Projects 1949 Mercury barnfind resurrection
Discussion in 'Traditional Customs' started by MercMan64, Dec 5, 2023.
  1. Doctor Detroit
    Doctor Detroit
    Nice job, looks like a fun one. I'll look for it at AutoRama.
  2. Squablow
    Squablow
    Looks like it's cleaning up nice. If your blanket seat covers move around on you a lot when you drive the car, straighten out some coat hangers, weave them into the blanket around the front, back and sides where it tucks under the seat frame, and hog ring them into place just like the factory seat covers. It's a way to get them good and tight and they will stay put that way.
  3. MercMan64
    MercMan64
    from Taylor mi
    The car got a great response at the show, still having engine troubles, thinking about pulling the heads and intake again and pulling all the valves and cleaning them up IMG_4643.jpeg IMG_4646.jpeg IMG_4666.jpeg
  4. guthriesmith
    guthriesmith
    Yep, looked good and great hanging out with you over the weekend! Here are a couple of the pics I got of your car. I still can’t believe the deal you got on it… :D
  5. Awesome car man done a great job getting it back on the road .
  6. MercMan64
    MercMan64
    from Taylor mi
    Jeff it was great to meet you! I was definitely happy with how it turned out for the show.
    guthriesmith likes this.
  7. MercMan64
    MercMan64
    from Taylor mi
    I’ve been spending a little more time with the merc here the last couple of weekends. The number 3 cylinder never did free up and I found that the number 6 cylinder was very low on compression. The carburetor was also on its way out. Jerry and I pulled the heads off last weekend and started digging into my compression issue. 3 bent valves and a burnt valve ended up being our issue. We picked up a handful of valves, copper head gaskets and a stromburg 97 from an old timer in Detroit Monday. We lashed the valves and freshened up the seats and got the new valves installed. Cylinder heads and a stock 8ba intake went on, we replaced the stock 8cm intake to something that’s a little more user friendly. Taking the generator to have it tested this week, hopefully come next Saturday I may get a good first test drive without it back firing from both ends! IMG_4789.jpeg IMG_4793.jpeg IMG_4723.jpeg
  8. MercMan64
    MercMan64
    from Taylor mi
    Progress is moving along, I haven’t had much time to post here recently with yet another new job. We purchased a rebuilt genuine stromburg 97 which we installed on a late model truck intake. We found out quickly that a standard 97 just isn’t enough fuel for the 255. With a lack of funds currently to put a dual carb intake and a second 97 on the car, we rebuilt the Holley 94 off of the truck intake with great success! We ended up sealing throttle pedals and she’s finally a driver! I took my first test drive with the 94. It tosses both belts… order a set, get those installed. Finally it seems good. I installed a new voltage regulator and it finally charges. It seems like I’m getting pretty close to finally having it dependable. Took it to greenfield village for its second car show this weekend, looks like it’s time for a set of water pumps and thermostats. Leaving the show this evening, mind you we had 90 degree weather today, the car did overheat. I’ve been told I should start with water pumps. Does anyone have any insight on what I should purchase? I see speedway sells a set but it’s not a perfect fit. Shoebox central sells a set but only for 50-51. Can anyone explain the difference between a 49 ford to a 49 mercury? IMG_5357.jpeg IMG_5349.jpeg IMG_5377.jpeg
  9. Okie Pete
    Okie Pete
  10. Squablow
    Squablow
    The Mercury water pumps put the motor mounts in a different position than the Ford ones do, that's why hot rodders using the Mercury engine swap the pumps out for Ford ones (please correct me if I'm wrong, I often am) so if you order new Ford pumps they'll fit on the engine but the motor mounts won't line up anymore.
    I don't know your car well enough to say, and I'm sure some others here will have different stories and opinions, but in my experience, every overheating flathead issue (and most old car overheating issues) was tracked back to a ****ty old radiator. Sure it might not leak, but when they get old, they lose a lot of cooling capacity due to buildup inside or whatever.
    The new aluminum radiators you can buy are not very attractive in an old car, but they do cool with incredible efficiency, and they're pretty damn cheap. What are you running for a radiator?
  11. Old-Soul
    Old-Soul
    Put a known good mechanical temp gauge on first to see what your engine is reading.
    On my '49 ford I did a lot of head scratching and ****ing around trying to solve my perceived "hot engine" woes only to find it was a bad sender reading much hotter than the engine truly was.
