If you’re asking us for colour opinions, black doesn’t go out of style, the light green looks neat, but the two tone with Indian logo suits the truck best. If you’re not asking for colour opinions, - nice looking truck you have there ! (even better if you paint it two tone with the Indian logo).
from the front 1. make new irons for the dipped bumper, raise it so the ends middles sit at the fender bottoms . 2. delete crank hole in grille fins 3. the 34 headlight stands there in pink are totally pointing in the wrong direction, you must repair the stockers, CHECK the bolts in the headlights you have are long enough..... dont worry about smashing the gl*** - they are cheap h4 units.. and you have 4 spares!!! 4. radiator - -sitting in the drivers seat looking at the rear - -top right - -bottom left - - br*** ? header tank above - -cap location - engine up crosmember and lower hose -remember! 5. put motor and transmission back and raise and inch - -stick clears bench seat and lower gearbox clears bone, manifold clears steering -CUT firewall!! - trans clears stock floor panel- stock clutch actuator rod perfectly for fork!! - - 6. fit original engine block supports. 7. must get a mt75 round output flange - -oem external slip yoke to flange - -propshaft will be LONG must have outy clips and not peened over u/j parts - -non oem>? will you need the prop in 2 bits with a support, will be 60 inch long? 37 ford was 55.5'' with long t5? - will they only make one in 3'' tube? 8. so cal gear knob is 7/16 unf extend stick 100mm 9. what is the thread on the window crank - -countersink ****on screw. 10. make trans mount to land on stock 36 lug parts - -bolt is LONG 11. finish the dash - -fit all the switches - -too tight on right for key - -place idiot lights two clicky clacky - - oil - ign. - -find a two pull and motion for windscreen squirt 12 . re-do the under seat battery box, its too small, fit a bigger battery. 13 FIND a seat riser and 1936 1/2 ton inner fenders - -37 are not the same. 14. lowr the rear - -make 2/34'' saddles - find 2 3/4'' long u-bolts, move back mount into frame... -- last. 15 loom MUST have a plug like oem at the firewall - multiplug, you idiot, you cut it all out.. 16 spring loaded non surge pump - with return and vent - -measure depth of tank, measure impedance of sender - -then do same for aftermarket gm style you do not want another hole in the tank. 17 - -grommet from tank to cap - -can you have the fill in the bed? - do not point it upwards.. 18 land rover defender screen £120. 19 WHERE IS THE DOOR WINDOW LIFT CHANNEL? 20 just fit the window cranks and channels - -no gl***, fit door opener and crank - -make door cards, d/s tape them for now. 21 you can if you wish switch to v belt pulleys, and a viscous fan - shroud. run a tiny denso alternator . switch them around pas pump drivers side -
oddly the 37 pickup is burgundy with black fenders I have to run it blue I am trying to decide what saturation - -i am thinking sky blue - -quite light aesteticals !! damn!! I am still trying to learn how to not set myself on fire!! -its more everything else visually, I think I need to lower down the back of mine some, don't know by how much, the project isn't at my home and I get there and my brain must be going as I keep forgetting what I am supposed to be doing and end up wasting time.........
find the wooden blocks that sit at the rear of the bed and find out how they fit. were they from the 37 as they may be different? what size is the bundy tube for the windscreen wipers, is it 8mm aluminium tube light weight wall? 91031045 - R need a new right caliper thanks got a new left thanks
I would love to see one of these with the grill sectioned a bit and ****ed back behind the leading edges of the front fenders, I don't know why Ford had them stick out so prominently. That being said, the sea-foam green on black wires would be welcome in my home. It looks just as right as you can get.
i measure twelvety times, cant get the oil filter remote in ffs, hits the wishbone, cant turn the engine over - -ffs no one told me there was a top loader mt75 for petrol ford 4 cylinders from a mk5 transit van - -one model specific smiley front van for the 4 cylinders getting one of them then
Cool truck my man, def some hard graft gone in so far. Be careful sharing pics of your engine and transmission combo on here though as they don't comply with board rules.
for me its nothing about the engine its all about the gearbox mk1 transit type 2? stick on left of case mk2 transit type 9 box ?stick on outside of case at the front mk3 transit -pinto type 9 stick on side mt75 diesel box only with factory adaptor to pinto 4 cylinder petrol mk4 transit same as above? mk5 transit gets its own mt75 4 cylinder ford petrol case finally, but needs to be top loading as the pic as the mk5 transit smiley rwd is still a tight cab van / /pickup = transit van specific, to take the 4 cylinder petrol sierra block evolution -- not the pinto block or zetec, transit runs a 8 valve twin cam sierra engine with coil packs on the front mk6 transit mt75 4 cylinder petrol front with transit tail - -engine goes to 2300cc case is the same as the sierra mt75 uses the sierra granada tail mount but uses the transit stick position on the tail - -van body shape and size changes in mk6 mk7 transit all change, engine goes mazda duratec 2300cc - -lpg its why its so confusing as the cc stays the same BUT its a completely different engine and gearbox - -i think it have the box with dual starter locations for petrol and derv - -starter bolts flat to the bell house so you say - -well why dont you go for a mk7 mazda based transit rwd set up... the answer isfor rhd no good as exhaust is drivers side 2 its an aluminium block and the crankshaft girdle is part of te block = =i.e. cross bolted caps -so the crank line to lower sump oil pan area is deep - -toodeep for cross steering - -zetec is the last iron block ford motor.- - intake driver side rhd = =
I don't know how I missed this. FABULOUS!! Where in Lundinium are you?? I have a 35 pickup with some 36 panels and I am in Boston Lincs. Charlie.
See my build thread for how I built lower (higher in frame) rear spring hangers https://www.jalopyjournal.com/forum/threads/quilt-my-40-pu-build.922466/
