Technical Advice on oem power steering for ‘63 impala
Discussion in 'Traditional Hot Rods' started by Eth727, Apr 30, 2025.
  1. Eth727
    Eth727
    Hey guys I’d like some advice about an oem factory steering setup I just bought used off eBay. My car is a standard steering 63 impala. I recently bought the whole power steering system (gear box,pump,valve,etc).
    Everything is used and the operational status is unknown. Originally I was going to rebuild each component but what if they work fine. How can I tell before installation. The components have surface rust but aren’t greasy and leaking so I guess that’s good. What would you guys do if you were in my shoes? Thanks
  2. jaracer
    jaracer
    I think I'd replace the hoses as they look a bit suspect in the picture. I'm not sure that the steering gear is any different between standard and power steering. If the box you currently have is okay, I wouldn't replace it, just the rest of the linkage.
  3. gary macdonald
    gary macdonald
    Its easy enough to install to check . Do you have the pump ? The lines should be replaced and the idler arm .
    The pump and mount bracket for your motor is important along with the correct pulleys and fan belt .
  4. 37gas
    37gas
    Any of those X frame car if you buy a power steering kit you will need to replace the radiator . the power steering is bigger and interferes with the radiator. So I would look at the slave cylinder and see if it can be rebuilt and get new hoses
    RICH B likes this.
  5. Eth727
    Eth727
    This is an original gm power steering setup off a ‘60 impala . Why would the radiator need to be replaced? From my understanding standard gear boxes where different from PS ones
    gimpyshotrods likes this.
  6. gary macdonald
    gary macdonald
    I’m pretty sure the ratios are going to be different.
    seb fontana and Crazy Steve like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, a friend of mine just did this exact thing on his 59. the steering gears are a different ratio, go ahead and change it. I would change out the hoses and give it a try. did you get the pump and brackets and all the pulleys that are needed?
  8. Eth727
    Eth727
    Yeah the hoses are trash. I do need a double groove crank pulley. It makes you wonder why would someone remove a part if there isn’t anything wrong with it.
    I recently bought a Muncie ****** that looked like hell and the guy didn’t know its working status. I was going to rebuild it before installing it but decided to roll the dice and see if it works. After cleaning it up i installed it and it runs great no issues. I’m hoping the same with this P/S system
  9. MAD MIKE
    MAD MIKE
    from 94577
    If you do have the pump, rebuild it yourself using the $10 Sunsong or Edelmann kits with bushing.
    $150 rebuilt units from the local parts house always seem to have something wrong, have found vanes installed wrong more than a few times.
    Not sure if the $200 resto catalog pumps are any better.
    You'll need the pulley tool either way.
  10. Kerrynzl
    Kerrynzl
    They usually throw out the power steering ram system and upgrade to a later Saginaw power steering box [which is better]
    29Sleeper and seb fontana like this.
  11. Kerrynzl
    Kerrynzl
  12. vtwhead
    vtwhead
    ^^^^^^ did this on my 64. worked great but, then learned I needed a new radiator with a notch in it to allow the new steering box location and length.
  13. Eth727
    Eth727
    Was your steering box from a ‘60?
  14. vtwhead
    vtwhead
    No, the steering package came with a newer ps box which IIRC was a Saginaw
  15. Eth727
    Eth727
    Yeah thats why I wanted an original one so I wouldn’t have any fitment issues. Thanks for sharing that.
  16. Eth727
    Eth727
  17. 29Sleeper
    29Sleeper
    from SoCal
    Or hide the power steering from an electric car under the dash and enjoy an uncluttered engine bay.
  18. Kerrynzl
    Kerrynzl
    Make sure you use the pitman that matches the power steering center link [it should be slightly deeper to allow for the pindle valve ***embly]
    If not the Pindle valve leans one direction.
    The reason a Saginaw box is better is purely because the Pindle valve [spool] is on the column so it is more accurate due to mechanical gearing [16:1 +]
    You can make power rams more stable with altered allignment specs and radial tyres.[you need to "soften" the predictability]
    You want as much caster as possible.
    Slight positive camber
    Slight toe-in
    If you use modern negative camber specs the car will dart all over the place [due to freeplay in the Pindle valve directly affecting the steering angles]
  19. Kerrynzl
    Kerrynzl
    That is what I would do [but there is bit of engineering involved]
    You vulture the column and controller from a Prius
    Note : this doesn't quicken the steering ratio
