Hot Rods A one of a kind stock 1929 Ford 3 door delivery???
Discussion in 'The Hokey Ass Message Board' started by chrisp, Feb 13, 2024.
  1. chrisp
    chrisp
    Also the pictures are of poor quality and very hard to decipher it really is just the name :
    parisian ute
    2 doors, 4 windows.
    Inner dimensions from the seat to the tailgate : 1.325 m, height : 1.200 m, width : 1.300 m.
    tailgate width :1 m
    for the 4 doors 6 windows:
    Inner dimensions from the front seat to the tailgate : 1.500 m, height : 1.220 m, width : 1.340 m.
    tailgate width :1 m
    For the stake bed truck it says :
    Closed cab with dropsides stake bed on a (I think) 1200kg ch***is
    For the trucks it says:
    Paris - tractor picks up your ch***is at the Ford Asnières factory and lengthen your frame.
    The factory frame stays unmolested, uncut, undrilled.
    chryslerfan55 and The37Kid like this.
  2. If you download Google Translate to your phone, you can use the camera to translate literature. Just hold the camera over the text, and it will translate it.
    chryslerfan55 and tb33anda3rd like this.
  3. Stogy
    Stogy
    Pretty darn cool and the research also awesome as well...It certainly has a shop truck or tour vehicle potential about it. I just noticed 2 drs on the p***enger side. I thought it was 2 front drs and the rear.
  4. chrisp
    chrisp
    That's what I thought when I bought it, I didn't think there was a rear seat either since I bought it sight unseen.
  5. chrisp
    chrisp
    Today I found out that the '29 front bumper I ordered for another car was mispackaged and I received a '30/'31 instead with the '29 clamps. Since I can't return it, I decided to mock it up to see what it looks like on the delivery.
    What do you guys think?
    While I was at it I installed the dropped headlight bar that I bought for my RPU that I won't be using because of the '32 grille and the '32 headlights I will maybe be using for the RPU.
    Since I had that Bentley fog light laying around for years I also mocked it up on the modified original Ford headlight bar for the heck of it.
  6. Hitchhiker
    Hitchhiker
    Id be tempted to swap an American size A motor in and call it done!
    Really cool car. Thanks for sharing
  7. chrisp
    chrisp
    That's the goal, I have the engine, but gearbox and rear end are geared for the small engine. I can solve the rear end with a Matford rear end I have and I have a set of proper ring and pinion. But the box is a problem. Early Ford 3 speed or top loader are impossible to find, T5 are now very expensive, US versions are near impossible to find here. But SSangyong used them, are relatively easy to find and cheap but I don't know the gearing nor the bolt pattern.
    I don't want to work or invest on it yet, I have other cars to finish first.
  8. chrisp
    chrisp
    Since I have parts laying around from a trade deal I made about 10 years ago for a project that will maybe never see the light of day and have some duplicate parts I thought : why not use them on a very real car?
    A 4" dropped 46" front axle that I suspect came from speedway, unfortunately a monoleaf that is 3/4" too short from speedway, aftermarket and model A spring perches, stainless steel spring shackles, '46 ford wishbone, '33 ford spindles, a model A tie rod and a selection of '28/'34 tie rod end plus a wishbone splitting kit from CTaulbert .
    I started by restoring the tie rod ends, sand blasting and gun blueing of what was not worn out.
    Shortening and straightening of the tie rod, I even reinserted the metal slug found originaly inside the threaded end.
    Modification of the shackles to suit that stupid monoleaf.
    Modification of the spring perches
    At first I wanted to keep the eye for the mecanical brakes because I noticed that a lot of old build didn't remove them but upon mockup I found out that the steering arm was hitting.
    Almost all ***embled
    I still need to ream the new spindle bushings and get a couple of tie rod balls.
    A view of the now dropped steering arms.
    I need to finish the shackles, but shall l paint them or polish them?
    chryslerfan55, bymanr and The37Kid like this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    Sure they had water pumps. HRP
    chryslerfan55, chrisp and The37Kid like this.
  10. treb11
    treb11
  11. chrisp
    chrisp
    I'm leaning toward the M47 from the 740 or 960 I don't remember.
    I didn't really like the flat shackles, I wanted something more original looking so I cut down 3 worn out A shackles and brazed them onto the ones I made to fit that stupid Speedway spring.
