Technical Flathead Pre-oiler - Good, Bad and the Ugly?
Discussion in 'The Hokey Ass Message Board' started by Ziggster, Apr 18, 2025.
  1. Ziggster
    Ziggster
    Decided last week to fab up a pre-oiler to use on the first start-up on my C59A. Hoping to start it for the first time in a couple of weeks. Some background. Engine was rebuilt (short block) back in 2019 IIRC. I didn’t get around to doing the final ***embly until 2023-2024. I used Permatex Ultra Slick engine ***embly lube on stuff I ***embled like oil pan pump and cam gear. Has 5 quarts of Lucas 5W-30 Hot Rod oil in the pan.
    Since it’s been sitting for so long, thought it would be a good idea to somehow pre-pressurize the internal p***ages. My understanding with flatheads this is impossible due to the distributor drive config (I put a helmet style on). So, the idea of a pre-oiler. Got this old air tank and modded it. Tank has crude/rust inside so added the Ford style remote oil filter. Now wondering does this make sense. Will the filter trap all the crude inside the tank?
    Stogy likes this.
  2. AmishMike
    AmishMike
    Bought a small cheap ( forget $ ) pump to be driven by hand held drill. Good enough to attach rubber hose in oil pan, outlet into fitting for oil gauge. Let it run for couple minutes, oil everywhere. Easy Peesy & cheap
  3. jaracer
    jaracer
    When I ***emble an engine I make sure everything internal is well oiled, I typically don't use ***embly lube. Before I fire the engine, I remove the spark plugs, dissable the ignition, and crank it over with the starter until I get good oil pressure. Then I put it back together and fire it off. It has always worked for me.
    I should mention that I don't ***emble and engine and let it set for a long time before starting it up.
  4. jaracer
    jaracer
    I do use cam lube on the cam and lifters with flat tappet cams.
  5. Ziggster
    Ziggster
    Stogy likes this.
  6. Joe H
    Joe H
    Was the ***embly lube a grease or a oil? Grease will still be where you put it, oil will be in the pan.
    Stogy likes this.
  7. Jmountainjr
    Jmountainjr
    I have to ask. Why would you consider using something with known crud in it, filter or not, as part of your first start up? Seems like the potential to self sabotage.
    Stogy, Budget36, Toms Dogs and 2 others like this.
  8. Ziggster
    Ziggster
    ***embly lube.
    Stogy likes this.
  9. Ziggster
    Ziggster
    Good question. Impulse decision/buy. Had more crud it in than I expected after I drilled out the casing to add some threaded bosses. Agree, not really the best idea (the bad & ugly). A filter will work down to the micron level, so should be no issues (I hope).
    Stogy likes this.
  10. Ditch that oil tank! Don't sabotage your plan with contaminated components!
    Refer to @AmishMike 's post above.
    Good luck!
    Budget36 likes this.
  11. Joe H
    Joe H
    Plug the oil fill hole and roll it over to coat the insides, that would be a better option then using dirty pre-oiler.
    Tow Truck Tom likes this.
  12. RICH B
    RICH B
    A sbc chev oil pump with a plate & hose on the mounting flange, dipped in a bucket of oil, and spun by a 1/2" drill along with a remote start switch to crank the motor makes a good oiler.
  13. kls50
    kls50
    I bought a Melling M-55 oil pump from O'Rielly's ($40.00) and bent metal brake lines and fittings from the pump to where the oil pressure fitting on the back of the is. I bought a gallon of engine oil and ran a clear plastic hose into the gallon of engine oil to the pump. I pumped the oil from the gallon jug throughout the engine with a cordless drill turning the pump. Search (starting an 8BA after 36 years) Pics included. Hope this helps.
  14. 31 Coupe
    31 Coupe
    X2
    I made my flathead pre-oiler from an old aluminum fire extinguisher tank that holds about 3 quarts of oil.
    Replaced the original top fitting with a custom made, easily removeable, TEE that positions a 1/2" pickup tube close to the bottom that's coupled to a ball valve with a -8 JIC/AN fitting on top for a hose connection to the engine block. Then I ported a Schrader valve into the TEE to charge the unit with air pressure above the oil.
