Technical ***May 2025 Banger Meet Thread - May Flowers Bring Allergies***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 1, 2025.
  1. Jiminy
    Jiminy
    Link to previous month: April 2025 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    Deutscher likes this.
  2. denis4x4
    denis4x4
    from Colorado
  3. wuga
    wuga
    Me too!
    Warren
  4. 62pan
    62pan
    Still here
  5. GuyW
    GuyW
    Races this weekend at Barona raceway in Sandy Eggo county
    51 mercules likes this.
  6. Kevin Pharis
    Kevin Pharis
    from Califunny
    I’m here! Well… in Bakersfield for the swap tomorrow. Stop by, space #172
  7. Stovebolt
    Stovebolt
    Coming up to the end of hot rod season out here
    Outback likes this.
  8. 51 mercules
    51 mercules
    I'll be there!
    GuyW and Outback like this.
  9. Outback
    Outback
    from NE Vic
    Still here, hoping to make some progress in the coming months
  10. Dedsoto
    Dedsoto
    from Australia
    Just picked up this B trans for my roadster, hope to use it behind the B banger, will this trans bolt to the A flywheel housing or will I need to use the B housing and fab engine mounts? I understand I'll need to make pedal, wishbone and handbrake mounts. It's also missing the shifter, will any stick from 32-36 work?
    Outback likes this.
  11. Midnight Rider
    Midnight Rider
    from Australia
    Here now, after returning from over there. Good times.
  12. Not too much to report. With researching Frontenac stuff, I managed to escape to the garage to tinker for a bit!
    s.e.charles, Outback, burl and 2 others like this.
  13. Planning on some sump baffling this week. Other than that, just been out and about. Played a couple of gigs at a charity event yesterday. Beers, Bikes & Bands. Double b*** fits in the Fordor so I started the Model A Sedan parking lineup… IMG_6864.jpeg IMG_6876.jpeg IMG_6857.jpeg
  14. wuga
    wuga
    You lead a charmed life!
    Warren
    winduptoy and hotrodfil like this.
  15. 5280A2
    5280A2
    Dedsoto, GuyW and 62pan like this.
  16. Dan from Oakland
    Dan from Oakland
    And if you use a B pan, you will need to make up a filler piece or splice in a chunk of A pan to seal around the rear main cap, as the B cap seal surface is larger than the A rear cap sealing surface. Not hard to do, just be aware.
    Dedsoto, winduptoy and 51 mercules like this.
  17. alchemy
    alchemy
    One old fella told me it’s easier to remove the back half of a B pan and weld that on the original A pan. Said it should fit on. Then you don’t need to worry about the sealing surfaces. I haven’t tried it yet.
    Outback likes this.
  18. 5280A2
    5280A2
    I'm reposting this because it was buried in the Quote when I posted it yesterday. As far as adding the B rear flange to an A pan I have looked at it both ways and the shape of the A pan is quite different in the rear. I think fabricating the filler piece is an easier direction.
    You will need to use the B flywheel housing and a B oil pan in order to use the B transmission with an A block. The flywheel housing is a bolt on, but the pan and the block need a couple of modifications. First, you need to resolve the difference in how the pan seals against the rear main bearing cap. The B crank journals and cap are larger than the A so when you test fit the B pan to the A block you will find a significant gap that needs to be filled on the B pan. The filler piece needs to be made so that it will seal against the cork strip on the rear main cap when the pan is bolted on.
    Second, you need to fill the two pan bolt holes in the rear bulkhead of the A block. If these aren't filled you will get lots of oil moving from the sump into the flywheel housing and you and your clutch don't want that. While you're at it, the B pan has two mounting holes in the rear corners that you won't find in your A block, so you need to drill and tap holes to match the B pan in order to seal it along the rear of the block. This photo shows the block with the new hole tapped in the rear corner, and with the bolt hole for the A pan filled. The gray spot is JB Weld placed over a cut off bolt that's installed by sawing a slot in it to allow you to screw it into place just below the machined surface of the block, File the JB Weld flush with the surrounding gasket surface. When you install the pan with a B pan gasket you will find it's a little short where it is supposed to fit up against the main cap. If you use the paper style (not cork) gasket you can easily compensate for that with your favorite silicon gasket sealing or making product.
    Now all you have to do is build motor and frame mounts, brackets to hold the pedals, a new clutch release shaft and an emergency brake bracket. These parts are all available but can be fabricated in a home shop too. You are right about the shifter, any 32-36 with the short bottom.
    Airborne34, jet996, Outback and 3 others like this.
  19. winduptoy
    winduptoy
    checking in
    just returned from a 1400 mile round trip to the Stray Kat 500 in Dewey, Oklahoma
    no problems for the banger Vicky
    I've been soaking the suspension springs with diesel/transmission fluid mix
    man, did it improve the ride
  20. burl
    burl
    from Minnesota
    I have got nothing to show for work on my modified last month but i did score this pretty cool part last weekend
    The37Kid, s.e.charles, 5280A2 and 8 others like this.
  21. Finally figured out this distributor and got the engine to fire off temporarily! Time to run a fuel line, install a gasket/bolt kit, and let her eat! IMG_0620.jpeg
    jet996, G Baese, Outback and 3 others like this.
  22. hotrodA
    hotrodA
    Anybody have hands-on experience rebuilding one of these water pumps?
    A friend in Nashville has one on a recently purchased coupe, but hasn’t seen one before.
    Experienced banger guy with a complete shop, but was looking for tips before tearing it down.
    Is it a sealed bearing held in with a snap ring or press fit?
    Thanks!
    Outback likes this.
  23. Take a look for V8 pumps diagrams
    J
    winduptoy likes this.
  24. Crazydaddyo
    Crazydaddyo
    I think that is a Norm Frick water pump. I've used one, but never had one apart. I think it is based on a 32- 36 21 stud V-8 water pump
    Outback and winduptoy like this.
  25. hotrodA
    hotrodA
    Thanks! Yes, Norm Frick built the head.
  26. The37Kid
    The37Kid
    Just listed this in the Antiquated section. Has anyone worked on one of these?
    winduptoy and Outback like this.
  27. Bigcheese327
    Bigcheese327
    Would that be the 9N/2N tractor engine and its stablemate used in '41 pickups?
  28. The37Kid
    The37Kid
    Judging by the photos the size of the bellhousing makes me think it is a Truck engine. They must mention "Vehicle" in the text.
    Bob
    Bigcheese327 likes this.
  29. Savage Coupe
    Savage Coupe
    from Washington
    IMG_0315.png IMG_0308.jpeg Does anyone recognize these rods? I can barely make out the letters HAL on the side of them.
    winduptoy, jet996 and Outback like this.
  30. Outback
    Outback
    from NE Vic
    HAL made a variety of engines and parts, hadn't heard of Rods unless they were repurposed from one of their engine's?
    Savage Coupe likes this.
