Projects Bean Runna
Discussion in 'Traditional Hot Rods' started by Duellym, Mar 10, 2025.
  1. Duellym
    Duellym
    Very recently I purchased this
    A 41 ford Tudor. I will tell you all the same thing I told the gentleman I bought the car from when he asked what my goal was I wanted to do with it, drive the **** out of it.
    The car has what looks to me like a 24 stud, and a 3 on the tree. It had one of those Amazon chinesium carburetors on it when I bought it. I immediately yarded that for one of the couple of holley 94s I have laying around. I still need to build the rest of the fuel system from the tank to the pump. Now that it's finally starting to be spring time here in M***achusetts I'm hoping to have that done this week.
    I have many things I want/ need to get done to it to make it roadworthy, I can't say it shocks me considering its 84 years old now. I'll be showing all that here
    Figured I'd start a build thread here, it'll give me more ambition to get the thing done.
    More to come very soon!
  2. Tim
    Tim
    from KCMO
    Cool, look forward to seeing what you do with it!
    Sharpone and Duellym like this.
  3. Speccie
    Speccie
    Great start. Good luck. Hope you checked the antifreeze
    ydopen, Sharpone and Duellym like this.
  4. Duellym
    Duellym
    Thanks!
    Thank you, yeah checking the antifreeze is one of the 1st things I did lol.
    I'm trying to get this running properly now, have redone the fuel system. Someone had run rubber the entire length of the car. I was having this odd issue where it'd intermittently not pull fuel from the tank, I put a see through fuel filter on it and you could watch it pulsate just barely enough fuel to make the thing run, sometimes it would run out of fuel. I have replaced the soft line that was no longer soft with hard line. Now it seems to not pull fuel at all, my guess is maybe the pickup in the tank is no good, or maybe it doesn't like the lack of a gas cap on it.. maybe it's the Chinese fuel pump I am not quite sure.
    For whatever reason too the starter in it was basically falling out of it. I'm impressed that the thing would even crank over, or it didn't chip the teeth off the flywheel lol. Tightened the bolts on the starter problem solved.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Good goin'
    When you get it sorted, enjoy the uniqueness.
  6. Outback
    Outback
    from NE Vic
    Nice find
    ydopen and Duellym like this.
  7. Duellym
    Duellym
    Decided to pull the tank and stop being lazy, may have found part of the issue. Messenger_creation_98D04FA1-EB18-4B57-A671-A6E41792C855.jpg
    Ordered a new tank and sender, should have it this weekend.
  8. Rickybop
    Rickybop
    Awesome. You're gonna have a lot of fun with that car.
  9. RodStRace
    RodStRace
    Just to clarify,
    Fuel systems need to have atmospheric pressure and a vent to be able to pull fuel. Think of it like a hamster water bottle. It would develop a vacuum above the fuel and not run out.
    Lacking a cap won't cause fuel flow issues. Late model stuff will throw a code but still run fine.
  10. Duellym
    Duellym
    Got the new tank and sender installed this weekend, the bean runner is alive, took it for a test cruise up and down my road to check it, I noticed the front tires rub wicked bad, my guess is on the tube shocks someone has installed in the front.
    My car is on 15s, not sure the width of the wheel, with a 235 wide tire on them. I have what i ***ume is the original spare from the car which is a 16 with a 16-6.00 on it, is that what this should use for a stock wheel size?
    Also my next task will be to figure out why I have barely any brake lights when I step on the pedal.
  11. jaracer
    jaracer
    235's are awfully wide for that car. I think 195's or possibly 205's would be much better for clearance.
    Outback, RDR, chryslerfan55 and 2 others like this.
  12. Wanderlust
    Wanderlust
    Check for a clean ground at the taillights and check resistance in the wiring, most likely the wires are green under the insulation and would need to be replaced
    Tim, chryslerfan55, RodStRace and 2 others like this.
  13. Okie Pete
    Okie Pete
    Very cool .
    Duellym likes this.
  14. Squablow
    Squablow
    49 plymouth bumper looks right at home on there.
  15. RodStRace
    RodStRace
    All of this, plus check the interior of the tail light. It's called a reflector and it's probably pretty corroded and dirty.
    chryslerfan55 and Duellym like this.
  16. Duellym
    Duellym
    I definitely agree, I'm definitely changing tire size in at least the front
    Thank you!
    Thanks, that's something I forgot to mention, I put a 49 plymouth bumper on the front of it, the chrome was a lot better than the bumpers that were on the car when I got it, not too sure how I feel about them yet though.
    I definitely will be doing this, probably going to replace the entire harness if I can, my guess so far is that it's the actual switch that is the issue as I do have running lights that are bright enough. The tail lights do work it just barely illuminates the bulb enough to actually see that they are doing anything, gonna have to go at it with the multimeter.
  17. Bigcheese327
    Bigcheese327
    Howdy neighbor,
    6.00-16 is stock for a '41 Ford.
    You probably know this: The '41-'48 Mercury is basically the same car as the Ford. At some point in this period, Mercs started coming with 15-inch wheels and 6.70-15 tires. Coker suggests a 205/75R15 as a replacement for the 6.70-15, if you want to stick with radials.
  18. RDR
    RDR
    Check taillight bulbs. They may have inadvertently switched to 12V on a 6 volt system.
    Nice find on that '41, by the way !
    winduptoy, chryslerfan55 and Duellym like this.
  19. Grumpy ole A
    Grumpy ole A
    That’s a nice buy, congrats. Hope you have found the problem with your brake lights. Does the tail lights work properly? As others have said, ground, proper bulb, is the wiring correct to the socket?
    chryslerfan55, Duellym and Okie Pete like this.
  20. Duellym
    Duellym
    I did not know that I'll definitely look for those, thanks!
    Thank you both! After doing some electrical diag I think the issue is just the harness being old. Got a new harness for it and will be putting it in this week. Hopefully I have it on the road for the Fitchburg airport swap meet this upcoming month.
  21. Cool car-sounds like the guy before you may have also ran the **** out of it. Glad you are getting things mastered and making it your own.
  22. guthriesmith
    guthriesmith
    Very cool and I like your plans for it. I have always liked 41’s. :cool:
  23. Balljoint
    Balljoint
    I like your plan. Driving them is the best way to enjoy them, whether to the grocery store, auto parts store or to work. Even with all their quirks and inconveniences they are more enjoyable than anything new.
  24. Duellym
    Duellym
    Bean machine is on the road. Finially took it for its 1st real drive today. 20250417_192741.jpg 20250417_192752.jpg 20250417_192805.jpg
    I think the car definitely needs a clutch, still need to install the taillight harness in it and redo some brake lines in it. Gonna change all the soft lines in it just for my piece of mind, probably will redo the oil filter lines on it too, simply because I don't like how whoever did it last had done it.
    I have a question for the more experienced than me, would it be easier to pull the trans off the back of the engine with it in the car or should I pull the motor out the front of the car?
    Car makes me very happy overall.
  25. Tim
    Tim
    from KCMO
    Personally I’d pull the front floor out and remove the trans that way
    winduptoy likes this.
  26. Grumpy ole A
    Grumpy ole A
    Does it have a closed driveshaft? If it does, drop the rearmed and pull the transmission.
  27. JayMcJay
    JayMcJay
  28. chiro
    chiro
    ^^^HaHaHaHa
    Andy
  29. Way cool! Good luck with her and thanks for sharing!!
  30. hotrodharry2
    hotrodharry2
    from Michigan
    Congratulations! Nice way to enjoy any cool car! Drive it & change what needs & the things you want. Keeping it on the road while you sort it out.
    Algoma56 likes this.
