Technical Flathead carb gasket
Discussion in 'Traditional Hot Rods' started by cammer8, Apr 29, 2025.
  1. cammer8
    cammer8
    I have a two barrel carb on my 1934 ford flathead V-8. My question is, what is the small hole on the 2 barrel gasket used for? It's located on the gasket right behind the two openings for the barrels. The bottom of my carburetor has no provision for such hole. Thanks in advance for any answers.
  2. tubman
    tubman
    I know there is a good reason, but since I'm an "8BA guy", I've forgotten it. If no answer here, try "The Ford Barn".
  3. 4barrel Harold
    4barrel Harold
    Most carburetor kits come with extra gaskets. A Ford-Holley-and Stromberg can have the same bolt pattern. I usually have a correct carburetor gasket or needle and seat for vintage carbs if needed.
  4. Speccie
    Speccie
    Doesn't the power valve get it's vacuum for said little hole?