    The aluminum housing is easy to clean out and the oil can also plumbed through a filter if desired.
    RICH B and Ziggster like this.
  15. Ziggster
    Ziggster
    After some reflection, I’ll follow the advice, and start fresh with a clean “pressure tank”. Thinking of this.
    ekimneirbo likes this.
  16. fabricator john
    fabricator john
    from venice fl.
    I did a full build on my flatty then pondered the same thing ,,saw a fella online somewhere do this and it worked for me , went to home depot , bought 20 buck pump up garden sprayer, whacked up the hose and screwed it onto the oil pressure fitting on the block , threw a couple quarts in it and pumped the **** out of it , then waited 20-50 took a few minutes to all get in there but it did the trick , had plenty of lucas ***embly lube on everything , and plenty of cam paste on the cam lifters and valve tips , VH-1 high zinc and a bottle of lucas break in lube , so my only real reason for priming was to fill the oil pump and get the air out of the galleys for the inital hit so oil pressure would come faster , and spun it on no plugs first before firing and made like 50 psi on the starter! , worked like a champ was uncomplicated and cheap !!
    fabricator john
    miss you dad
    Ziggster likes this.
  17. Ziggster
    Ziggster
    I think I’ll do just that. Thanks!
    '28phonebooth likes this.
  18. Ziggster
    Ziggster
    So, picked this thing up yesterday for CAN$25 thinking easy peasy. Been to a couple places and cannot find the correct fitting to attach to the end of the wand. Really don’t want to cut the tube. Nothing I touch is just plug and play…
  19. Ebbsspeed
    Ebbsspeed
    No issues IF you have a filter with no byp***. If the filter has a byp*** and you pump enough crud into the filter, or excess flow into it the byp*** might open and then your cruddy oil is going directly into the engine.
  20. V8 Bob
    V8 Bob
    I cut the end off the wand and used a compression nut and feral. "Easy Peasy"! :)
  21. Ziggster
    Ziggster
    Don’t think the WIX cartridge has a byp***.
  22. Ziggster
    Ziggster
    Thought about that. Problem is the OD of the wand is like 0.412”. Not std.
  23. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Had to edit this because it was for an LS Chevy, but its a cheap way to make a pre-oiler.
  24. Ziggster
    Ziggster
    My Makita cordless drill died this morning, so back into town as today is the last day for a sales promotion at the local fastener place. Found a fitting (female nut) that fit the threads. Says it was for an airbrake system. Decided to get some br*** NPT fittings with a hose barb. Will cut tube if I use this setup and use the br*** ******.
    Will also look further into using the other setup with tank. I’m a little confused since IIRC someone stated that the Ford filter was not full-flow. Not exactly sure what that means. I always thought it was the internal factory oil p***ages that led it to being not a full-flow system.
    Got my hands full with my DD and other OT project right now.
  25. Ziggster
    Ziggster
    So, for $hit$ and giggles, I added about a quart of fresh Mobil 1 5W-30 syn to the HomeDepot sprayer. Was about 60F outside. Pumped it up to about as far as I dared thinking the handle would bend/twist if I continued. Seemed the pressure relief valve was far from popping. Removed the nozzle from the tip of the wand. Oil just squirted out about 3” - 4”. Could hold back the flow no problem with my index finger blocking the opening at the end of the wand. I have no experience priming a freshly built engine, but seems to me that this would have a hard time forcing oil throughout all the p***ages.
  26. fabricator john
    fabricator john
    from venice fl.
    i cut the hose , same one i used
    fabricator john
    miss you dad
  27. Ziggster
    Ziggster
  28. joel
    joel
    I copied V8 Bobs unit and plumbed it into the inlet of the remote oil filter. I also rolled the engine over as I added oil . (no spark plugs) until the pan was up to the mark on the dipstick. I then connected the
    oil pump outlet to the filter inlet and installed the spark plugs and started the engine. 50 psi oil pressure right away.
    V8 Bob and Ziggster like this.