    Try Shay @ Pre60's Auto Supply (just north of you across the bother) he may have some merc pumps for you.
    rodncustomdreams and Just Gary like this.
  12. MercMan64
    MercMan64
    from Taylor mi
    Currently it’s still has its original radiator, the price on those aluminum ones are definitely in the right direction. I spent a little time with it today changing thermostats, I put a set of 180’s in it. Didn’t really notice a difference in how “quickly” the gauges read hot. It dude puke a bunch of coolant all over my driveway. I’ve been looking at mechanical gauges also just to verify but moneys still tight here. Everything’s in the cart but the funds
  13. MercMan64
    MercMan64
    from Taylor mi
    IMG_5748.jpeg IMG_5747.jpeg Also scored a set of bubble skirts today. They have the right look but I’ve got too many doors
  14. Smokeshow
    Smokeshow
    Looks like you are taking the old girl in the right direction! You have taken it along way in just a short time.
  15. I dig those skirts!!!
    Maybe @anthony myrick can chime in with some suggestions on the skirts on a four door.
    anthony myrick likes this.
  16. guthriesmith
    guthriesmith
    Just need to tell everyone they can’t use the back doors. :D I like the look of those skirts on it. :cool:
    LCGarage, williebill and Okie Pete like this.
  17. tubman
    tubman
    Regarding 8BA era water pumps.. Basically, there are three different mounting options (Mercury, Ford Car, and Ford truck) and a choice of wide or narrow belts. Here's how they line up :
    1949 Ford cars - wide belt, Ford car mount.
    1950-1953 Ford cards - narrow belts, Ford car mount
    1949 Mercury - wide belt, Mercury mount
    1950-1951 Mercury - narrow belts, Mercury mount
    1952-1953 Mercury - narrow belts, Ford car mount
    1948-1952 Trucks - wide belt, Ford truck mounts (same s '37-'48)
    1953 truck - a weird combination I have no experience with
    All pumps bolt to the block the same. Early Mercury and Ford truck pumps use "mounting ears", but the Mercs are higher than the trucks. This means you can use Merc pumps in a truck with spacers, but not truck pumps in a Merc (without drastically screwing up the engine position). Ford cars mount completely differently on the bottom of the pump. I have heard some folks make strap steel adapters to allow them to use Ford car pumps in other vehicles, but I have never seen or done it.
    No one else has mentioned it, so I will. If you use a stock 8BA series distributor, you must use a stock matching carb (either the Merc Holley 885 or a Ford 94). During this period, Ford use a unique, all vacuum advance system called a "Load-A-Matic". It has no mechanical advance mechanism and needs a special vacuum signal from a port located in the middle of the rear of the carb. The reason the 97 didn't work well is not because it was too small, but because you had no way to advance the timing. If you change the carburetion on these, you have to change the distributor to one with a normal advance mechanism. A converted SBC distributor works fine as well as certain aftermarket units (Mallory, etc.). In my opinion, the best carburetion for a set up like this is a Rochester small base 2G on the Mercury manifold. The carb will bolt right on, but the throttle bores in the manifold need to be bored out to 1 7/16". One last hint : If you mount the 2G backwards, it makes installing it much easier, and the carb doesn't seem to mind at all.
    I have to disagree about those skirts.:(
  18. Yea. Cut em
  19. Okie Pete
    Okie Pete
    I like the shirts . Maybe attach them to the rear doors and cut them at the door gap ?
  20. MercMan64
    MercMan64
    from Taylor mi
    This is really good information, I’m sure I could pick up a set of 50-51 merc pump. I wonder how hard it would be to swap pulleys or if it would be easier to swap the crank pulley?
    I’m not sold on the skirts myself but I couldn’t beat the price
  21. tubman
    tubman
    Has anyone mentioned "Skip" Haney in this thread yet? He is the "Go To Guy" for flathead water pumps. He specializes in the earlier pumps, (mainly because they need more help), but I know he does the later pumps. I'm sure he could rebuild yours (unless they are completely shot), which may be the solution to your water pump problems. I'm sure he could swap pulleys as well. They're kinda delicate, so don't try to do it yourself without the proper tools and knowledge.
    A wanted ad on this forum can produce some good results (I just scored an aluminum Canadian Merc intake manifold for a decent price.) And as always, keep looking on the various online marketplaces (eBay, Facebook, Craig's List, etc.). Going to swap meets is kinda fun, too. With a car that complete, I wouldn't start throwing a lot of incorrect parts at it just yet.
