Technical No mechanical timing advance
Discussion in 'The Hokey Ass Message Board' started by 05snopro440, May 2, 2025.
  1. 05snopro440
    05snopro440
    Hey guys,
    My question is related to an HEI on a 455 Buick but I figure timing is timing :).
    Checking the timing with a new good quality timing light, I'm getting the same advance from 600 to 2,600 rpm. It seems as though I'm getting no mechanical advance. After the discovery I recurved the distributor with an MSD medium setup (picture below), same result of no change through the range. Other than trying the heavy and light springs, I'm at a total loss.
    The weights move freely under the cap and the advance moves freely. I have tried three weight/spring setups now with the same result. Balancer is new, cap and rotor are new, coil and contact are new. The distributor and guts are new with less than 1,000 km.
    Could there be something wrong with the pickup coil?
    I'm at a loss. Thoughts would be great.
    It spins clockwise, same as a SBC. The second photo below is the weights before I recurved it.
    kadillackid likes this.
  2. Kevin Ardinger
    Kevin Ardinger
    I could be crazy, but I think the weights are on it backwards. If it spins clockwise, those weights are not gonna be very prone to sling out. I think. It looks like a reman distributor as the parts look like they’ve been sandblasted.
  3. Mr48chev
    The pickup coil moves with the vacuum advance.
    Distributor advance is not one of my high knowledge things but I have seen some GM distributors with the back side of the advance weights worn to the point where they want to hang up and not move right. That was on one with hundreds of thousands of miles though. That chart is pretty explicit in that you don't get the advance with the heavy springs that you do with the lighter springs.
  4. rockable
    rockable
    It looks like one of the weights is sitting on top of the other and that would keep the advance mechanism from working.
  5. Moriarity
    Moriarity
    SUPER MODERATOR
  6. 05snopro440
    05snopro440
    Is the MSD picture also wrong? I'm not being s***y, I genuinely am curious.
    The weight installation matches the HEI I have on my bench that just came out of a SBC
    Wouldn't hurt anything to swap it and try it, I guess.
  7. 05snopro440
    05snopro440
    GlassThamesDoug likes this.
  8. Moriarity
    Moriarity
    SUPER MODERATOR
  9. 19Eddy30
    19Eddy30
    from VA
    Check to make sure the Vac moves
    With finger , it can limit the plate
    Movement of wights,
    & pics show opposite of @Moriarity point weights ,my self not @ shop to check 1 of 10 HEI's I have :cool:
    GlassThamesDoug and alanp561 like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    unless an Hei and a points dist are different, I just spun mine and the mech adv works
  11. 05snopro440
    05snopro440
    No, it's not.
    rockable likes this.
  12. Moriarity
    Moriarity
    SUPER MODERATOR
    yup, I was wrong, all the pics I see are opposite of the points dist. doesn't make any sense to me. I do not have an Hei to test .. sorry if I messed you up
    Toms Dogs, alanp561 and 05snopro440 like this.
  13. ClayMart
    ClayMart
    That looked su****ious to me too. When the rotor is installed I wonder if it could put the advance mechanism in a bind.
    jaracer likes this.
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    you should be able to grab the rotor and rotate it some against the spring pressure...
  15. 05snopro440
    05snopro440
    I'm able to move the weights freely with the rotor installed., everything is well lubricated and moves freely.
  16. 05snopro440
    05snopro440
    Yep, it advances the magnetic ring attached to the shaft.
  17. 19Eddy30
    19Eddy30
    from VA
    Not over lapping
    05snopro440 and alanp561 like this.
  18. 05snopro440
    05snopro440
    Nope not at all. Besides, my weights now look like the picture in the MSD instructions.
  19. 19Eddy30
    19Eddy30
    from VA
    I missed typed , Mint to say
    NO , not over lapping ,pic was to shown that where Not :rolleyes:
    05snopro440 likes this.
  20. 05snopro440
    05snopro440
    Oh, yeah I got that. I was agreeing with you.
  21. 05snopro440
    05snopro440
    All good. Strangely when I spin the one on my bench (SBC, same direction of rotation), the weights fling out when I spin it counter-clockwise but not clockwise. I'm so confused.
  22. 05snopro440
    05snopro440
    Pickup coil turns counter-clockwise with vacuum applied. Mechanical Advance advances the distributor shaft clockwise. These directions make sense for advancing timing.
  23. Oneball
    Oneball
    Have you done what Moriarty said and check you can turn the rotor arm? It could be something on the bottom of the rotor arm is fouling the weights. Other option maybe the springs are so light it’s getting full advance after you start it, I run my race car like that.
  24. 05snopro440
    05snopro440
    Yes, the rotor moves freely, and the weights move freely under the rotor. I did say that originally too.
    There is no binding. Short of trying the lightest and heaviest weights, I'm at a loss.
    I've tried three different spring/weight combos with no difference so far.
  25. Oneball
    Oneball
    When you move the weights/rotor can you see the trigger moving in relation to the pickup?
  26. 05snopro440
    05snopro440
    Yep, the trigger ring on the shaft moves clockwise (advance) relative to the pickup side. That's why it's so strange to me.
    When I provide vacuum to the vacuum advance, the pickup turns counterclockwise, which I believe would also advance the timing.
    There's obviously an issue but everything seems to operate as it should.
    jaracer likes this.
  27. RmK57
    RmK57
    My MSD with the two lightest springs will flutter back and forth, really messing up the timing. Maybe be a vacuum thing? Try plugging it off then run just initial and then your mechanical.
  28. 05snopro440
    05snopro440
    The timing checks were with no vacuum connected.
    I'd love to run mechanical advance, but it's not making any. :)
  29. partsdawg
    partsdawg
    from Minnesota
    Try using a different timing light?
  30. jaracer
    jaracer
    If the weights are free and the rotor will move when you attach it and move the trigger ring; then I think that your weights are at full advance at 600 rpm. That's the only thing that makes sense. Need stronger springs.
