Projects 1955 Gasser Build
Discussion in 'The Hokey Ass Message Board' started by jsxtreme, Apr 11, 2025.
  1. Fogger
    Fogger
    I built this one over 60 years ago from a junk yard $125. find. Tube front axle with 12 degrees caster and not a car to be driven on the street. Was NHRA legal for both C and B/gas after I moved the front axle back to correct the wheelbase.
  2. DDDenny
    I don't expect the nose high g***er deal to peak any time soon, as long as the traditional "trend" stays popular, it is refreshing though to see some of the more contemporary build styles, kind of a 70's vibe, somewhat lower while actually being road trip friendly, many times utilizing coilover shocks and dropped round tube axles.
  3. jsxtreme
    jsxtreme
    from Michigan
    Thanks for all of the information guys, I appreciate it. I'll be asking a lot of questions as this is my first "g***er" build.
    To this point, I'm leery of a straight front axle swap at the present time. Two reasons:
    1. I've heard horror stories for drivability if done incorrectly, and I want to drive the hell out of this car on the street every chance I get.
    2. I don't what the geometry needs to look like to be done "right". I'm sure I could learn, but I don't think whatever the first iteration of this car will look like will have one right off the bat.
    At some point someone put taller, heavy duty springs in the front end to get the nose up slightly it looks like, which I have seen in some of the early ones.
  4. swade41
    swade41
    from Buffalo,NY
    You can drive a straight axle, don't be afraid of that, and if you dial the springs and shocks in right they don't ride bad.
    You just have to drive them for what they are, they're not going to take a 30 mph curve at 75 but they'll damn sure go the 30 !
    I drive mine all over
  5. AmishMike
    AmishMike
    Swade41 is right they drive ok with beam axle. But please NO ball joint extensions. I have seen 57 with about 10” extensions, had to be trailer queen, was afraid would fall over standing still. When driven, I moved away did not want to get hurt.
    saltflats likes this.
  6. swade41
    swade41
    from Buffalo,NY
    My buddy's 56 couldn't keep an alignment with the ball joint spacers.
  7. 1971BB427
    1971BB427
    from Oregon
    I've taken my '39 Chev on several 1000+ mile trips. I put an OD trans in it just for that reason. Don't take long trips in my Austin as the 3.73 gears and no OD trans make me not like the high rpm's for long trips.
  8. alumslot
    alumslot
    I have driven mine on a 250 mile round trip and a 180 mile round trip. BBC with 700r4 and 4.10 gear the rear tire is a 31" 65 mile an hour is 1800 rpm.
  9. snoc653
    snoc653
    from Iowa
    What final gear do you have in your 700R4. I have a 700R4 and I thought the final drive is .69 which calculated out to just under 2000 at 65 when I ran the numbers. If locked up drops it down below .69 I'll have to rethink my final gear choice.
  10. alumslot
    alumslot
    The gears in the trans are stock. That is with the lock up on.
  11. 1971BB427
    1971BB427
    from Oregon
    Final drive in 4th OD is I believe .67:1
    Mark Yac likes this.
  12. snoc653
    snoc653
    from Iowa
    From the factory 4th was .69. I used this type of gear/rpm calculator (Calculate RPM for Given Speed(MPH), Rear Gear Ratio, and Trans Gear Ratio) to figure out the no slip rpm at highway speeds and hopefully trap speeds at the track. I don't doubt the RPMs at @alumslot sees, I'm just trying to figure out if I missed something so I can buy parts just once hopefully. With the gear and tire size given in his post, I show 1997.94 RPM at 65. Almost 200 RPM is a lot of difference. I want to make sure I can't be at or over 150 mph thru the traps in 3rd gear which is 1:1 and I don't want the RPM too high or too low cruising down the highway possibly with a small trailer.
  13. AHotRod
    AHotRod
    The way I would build a 100% street G***er style car. Get out the sawzall and open up the rear wheel openings. Leave the factory front suspension in it (as most were done then) and drive the snot out of it.
  14. Dave G in Gansevoort
    from Upstate NY
    I remember one like this from the late 60s, ran a 389 Pontiac with 3 deuces and a 4 speed. Friend of my brother I think. It was scary fast for its day.
  15. snoc653
    snoc653
    from Iowa
    If I go 29s or larger that is the plan. It looks like the 27s will fit in the stock 51 Chevy wheel wells. I don’t want too much tire stick. My safety fuse for the transmission is my tires slipping. I hope.
  16. benchseat4speed
    benchseat4speed
    from Golden, CO
    So if you wanna find out what's 'correct' for your car and plans, buy some old magazines. Popular Hot Rodding is my favorite rag from that era. Any issue from '62-'72ish is solid gold.
    Lots of 5-6-7 Chevy stuff from about '64-'70.
