Projects 1950 Ford Business Coupe build
Discussion in 'Traditional Customs' started by SinisterSleds, Apr 29, 2025.
  1. SinisterSleds
    SinisterSleds
    from MA
    All right, here it goes.
    Was gifted a 1950 Ford business coupe project a year ago.
    These were a few pics from the 90s
  2. SinisterSleds
    SinisterSleds
    from MA
    Over the years it had been dis***embled stripped and primered. The rockers had been replaced as had the lower 1/4s. Not great work but I decided to leave it as is.
    Also sitting in it was a small block chevy and trans along with a Jamco front end.
    I pulled the engine an transmission, sprayed the firewall and engine and front frame. I then dropped it all back in. 20240912_070621.jpg
  3. Fat47
    Fat47
    Go on, you've got my attention.
  4. SinisterSleds
    SinisterSleds
    from MA
    Once the engine and trans were back in I painted and added sound deadening to the floor, roof and firewall.
    I had heard the car was left outside in primer on occasion over the last 20ish years of storage so I decided to tackle the main body.
    As i expected under the primer on the flat surfaces I found rust under the epoxy.
    I stripped the roof and 1/4s back to the filler in the rear 1/4s. I could tell from the inside that the 1/4s had some sub par repairs. This however is a budget job and I know if I stripped the 1/4s I would end up making new ones. This would also lead to chopping and sectioning and turning it into a long term build I'm not prepared for. I stripped a little of the bondo back in s few places and the metal under it looked clean.
    A few coats of Ospho and it was into epoxy. 20240913_071351.jpg 20240913_123030.jpg
  5. bschwoeble
    bschwoeble
    I'm surprised that some people, who don't understand the term "hot rodding", and what it used to mean, aren't complaining about a Chevy in a Ford.
  6. SinisterSleds
    SinisterSleds
    from MA
    I chased a few spots blocked the epoxy with 180 and spyayed a coat of high build primer.
    Blocked the high build with 180 quickly followed by guide coat and blocked with 320.
    I only intended to epoxy the car and spray the jambs especially since it was windy and raining but I got carried away and ended up spraying the roof and 1/4s as well. It is a solid dark blue Aston Martin color from the 50s (3 coats single stage color, 3 coats with color/clear mix) The car was then tucked away for the winter.
  7. SinisterSleds
    SinisterSleds
    from MA
    Next I cleaned up the engine sheet metal.
    Sand blasted, ospho, fix rust holes or cracks, seal with epoxy, paint and install.
  8. SinisterSleds
    SinisterSleds
    from MA
    I pulled the dash out of storage.
    Made a frame to hold it. I stripped it and painted it with a Dodge color called Cool Vanilla.
    I also decided a nice touch would be custom knobs made of laminated plexigl***. Further I added a 2" tach where the clock would be.
    The knobs required layered plexigl*** clamped ever 2 pieces. This was made int a block. The block was then milled square. The ***embly was then placed in a 4 jaw chuck and a round end turned on it. I could then place it in a collet chuck and turn the rest of the piece.
    Once round the knobs could be turned from that blank.
    The dash is currently out for pinstripe.
  9. SinisterSleds
    SinisterSleds
    from MA
    With the dash done the only other panel I has was the trunk.
    I decided to shave it.
    Under the primer I of course found rust.
  10. SinisterSleds
    SinisterSleds
    from MA
    I delt with the rust by treating it with ospho.
    Cut out the inner so I could metal finish the license plate fill patch and painted epoxy on the trunk. 20250330_123356.jpg 20250331_163424.jpg
  11. SinisterSleds
    SinisterSleds
    from MA
    Tim, Deutscher, Barn Hunter and 10 others like this.
  12. SinisterSleds
    SinisterSleds
    from MA
    Next on the chopping block was the doors.
    Shaved the lock and added Fiat door handles. The door handles required fabricating a new ush ****on and means of actuation the latch. I will modify the latch later. 20250427_061144.jpg
    Lepus, Deutscher, 49ratfink and 8 others like this.