    They're thicker than original ones, but under the fender it won't be noticeable.
    On a side note I found out that on the French ford, on the '28 the grease fittings are those big br*** ones that are pressed in, I don't know if it's the same on US fords and on the '29 the zerk fittings are metric thread while the castle nuts don't have a cut down head where the cotter pin goes in and the 9/16" socket is nearly impossible to get on while the 14mm fits like a glove despite the thread being UNF.
    I wonder if it's a French ford thing : imperial thread with metric heads. I had those in multiple places on my '28 and on my Simca flathead.
    Only one old mecanic told me about this saying it was so everybody could work on them without needing to buy new sets of tools, but that also led some mecanics to destroy threads by forcing metric nuts and bolts on them, or "cleaning" the threads with metric tap and dies.
    chryslerfan55 and hfh like this.
  12. chrisp
    chrisp
    Yesterday I picked up a set of front '36-'38 Matford V8-72 drums, dimension wise they are identical to the '37 and up Ford.
    Visualy they're different because of the fins.
    On the inside they have those swearly reinforcement ribs
    I'm ***uming those are the same on the UK Ford Pilot, maybe they can be found on other earlier EU Ford also but I have no info. But they do fit the '33 Ford spindles with the spacer.
  13. shorrock
    shorrock
    I have a SSangYong box in my blown 34. I can send you some pics if you need info.
    chryslerfan55 and chrisp like this.
  14. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I am thinking a funeral parlor "flower car"?
    X-cpe, chryslerfan55 and SS327 like this.
  15. chrisp
    chrisp
    We're talking about the t5 right?
    I'm very curious about the bolt pattern, is it the same as Chevy ?
    Do you run a close drive?
    Is that the long or short version ?
    Finally what kind of gearing did they use if you know ?
    I'd like some pictures yes but in pm because it's not traditional at all.
  16. chrisp
    chrisp
    I don't think that kind of car did exist in France or flower cars for that matter.
    From what I gathered the original owner was a farmer. I could take a 2h drive to check the archives if they survived the war. Maybe someday if I have the time.
  17. shorrock
    shorrock
    I´ll take a couple pics tomorrow and send your way. I made just a plate between SYbox and french clutch bellhousing. Put an S10 chevy rear housing on the box for relocating the shifter and made a bronze bush for the output yoke. The splines are different on the in- and output shafts so I used a SY clutch and a Nissan RX yoke as it has the same splines for the now open driveshaft . Rear axle is a Chevy with 3,03 ratio. Have to look for the box gearing, could be found on the net as well. OD is 0,82 if I recall correctly. When I added a blower the SY clutch at 9,5" could not hold above 3500 so I converted the french 11" clutch to the SY splines.
  18. shorrock
    shorrock
    PM did not work:
    Here are pics of the SY gearbox. The french bellhousing is aluminium, ****** end housing is Chevy.
  19. shorrock
    shorrock
    SY clutch needs a spacer ring with 18mm height to get correct tension on the spring. No problems as the splines on mainshaft are long enough to accomodate. Clutch did hold my normally aspirated flathead, was easy to use and absolutely no chatter. It is used in the 2.9 ltr Diesel engine so can stand some torque. Made a spacer for the SY Throwout bearing and checked function when ***embled without oilpan.
    chryslerfan55, chrisp and RICH B like this.
  20. chrisp
    chrisp
    I received parts last week for the RPU but there were some for the delivery also.
    I broke the piggy bank and bought a reamer.
    So easy to do the bushings, That allowed me to finish ***embling the front end.
    When I get the time I'll ***emble and detail the boling Bros brakes and clean up the matford drumsand it'll be ready to go on the car.
    I thought that was cool same ref but stamped Matford :
    Unfortunately the big ones spun, Despite the roller being good I'll have to replace them all.
    On a side note in '36 the Matford logo became MatFord.
    Since I bought some bling for the body I thought why not install it so it looks pretty, lets start with the easiest : the mirrors.
    Well it turns out the hinges are different : they're 3.5mm taller and use a 5mm pin. Some stainless steel that I polished, a little bit of lathe work.
    Stupid amount of time for a bolt on mirror, I'm not sure I want to install 2 of them now.
    So for now it's only one.
