Technical Good Zinc Oil - Rotella T4
Discussion in 'The Hokey Ass Message Board' started by Voh, Apr 27, 2025.
  1. Voh
    Voh
    Anyone running the Rotells T4 for their older flat tappet motors? I believe it has enough zinc, but asking for other input.
  2. rockable
    rockable
    Use VR1 or Brad Penn or some other oil made for gasoline engines that has zinc.
  3. Define older
    Ben
    bobss396 and Adriatic Machine like this.
  4. Voh
    Voh
    1964 SBC 283.
  5. 1biggun
    1biggun
    Sharpone likes this.
  6. mad mikey
    mad mikey
    I know lots of guys running Rotella in flat tappet cam hot rods. Its good oil, no issues. The owner of the shop I work at even runs it in his older ford explorer, and now it does not burn near as much oil.
  7. alchemy
    alchemy
    I use it in my flathead. Some oil changes I even throw in a bit of that zinc additive, even though some guys say it’s not necessary after the engine is broken in.
    winduptoy likes this.
  8. Oh no
    Oil thread
    ( I use it. So far so good)
    Whisper mode.
  9. JD Miller
    JD Miller
    Delo is better
  10. AldeanFan
    AldeanFan
    I run Kirkland synthetic 5w30 and a bottle of hyperlube zinc additive in my y block.
    bondojunkie and Sharpone like this.
  11. I always recommend using oil
    Oil is good
  12. Jack E/NJ
    Jack E/NJ
    from NJ
    > >Rotella T4 > > believe it has enough zinc, but asking for other input.
    I believe calamine lotion has even more zinc.
    slayer and winduptoy like this.
  13. tubman
    tubman
    Why are you asking this? Rotella is formulated for diesel engines, not car engines. By coincidence, it may have adequate zinc, but what about all of the other ingredients? They may be included in the formulation in a way that is harmful to spark ignition engines. As to zinc, do you have any idea of the zinc content of the current version of Rotella that is now on the dealers shelves? You should at least check the API rating on the container and find out the zinc content of what you are actually buying, certainly not what someone told you 6 years ago. If diesel oil is anything like regular automotive oil, zinc content has been greatly reduced over the last few years.
    And to those of you who are complaining about "another oil thread" it will probably continue for as long as some stubborn people insist on using the wrong oil in their cars.
  14. tubman
    tubman
    It very well may be; I wouldn't know. However, your statement is meaningless as neither is suited for automotive use. You should not be using it in your Hot Rod as there better choices in the vast array car oil available. If your hot rod has a ***mins turbo diesel, you can disregard this advice.
    ydopen, egads, lemondana and 3 others like this.
  15. oldsmobum
    oldsmobum
    from SoCal
    This was brought up in the last week or so. Please use the search feature/google.
    Adriatic Machine and Sharpone like this.
  16. Sharpone
    Sharpone
    Question - If you use diesel oil in your crank case do need to use diesel fuel in your tank? Just kidding.
    Why use diesel oil in a flat tappet cam engine when there is oil made specifically for these engines? I don’t understand.
    Dan
    ydopen and Driver50x like this.
  17. Bugguts
    Bugguts
    Like my father in law used to say, “ any oil is better than no oil.”
    ps... I run it in one of mine.
  18. I’m out. Ugh!!!!
  19. Sharpone
    Sharpone
    You’ll be back
  20. Diesel oil will damage spark plugs
    That’s why it’s designed for diesels
    I ran gas oil in my diesel tractor and spun a glow plug
  21. patsurf
    patsurf
  22. pprather
    pprather
    winduptoy, 2OLD2FAST and Sharpone like this.
  23. Onemansjunk
    Onemansjunk
    from Modesto,CA
    FEBDCE90-B984-4FDE-933C-B9367802821A.jpeg E35CA4DA-D2FD-4DFE-B0E5-3A3AB2B6F7FE.jpeg You’d have to be “CRAZY “, to run that stuff in your engine!
  24. tjm73
    tjm73
  25. pecker head
    pecker head
    IMG_6350.jpeg 61 283 came out of 72000 mile car, been running it for the last 4 years.
  26. jimmy six
    jimmy six
    Lucas Hot Rod…..everything needed for our flat tappet engines. If you don’t drive much 1000 miles a year …change any oil you use every year!
  27. AldeanFan
    AldeanFan
    Rotella has a cool name, like a pasta or some type of tasty cheese.
    It’s also easier to find and cheaper than hotrod or racing oil.
    I’ve personally never seen a confirmed case of damage to a gasoline engine that can be attributed to using diesel oil.
    Often we hear stories like “my used engine that I don’t know the history of threw a rod shortly after I started using diesel oil” or “the engine in my hotrod was knocking and diesel oil didn’t make it better”.
    These prove nothing against diesel oil.
    however there are many people that have used diesel oil in gasoline engines with no problems reported.
    The only advice I will follow is from my engine builder. If it’s a used engine or a used car either use the factory recommended oil or take your chances.
    Sharpone and CSPIDY like this.
  28. Joe H
    Joe H
    How much lift and valve spring pressure you have determines how much additive you need.
    My 250 has a stock cam with stock valve springs so it gets standard 10w30 synthetic , been that way for 24 years now.
    Sharpone and winduptoy like this.
  29. Jack E/NJ
    Jack E/NJ
    from NJ
    Yet another link to the diesel oil conspiracy theory being peddled by that funny-looking funny-talking nerd again. Gotta be sorta weird yourself to believe a guy who thinks, talks & looks like him. Doncha think?
    seabeecmc and Blues4U like this.
  30. I’m no scientist but years of my independent testing has concluded that oil is good