  13. '49 Ford Coupe
    '49 Ford Coupe
    Plus you've been up since 4:00 this morning! ???
    How about a quick outline for the finished product?
  14. SinisterSleds
    SinisterSleds
    from MA
    Yea! 4 AM is the usual.
    Lounge, clean up, feed and walk dog, coffee, get to the shop, don't get enough done, leave between 5-8pm.
    Overall, what you see. Blue with white engine bay, pleated are-51128012400_xl.jpg white interior. Hopefully the mags I have well fit or I'll have to get some new rears.
    Pics below. Just a cruiser.
  15. In_The_Pink
    In_The_Pink
    Great color choice. :)
    SinisterSleds likes this.
  16. HOTRODPRIMER
    HOTRODPRIMER
    Looks good, gotta love a '50 coupe. HRP
  17. evintho
    evintho
    Looking good! Great build!
  18. Grandadeo
    Grandadeo
    I'm following for sure!
  19. Rand Man
    Rand Man
    Looks like you’re getting off to a great start. Gotta love the coupes.
  20. Rickybop
    Rickybop
    Excellent.
    I love an old business coupe.
    I like your section by section approach.
    Now let me ask...
    You were finding rust under the primer. Was it epoxy primer or polyester? I think you said epoxy? I thought epoxy primer doesn't allow rust to form. Maybe it was there when the primer was applied.
    F-ONE and SinisterSleds like this.
  21. Bidness coupes make my wee wee tingle!
  22. SinisterSleds
    SinisterSleds
    from MA
    Epoxy was applied by another shop probably in the 90s. As the car waited to be worked on by various shops it often sat outside. My guess is it was a combination of factors. Old rust not properly removed and moisture getting through the epoxy when left in the elements. I use epoxy as a place holder after metal finishing but would not trust if to hold out long exposure to moisture. In a shop I wouldn't worry.
    ****! maybe I should change this to a for sale ad. Lol
    Moondog13, '28phonebooth and Rickybop like this.
  23. pprather
    pprather
    Nice work and great progress.
    Subscribed.
  24. lostn51
    lostn51
    from Tennessee
    The way I look at it as long as it gets back on the road and is being enjoyed who cares what is powering it. Heck if I could get my grandkids under the hood to peddle the thing down the road I’d do that:D:D:D
    Moondog13 and SinisterSleds like this.
  25. lostn51
    lostn51
    from Tennessee
    I’m wanting to put a set of these on my 51 woody but polished. I love these wheels!!!
    Moondog13, pprather and SinisterSleds like this.
  26. SinisterSleds
    SinisterSleds
    from MA
    Someone could complain if they wanted but I'm not redoing work I don't have to. I'd like a 4-5 speed, but I'm not going through the effort on this build, the set up is the set up. If I really like the car and my wife agreed (she is a bit afraid of the 390, 4 speed AMX) I can always swap in a 4 speed later but Im building something she is willing to jump in and drive.
    Sealed the doors with epoxy after blocking the high build on Monday night, painted them yesterday. Quick buff this AM and installed the door handle. Then modified the latch. I'll take it home tonight.
  27. Fat47
    Fat47
    Following this build now. Agree, there's no point in getting into areas that will push the road use back several years. Keep at it.
    sammyb, F-ONE, Toms Dogs and 2 others like this.
  28. SinisterSleds
    SinisterSleds
    from MA
    Agreed. The 350 was installed. I would have liked an old flat head but the chevy makes it more usable but adds difficulty in installation. Stock manifolds (still need to figure out the left on (hopefully 80s chevy truck will work).
    I would have considered putting in the 5.0 5 speed I had for a Galaxy 500 project, that died before completion, but I sold it a year or 2 ago.
  29. SinisterSleds
    SinisterSleds
    from MA
    Buffed the 2nd door and put a coat of epoxy on a couple bumper fillers. 20250430_174430.jpg 20250430_182539.jpg 20250430_182543.jpg
  30. F-ONE
    F-ONE
    from Alabama
    The “some people” are people of the land....
    You know.....
    *****s.