    Deutscher and Okie Pete like this.
  22. MercMan64
    MercMan64
    from Taylor mi
    Haven’t heard anything from skip, but I’ve seen his name pop up in other threads
  23. LCGarage
    LCGarage
    I love your 4 door Merc, and the skirts too. I like the idea of cutting the skirts on the door opening. Once they are color matched they would look great!
    Okie Pete likes this.
  24. LSJUNIPER
    LSJUNIPER
    from ct
    [​IMG] I SEND MY WATER PUMPS HERE FOR REBUILDING. WELL WORTH IT, YOUR CAR WILL RUN COOLER WITH SKIPS REBUILT PUMPS.
  25. MercMan64
    MercMan64
    from Taylor mi
    Slow progress is better than no progress, decided last week I was going to break down and order an aftermarket radiator for the merc. While the parts were in the mail I went and snagged a flush kit from the local auto parts store and drained the radiator. Yesterday I pulled the radiator out of th car, no wonder it wasn’t cooling, half the fins were smashed. Checked out the insides of the water pumps without removing them also and they looked decent. I drove the car for the first time yesterday in over a month more than 5 miles without any sort of issue overheating. It runs about 3/4 temp on the gauge but with a temp gun shows 185-195 on the head. Sorta thinking I should have put a 160 thermostat in it instead of the 180s. IMG_6034.jpeg IMG_6025.jpeg IMG_6024.jpeg 76872F1A-E927-4F29-8A8F-4D77061402D9.jpeg IMG_6028.jpeg
  26. MercMan64
    MercMan64
    from Taylor mi
    I suppose the next venture i plan to tackle is exhaust. Been doing some reading on here about manifold/headers. But nothing about fitment, I’ve heard the original fenton’s fit perfect but the repops don’t. However when comparing photos they look identical. I’ve got a buddy who swears by the redd’s but the fenton’s are more my budget. Any insight? The p***enger manifold has a decent sized hole that pushing exhaust fumes into the fresh air box that’s desperately in need of a new seal, so all i get I fumes in the car while driving IMG_5753.jpeg
    Deutscher, Okie Pete and LCGarage like this.
  27. MercMan64
    MercMan64
    from Taylor mi
    IMG_7171.jpeg I’ve been slowly plugging along on this thing as spring is finally starting to show its face here in metro Detroit. The car did the Detroit autorama once again, this time I scrambled to throw a set of lake pipes 4 days before move in. I had a small scare when the drivers rear flew open on the drive into the show. I let it sit for a few weeks before throwing a set of Aerostar coils on the front. Talk about a difference in right height! And in the last two weeks the biggest milestone, insurance and hopefully soon, registration! I’ve got a set of reds headers on the way and an induction heater to hopefully make the removal of manifolds go as smooth as possible. I may actually get to enjoy the car this summer! Once this thing is finally dialed I may finally get around to some long awaited maintenance my Thunderbird is looking for IMG_7166.jpeg IMG_7291.jpeg IMG_7490.jpeg IMG_7491.jpeg
  28. MercMan64
    MercMan64
    from Taylor mi
    Once again slowly making progress on the car, my headers finally showed up from red’s after about a 3 month wait. I immediately took them to get ceramic coated. Once the headers came back I started to pull the manifolds. I purchased an induction heater to aid with the removal of the bolts however ended up with 5 broken bolts. Luckily the bolts broke flush with the manifolds instead of the block. With about 6 hours with of work I slowly removed each broken bolt, cleaned the threads in the block and installed the headers. The car is going Thursday for exhaust, I m still contemplating keeping the lake pipes but I’m not sold on it yet IMG_7923.jpeg IMG_7924.jpeg IMG_7941.jpeg IMG_7952.jpeg IMG_7958.jpeg
  29. 50 Merc Man
    50 Merc Man
    Can I ask where you got the plaque holder from? Or did you make it yourself?
  30. MercMan64
    MercMan64
    from Taylor mi
    I made it myself, I used a couple pieces of aluminum flat stock, bent feet on them, then set them in the package tray to get my height. I will say I lowered the front after doing this and now my plaque is a little harder to see. I’m currently waiting for a club restock so this one can be put back on my comet and I can make some adjustments with a new one
    guthriesmith and Okie Pete like this.