    Hot Rod from that era is meh. I have a few, but there's lots of fluff in Hot Rod. Motorcycles and go karts and dune buggies and ****.
    Some .02 on your other questions, I have a 55 with stock front suspension, and a 56 with an axle up front. They both ride like ****. I put the axle under the 56 when I was 20. Just seemed like a good idea at the time. Lotta work, minimal gain. Looks cool, that's about it.
    I'd keep the stock coil spring front end under your car. Keep it simple.
  17. jsxtreme
    jsxtreme
    from Michigan
    Love the '55, legit using that as inspiration and a goal of where I'd like to end up. I am going to keep it simple for now. I'm sure like with my other '55 I'll be constantly changing things, but for the first iteration I'm going to leave it as is.
    Appreciate all the input, everyone. Almost done with my street car, should be able to start on it this month.
    Just Gary and benchseat4speed like this.
  18. Robert Pierce
    Robert Pierce
    IMG_1645.jpeg IMG_0729.jpeg Before and after. Kept the stock front suspension and added ball joint spacers. No drivability issues.
  19. jsxtreme
    jsxtreme
    from Michigan
    Well, I ordered so many parts yesterday I'm surprised the bank didn't shut my card off. Getting rolling on it soon.
    Factory fuel tank, factory sending unit, OE fuel lines, OE brake lines, petronix ignition system, and a lot of other misc. parts. I figure I will get a lot of it plumbed and sorted before it goes to the paint shop.
  20. Lloyd's paint & glass
    Here's the skinny, if you're wanting a bad*** hot rod that you have to actually drive, then build it, if you're wanting a nice driving, air conditioned, power steering, power windows, sweet radio setup, then build a street rod. I'm a hot rod guy, but every straight axle car I've built rides and drives great. Like swade said, no they don't road race well, but they're not built for that.
    sidewayzz69, Thor1, mad mikey and 4 others like this.
  21. brigrat
    brigrat
    from Wa.St.
    Put a '91 GM, 4L80E, manual shift in that Henery and never look back! Made My Willy's a hole new animal over the GM 400.................................
    mad mikey and porkshop like this.
  22. seb fontana
    seb fontana
    from ct
    ^^Close^^ View attachment 6413938
    I just realised in the 1st pic it is grainy enough that can't see that I have tilt nose.
  23. alumslot
    alumslot
    My 700r4 is full manual. Yea very eazy on the hiway.
    brigrat likes this.
  24. willys54
    willys54
    Real G***er's are straight axle with 3 pedals on the floor. Anything thing else is a Hot Rod.
    benchseat4speed and Fogger like this.
  25. Todd553
    Todd553
    Most "Real G***ers" weren't 3 pedals. They ran Hydros. Including, SWC, Big John, Ohio George, etc, etc, etc. Not sure where the 3 pedal g***er thing started.
  26. AmishMike
    AmishMike
    Todd553 right about auto g***ers - quicker & less driveline maint/repair. SEGA south east g***er great group & racing requires manual trans
    Algoma56, Thor1 and mad mikey like this.
  27. bobss396
    bobss396
    The hydros were a natural thing since they were behind many donor engines. You used what was cheap and plentiful. Then worked on making them reliable.
  28. benchseat4speed
    benchseat4speed
    from Golden, CO
    Thanks buddy. Glad to hear you already maxed out a credit card on it!! Lol that's how it all starts. If you dig mine, you'll dig these too. These are where my inspiration came from. There was a great writeup on this 'Big Stan Johnson' 55 in Hot Rod Deluxe in the 2010's as well but I can't find that magazine right now. 'It's around here somewhere':rolleyes:
    This was the other one. Sadly, I don't think any of the absolutely cl***ic photos in this thread made it to the present day. I hope you have better luck with em. I just see red X's. This is the car @Fogger built.
    https://www.jalopyjournal.com/forum/threads/1955-chevy-g***er-white-lightnin.306408/
    jsxtreme, catdad49 and Just Gary like this.
  29. Todd553
    Todd553
    So these two aren't Real G***ers? Thanks for the history lesson genius. images.jpeg
  30. HOTRODNORSKIE
    HOTRODNORSKIE
    My 62 fairlane is as real as it gets the build was started in 64 and finished about a year later. It has a full stock interior the only race safety is some lap belts and a drive loop. The car had a Hollman Moody 390 backed by a toploader econoline straight axile and home made latter bars ,fender well headers. The nasty as cam was removed in 77 when my brother owned it replaced with a Crain solid. The car was sold ad sat for 30 plus years block was replaced as it was cracked then I bought it. It was raced from about 65 to the very early 70s. 20240511_131140.jpg 20240511_131102.jpg 20210731_150836.jpg
