Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. SR100
    SR100
    The pic is pretty fuzzy, but it looks like the club plaque is from the Hi-Domers:
  2. Tim
    Tim
    from KCMO
    I’d say that’s a solid ***umption! Good find
    41 GMC K-18, winduptoy and Six Ball like this.
  3. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As promised, I hit the garage right after work. First, I installed the new low-profile zerk and slipped the steering arm back into position. After mocking everything up, I realized that I had almost forgotten the grease shield. Luckily it was close by. I had to modify it to allow the socket to clear. Once I did that, I broke out the torque wrench and tightened it to spec.
    (Grease shield not pictured here, but this gives the general idea.)
  4. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    With that ****oned up, I was able to install the wheels with the new tires.
    Apologies for the poor lighting. From what I can tell, the new tires are slightly taller and slightly skinnier than the rollers. It’ll be interesting to see how it sits with an engine full of oil and a radiator full of water. I will say this—Version 2.0 has never been easier to roll.
  5. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    There’s more to share, but that’ll be tomorrow. Feels great to be back out there!
  6. Tim
    Tim
    from KCMO
  7. When I first saw this, I thought it was @Anderson's old T hotrod with some (further) tweaks and changes.
  8. Excellent progress Joey!! Your attention to detail is amazing. You have methodically thought through each piece and part carefully when most of us are just trying to get our cars put together. You have way more patience than most of us.
    Can't wait to see it running down the streets of SF!!
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you so much, Brian! I love the process of piecing everything together. I wouldn't consider myself a patient person, but it is something that I have been working on. Won't be long before the cotter pins make their way on to the car!
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    As I work on this car, I'm realizing that the biggest thing that's missing is time. With that in mind, I dedicated this afternoon to checking boxes.
    Elsewhere in this thread I've mentioned the limitations of my shop space here at the house. Being on a cul-de-sac where all of our buildings are ****ed up against each other, I work to be respectful with power tool usage. Sometimes, however, things just have to get finished. I brought a bunch of pieces out to the back porch to cut and grind away.
    For today's first project, I wanted to finish my anti-chatter rod bracket. I had actually started this earlier in the week, but it needed some finessing (even though it will be 100 percent hidden beneath the floor).
    Due to the location of the 1939 Ford pedals, I had to re-route the rod. The new layout is inspired by early 1940s Ford rods that mounted to the top of the frame. IMG_9022.jpg
    Keeping it very simple.
    Nothing too crazy, but it accomplishes the task at hand.
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The next order of business was fitting the ignition wire tubes to the intake manifold. For whatever reason, the tabs didn't line up with the ones on the intake. Most would cut and re-braze, but that wasn't in the cards for me. Instead, I whipped up a pair of relocating tabs out of some thin aluminum that spent most of its life in the form of a Petaluma street sign. IMG_9082-1.jpg
    I love the CAD. Note the vintage scissors.
    Taking this to heart in more ways than one.
    Dunlap x Vise-Grip makes for a great combo.
    Drilling on the planter box on an old deck board.
    Fin. Once they get some miles, they'll fit right in.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Although they may seem small, it's these little odds and ends that will make this car more solid in the long run. For the day's grand finale, Yama joined the fun. The task? Setting up the emergency brake.
    IMG_9091.jpg The job was fairly straightforward thanks to the @Dennis Lacy kit. While we were at it, we also torqued the backing plate bolts to spec.
    Unfortunately, we discovered one of the long bolts had been damaged. I tried chasing the threads, but I wasn't happy with them. Does anyone out there have a single one of these long bolts that the could sell me?
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    That aside, I'm super excited to have a functional E-brake in the car. I've ordered a '32 pawl that will bring the lever down an inch, but other than that it's good to go. A huge step forward.
    It's incredible to see this view as I remember how far we've come. And if you'd like to watch the new E-brake in action, check out our video here.
  14. winduptoy
    winduptoy
    Joey,
    you have a rod on your Rod now
    and, having learned the hard way...I won't drive a car without a functioning e brake...
    stellar accomplishments in all your details
    carry on
    Outback, 41 GMC K-18, drdave and 3 others like this.
  15. Malcolm
    Malcolm
    from Nebraska
    Great to see your progress!
  16. trad27
    trad27
    If you don't find one closer I might have one if this is the one you need?
  17. Tim
    Tim
    from KCMO
    Man your soooooo close
  18. trevorsworth
    trevorsworth
    Your self control & methodical approach is gonna pay off... this car will be a legend.
  19. Robdski
    Robdski
    Super clean fabrication. You have come a long way.
  20. warbird1
    warbird1
    Yes! What he ^^^ said!
    Robdski, Six Ball, winduptoy and 2 others like this.
  21. BigJoeArt
    BigJoeArt
    There's a reason for that. @Anderson building his T on here was what made me want an early T roadster.
    Outback, Six Ball, shanejgass and 4 others like this.
  22. BigJoeArt
    BigJoeArt
    Good work as usual other Joey.
    as fun as it is to watch you solve problems with what you have, it makes me want to gift you a welder and a plasma cutter. :D:D
    did you cut this out by drilling a series of holes in a line?
    your patience knows no bounds buddy.
    getting mighty close!
    enloe, Six Ball, shanejgass and 3 others like this.
  23. trevorsworth
    trevorsworth
    A time honored method! That's how I did the radius on my AV8 transmission mount. Drill baby drill...
  24. Tim
    Tim
    from KCMO
    I thought the same but I think it’s edge marks from a cut off wheel in a grinder.
    the problem is the electricity of the building. Maybe what he really needs is one of the new electric generators/ battery packs. Plug your welder in and you got it made
    Six Ball, winduptoy and 41 GMC K-18 like this.
  25. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Hey Joey, as ever, I love the great shots, close up of various elements in your shop and the cool vintage things that often appear.
    So yes indeed, the vintage scissors caught my eye, because I have a pair that are very similar, the brand is "KLEENCUT" as you can see on my pair.
    I have had these for decades and they still cut very precisely!
    You are making great progress there at the
    "LOYOLA TERRACE, LTD MANUFACTURING FACILITY"
    Keep at it young road warrior!
    Thanks from Dennis.
    Six Ball and winduptoy like this.
  26. Tim
    Tim
    from KCMO
    Little California roadster action for inspiration ;)
    winduptoy, Outback, Six Ball and 4 others like this.
  27. RodStRace
    RodStRace
    Fantastic video! Love to see them moving more than just sitting.
    Gotta say that I realize parking in LA is get it when you can, but that bus should not have been parked there blocking the view out of the lot for everyone.
    bob b. likes this.
  28. Tim
    Tim
    from KCMO
    Yeah I think that’s why they had one or two people in the street most of the time watching.
  29. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I have a couple of minutes before I call it a night, so I figured I'd keep the ball rolling. I'll try to get around to replies tomorrow; thank you all for your patience.
    The other night as I was bolting down the intake, I noticed one of the bolts was having an alignment issue. Knowing how important it is to take my time on these things, I slept on it. Then, yesterday, I approached it with fresh eyes.
    First, I unbolted the intake.
    Using a rattail file, I enlarged the bolt hole ever so slightly. With a little finessing, it all went back together. I then tightened everything to spec.
  30. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    My reward for getting the intake torqued down? Chrome acorn covers. Acorns that gave me grief were given a small tap with an even smaller geological hammer (that we once used to split geodes).
    I have a lot of great things to say about many suppliers here on this thread, but I was pretty disappointed with Speedway's packaging. IMG_9109.jpg
    Does every acorn really need its own individual bag? They need to do better—especially during Earth Month!
