Hot Rods 1939 Transmission crack, Salvageable?
Discussion in 'The Hokey Ass Message Board' started by Airborne34, Apr 26, 2025.
  1. Airborne34
    Airborne34
    from Texas
    I picked up a 1939 Ford Transmission case, 78-7006 in a parts lot. It’s an actual 1939 with a *18-4685152*
    It has a crack and broken bolt boss. What do you think, repair, build or s****.
    image5.jpeg image7.jpeg image4.jpeg image3.jpeg image2.jpeg image2.jpeg image1.jpeg
  2. alchemy
    alchemy
    S****. A nice one can usually be found for under $50 at many swap meets. Any case from 36-ish to the 53 pickups is the same. The myth that the rib on the bottom makes them much stronger is blown out of proportion.
    warbird1, bschwoeble, Fogger and 4 others like this.
  3. Mr48chev
    I've got to go with Alchemy on that one, there are too many good cases floating around for reasonable prices to want to put time, money or effort into repairing that on a hope it works deal.
    Airborne34 likes this.
  4. oldsmobum
    oldsmobum
    from SoCal
    It might be neat to practice cast iron welding techniques on, but all the pro’s I’ve asked about that have always said don’t bother. The risks of cracking again after make the effort of rebuilding it into a transmission a potential lost cause, and the cost per inch to s***ch cast iron is “adult money” as my buddy would say.
  5. rusty valley
    rusty valley
    Cracks in cast iron will keep creeping longer. Drill a hole to stop that, then weld, bla bla...all a waste of time get rid of it, they are not that rare
    bschwoeble and Airborne34 like this.
  6. Mac VP
    Mac VP
    Pretty sure I see two cracks in the front bearing retainer opening, plus the major chunk of casting broken off one of the bolt holes for the shifter housing. These are just the flaws I see in the pictures….
    Good 78 series cases can still be found, and in most situations you can use a good 48 series case for a rebuild. Your time is better spent with another case. We’ve s****ped out better examples than this one.
    Toms Dogs, warbird1, skip65 and 4 others like this.
  7. Your time, effort, and money are better spent elsewhere. Plus the work of R & R when you find out that the crack / leaks are still there.
    Airborne34 and bschwoeble like this.
  8. I'd fix it only because I enjoy fiddling around with junk. Practically speaking, as others have said, it's a lost cause.