    Shinny grille shell, correct year bumper.
    I still have no clue of what was the use for that hole under the windshield, it's factory, not something done later.
    chryslerfan55 and 34 GAZ like this.
  21. chrisp
    chrisp
    I found out some small details :
    outside door handles look like Ford roadster but the left one is locking. Kinda look like Citroën B14 too.
    Window crank handle appear to be Peugeot 201/301/401 from 1929.
    Inner door handles are Citroën B14/C4/C6.
    Unknown pull handles.
    Still can't figure out the door latches but they are similar in design and function as the MGA but way smaller.
    I also found a picture online of the original owner who was a farmer and a WWI vet and came into contact with his great grandson in law (if it can be call like this) who's gonna ask the original owner grandson if he's got some history on this car.
    The rear fenders are handmade but the shape is very different from the Ford ones I find them pretty ugly even if they fit perfectly, but there are no wire edge, no bodyline on the edge, no reinforcements inside and are squarish.
    Off they go.
    Since I have a descent pair of sedan rear fenders, after some modifications, they fit perfect and are much more beautiful.
    Since I don't have the original tail light that was fitted next to the license plate I will use repro Ford ones without license plate light because the license plate is a backlit plastic that is mounted on a panel below the body. I also replaced one bulb holder to have a 2 filament bulb for turn signals in them separate from the brake lights.
    I placed a flashlight inside the license plate light box to kind of show what it looks like, I don't know if it ever was a thing in the US, but in France there were quite a few cars with this fancy feature in the late 20's to the 30's.
    I will look into mounting original Ford rear bumpers with an original bracket.
    I like the fancy bumpers that came with the car but they don't match the front one, plus the modified Citroën brackets are bolted on the wood subrails not the ch***is, I don't like the idea.
  22. chrisp
    chrisp
    I got time to swap the I-beam, it's pretty low.
    Here's what it looks like with a 6.00-16 tire, in the end it will get 5.50-16 black wall tires, that will give me a little over 2" clearence between the tire and the fender brace.
    I blasted, painted and replaced all the bearing and seals on the Matford drums
    The jack stands are set to simulate a 5.50-16 tire to visualize the ride height, now I can set the rear ride height so I'll be able to pie cut the front bones and set the caster.
    That will be the final ride height.
    I will need to replace the hoops on the beaded Madford wheels, so I'll be able to mount regular tires on them.
    Did Ford ever had beaded wide five wheels? I'm just curious to know if it's a Matford V8-60 only thing, since it seems the bigger ones had "normal" wheels.
  23. I,ve had a few Matford V8-60 cars but not with those rims. Could they be from Chenard & Walcker or Mathis ?
  24. chrisp
    chrisp
    Good catch, Mathis was gone in '35 so they never had wide fives, but Chenard in '36 when they received the Chausson body (the manufacturer of the Matford bodies) did have it seems wide five wheels, I found only 1 picture of a '36 Chenard with plainly visible wheels and indeed it's beadlock, but it has only 13 slots and the holes seems a little bit bigger unless I'm mistaken.
    From '37 it appears they don't have wide fives anymore.
    But the small '36 V8-72 Matford :
    My wheels.
  25. chrisp
    chrisp
    I have a couple of questions.
    First one for the banjo experts : what do you think of this surface?
    Is it too scarred to use? If so is there a way to fix that because it's not like we can find those used or new over here, it has to come from the US.
    I bought a cheap Ssangyong T5 with fried electronics.
    I contemplated the idea of a torque tube conversion but I came across a cheap S10 tail housing and a cheap mislabeled S10 output shaft.
    My second question is : does anybody have the refs of the WC T5 bearings? I looked up and couldn't find anything, I don't remember them in the T5 post either. I don't know if I need them, but if I do I'd like to avoid the importation.
    A feature that seems pretty useful on this WC T5 is the speedo gear and sensor that originaly resides on the transfer case.
    It's electric but has a mecanical gear, it looks like it can be used to convert an electric speedo T5 to mecanical, those gears sell for €35 new, I found them in the US sold for the Magnum Tremec for $95 to convert them to mecanical speedo.
  26. Petejoe
    Petejoe
    from Zoar, Ohio
    Way too cool. What a find.
    The hole under the windshield is a place to slide a rifle barrel through. :)
