Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. snoc653
    snoc653
    from Iowa
    It’s an 11,000 lb 2 post. DMS is out of Missouri I think.
    Tickety Boo, enloe, Sharpone and 4 others like this.
  2. RMcCulley
    RMcCulley
    Was working on the rear end (Ford 9")
    Shaft seals started leaking.
    When I pulled the axles they looked like they had a coating of glitter on them.
    Ordered new bearings.
    Pulled the 3rd member out and took it in to have it gone through.
    Cleaned out the housing.
    Following day our 2 year old daughter was diagnosed with B Cell Acute Lymphoblastic Leukemia.
    It seems like we have been in and out of Childrens hospital in the last 3 weeks than at home . Got re-admitted this afternoon.
    Killing time right now while she sleeps...
    The plan is to get everything ****oned up on the car because she always wants to sit in the car and she loves going for rides around the block.
    No joke, if I take her into the garage she will point and say hotrod, then she points again and wants to sit in the car, honk the horn, she tells me to sit down... then she give me a look like "why aren't we moving yet"
    Squablow, sixty3, shanejgass and 12 others like this.
  3. Oneball
    Oneball
    Hope she gets better soon, she sounds well educated, in a blink of an eye she’ll be driving and doing all the stupid things you used to do!!
  4. brading
    brading
    Wishing your daughter all the best with her diagnosis. May she spend many more years be under your feet pestering you to let her help.
  5. Prayers for your daughter....
  6. impala4speed
    impala4speed
    Feeling sad about your little 2 year old daughter. But I'm hoping, and praying, that she will be well very soon.
  7. alanp561
    alanp561
    More on the Fenton headers. I've gone back looking at posts that others have made about these on a '48, and I've not seen any reference to a clearance problem at the back of the header on the driver's side. The only way I can see to get a header pipe connected is to cut out the top of the opening in the frame where the stock pipe would have gone. Am I missing something here or is removing part of the frame the only way to get it done. The part needing removal is circled in yellow.
    View from inside of the frame looking forward.
    From the inside of the frame looking out.
    Tickety Boo, saltflats and Sharpone like this.
  8. Paul
    Paul
    Editor
    my grandson was diagnosed at two,
    two years heavy treatment
    two years light
    now six years old free and clear and catching up with normal life.
    you can beat this thing and you are not alone.
    rod1, Squablow, das858 and 12 others like this.
  9. Sharpone
    Sharpone
    Oh man my heart hurts for you and your daughter. Hang in there and stay positive. I’m praying for ya brother!
    Dan
  10. snoc653
    snoc653
    from Iowa
    My heart goes out to anyone going through those types of medical issues. It really puts things in perspective when I'm whining about help not showing up. Having children or grandchildren that would give anything to be there and can't because of something out of their control is way worse than them being healthy and strong and wanting to do something else. Especially when the thing preventing them from being there puts them in danger. I'll keep your granddaughter in my prayers.
  11. Stock Racer
    Stock Racer
    Wishing your daughter a fast and full recovery.
  12. 123
    123
    from Seattle
    Rescue mission! Today was the first time in 15+ years it has seen the daylight.
    20250426_091710.jpg 20250426_091959.jpg 20250426_093824.jpg 20250426_094906.jpg 20250426_095652.jpg 20250426_111904.jpg 20250426_113105.jpg
  13. RMcCulley
    RMcCulley
    Thank you
    shanejgass and Sharpone like this.
  14. RMcCulley
    RMcCulley
    Thank you all for the kind words
  15. dana barlow
    dana barlow
    from Miami Fla.
    Update from # 5123.
    Sometimes the little things turn into big headache; The intake home made/partly, thermostat housing,has started leaking,no matter what I seem to do. Now tryed fix 4 times,still leaking;just in in top now vs 1st 3 times was bottom.
    So going to have to do some welding. To get gasket match up each side/all around to hold. One of those thing that worked fine for years,now it dose not. Will the 5th try work? we'll see. Got 6 mile away from home.before it started leaking on 4 try. o_O:confused:
    mad mikey, loudbang, Sharpone and 3 others like this.
  16. Stay with it, Dana. Persistence got you this far and patience will take you across the finish line.
  17. choptop40
    choptop40
    DeSoto gauge panel stripped to bare aluminum..gauges test fitted for last time...Next .the rest of the dash..Steering column for mockup only.. PXL_20250427_005936988.jpg PXL_20250427_005915740.jpg
    shanejgass, enloe, 4 pedals and 5 others like this.
  18. flynbrian48
    flynbrian48
    Finally got real carpet in the roadster and covered the holes in the floor and firewall that heated up the ****pit. F912B91E-043D-42BE-BB83-CD95F58C3DE3.jpeg BC37CC93-9CD3-466E-AEA1-076249A6DA9E.jpeg
  19. Sharpone
    Sharpone
    I’m betting you’ll win the 5th round with a knockout!
    Dan
    alanp561, dana barlow and mad mikey like this.
  20. enloe
    enloe
    from east , tn.
    Got to get all of this into this fortunately I’m off work tomorrow image.jpg image.jpg
  21. shanejgass
    shanejgass
    Prayers are with you and your family. Keep moving forward.
    Sharpone and RMcCulley like this.
  22. jeepster
    jeepster
    from wisconsin
    Installing door gl***
    rod1, porkshop, enloe and 8 others like this.
  23. Robdski
    Robdski
    Final ***embly started on the front end.
    Engine and transmission in so I can piece together the exhaust system. They will come out one more time, so I can run the fuel and brake lines. IMG_3655.jpeg
  24. sixty3
    sixty3
    from Erie, Pa.
    Prayers for your family!
    porkshop, Sharpone and RMcCulley like this.
  25. atch
    atch
    Checking fluids and everything else in Clarence preparing for the trip to SK-500 this coming weekend.
  26. deathrowdave
    deathrowdave
    from NKy
    ***mins oil cooler and oil filer housing gaskets
  27. I’ve done more than a few of those!
  28. norms30a
    norms30a
  29. Worlds slowest engine ***embly
    Picked up these old lifters yesterday. NOS bulk lifters from Rocco and Cheaters
    Slicked em up and slid em in
  30. atch
    atch
    1937, 1955, and 1956: best lookin' trucks Chevrolet ever made; imho. I'd love to snag a '55 or '56 for a DD pickup.
