard is set wrong it pushes too much...
  9. No problem posting a picture of the front end, what did you want me to focus on?
  10. There is no track locator. I only have a maximum of about 2 in of travel at the rear so I can't see it being a problem with the panhard bar. But I've been wrong before.
  11. twenty8
    twenty8
    Front on shot of the outer end of the axle showing the brakes and wheel.
    If the wheels sit out too far it can cause tramlining (the front wanting to react to and follow road imperfections).
  12. Okay, I'm on it. First thing in the morning.
  13. Pete Eastwood
    Pete Eastwood
    from california
    Does it have a panhard bar on the front?
    If not, then that's your problem . . .
    RMcCulley and winduptoy like this.
  14. No, it doesn't have it on the front. I've never had one on the front. Not saying I don't need one. But that should be something I'm going to look into.
  15. 05snopro440
    05snopro440
    On what side of the car does the panhard connect to A) The axle, and B) The frame?
  16. alchemy
    alchemy
    Cross steer boxes need a panhard bar on the front. That’s why everyone is asking about that. Just kinda common knowledge.
    Please describe better what you mean by split wishbones on the rear, with triangulated setup? Are they bushed at all ends like four bars?
    warbird1 and Johnny Gee like this.
  17. Kevin Ardinger
    Kevin Ardinger
    For sure needs one in the front! Probably a lot more caster too if you can.
  18. Kerrynzl
    Kerrynzl
    @chopped51
    Do not add too much caster [the Hotrodders folklore myth]
    too much caster combined with extra scrub radius is what triggers "death wobble" in lightweight vehicles
    Camber and toe are "bed partners" [pos camber needs Toe-in , and neg camber needs Toe-out] or you get camber thrust.
    Have you checked for bump steer?
    Also check rear for "roll-steer" [a wheelbase variation during suspension movement]
    If the unstable feeling is in the steering it is usually the front end. If you feel it in your seat, it is usually the rear end.
    26 T Ford RPU and twenty8 like this.
  19. I can't thank you guys enough for all these replies just in the last couple hours. Sometimes you need somebody looking from outside the box. This is not my first build but it's my first build with a problem like this. And I think some of you are absolutely right. I've just been lucky in the past by not having a panhard bar in the front. I'll be making one tomorrow.
    gary macdonald and winduptoy like this.
  20. twenty8
    twenty8
    Absolutely the place to start. I thought you said it had one, but after re-reading your post I see that you meant it had a rear panhard bar. One on the front will hopefully cure the problem, but if it doesn't, it will still have been a good idea.
  21. ALLDONE
    ALLDONE
    I've noticed quite a few that put a good stabilizer on the front with good results.... I even have a model A with it done...and it works great...
  22. wheeltramp brian
    wheeltramp brian
    I've got no panhard in the front but the Spring angle is pretty tight.caster at 10° toe 1/8".never a problem
    Kevin Ardinger likes this.
  23. Blues4U
    Blues4U
    from So Cal
    With side steer you don't need a Panhard bar, with cross steer you do.
    05snopro440 and winduptoy like this.
  24. alchemy
    alchemy
    Is that on a FED?!
    gimpyshotrods and 05snopro440 like this.
  25. ROADSTER1927
    ROADSTER1927
    On the front of my roadster I put a dead perch on on side and have a panhard bar in the rear. It drives like a rail and corners great. Gary cold or wet.jpg original d.jpg
  26. woodiewagon46
    woodiewagon46
    from New York
    Your front end is basically "hanging" from the spring and shackles, if the shackles, perch bushings and spring bushings aren't tight and you do not have a panhard bar, you can wander all over the road. As others have suggest install a panhard bar and it will probably improve your handling. If you jack up your car and try to move the front end side to side you might be surprised at how much a "loose" front end can move, it doesn't take much.
  27. wheeltramp brian
    wheeltramp brian
    On my roadster with 30000 miles. I set up every car I build with a lot of caster, including this coupe
    with 10° also.
    Kevin Ardinger, alchemy and Gotgas like this.
  28. 05snopro440
    05snopro440
    A friend bought a 32 roadster street rod, it was a new build with under 300 miles. He drove it a bunch and after a few years it developed dangerous bump steer. It was a 4-bar and dropped axle with no panhard, and the bushings had worn enough that now he needed one. He installed a panhard and it has been fine again for several years now.
  29. 05snopro440
    05snopro440
    The reason I'm asking about how your panhard bar is anchored (I thought it had one on the front too), is a friend learned the hard way that it matters where it attaches to the axle. The panhard should attach to the chassis on the same side of the car as the steering box (driver's side), and attach to the axle on the opposite side (passenger's side). If it doesn't, you'll get some real bizarre bump steer characteristics. Keep that in mind when you're building your bar.
  30. Okay, less than 24 hours and I have an update. Went out in the shop this morning. Found some 1-in tube I had left over and a couple Heim joints. Kind of overkill. But I welded a bracket at the very front of the bone on the driver's side up to the frame on the passenger side. Just got back from a drive down the twisties. Wow, wow, wow. Can't thank you guys enough for the input. I will never build another car without a panhard bar in the front. The car handles completely differently now. Very impressed. Time well spent this morning.
