Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Sharpone
    Sharpone
    Anthony is the engine going in the Chevy on the left?
    Dan
  2. No.
    51 merc
  3. Sharpone
    Sharpone
    Definitely gunna be cool old school
    Dan
  4. tomcat11
    tomcat11
    Nice find. I have a set of those but one of mine has a small piece of the gasket lip broke off. Some day I'll repair it. Pretty hard to find and they usually bring good money.
  5. dave agosti
    dave agosti
    chryslerfan55 and porkshop like this.
  6. chryslerfan55 and porkshop like this.
  7. swade41
    swade41
    from Buffalo,NY
    I've been working on the steps on the 57
    Screenshot_20250504_140825_Gallery.jpg 20250503_155016.jpg 20250503_162253.jpg
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Did you step on wet paint?
  9. jeepster
    jeepster
    from wisconsin
  10. swade41
    swade41
    from Buffalo,NY
    I stepped in something lol
  11. dana barlow
    dana barlow
    from Miami Fla.
    Fix one thing,somethingcomes up next ! Water leak is gone n good now.
    Made about a 40 mile run to a show`` sat.< Turned out that had been can'ed=but no one posted that it was off ! Bizz that hosted went belly up late week,I found out! :(. So with another rod that came too,we went for pizza :D:p at our anytime hang out !:D. On way home brake pedal dropped lower then normal,an that also made brake light stay on all the time. Lucky it still stopped with extra pump.
    Got home OK!
    Checked a number of things,brake wise=that I had not checked as much as i should.
    Brake adjustment had gotten off,so redid that. Opened master Cly an looked in{ front only 1/2 full n turned brown=bad n has water n rust. Rear was full,but also brown n rust;;; I'll be pulling the master off n cleaqn up or replace,plus bleed all n check wheel clys next [ I use 1948 drum brakes in my 28A, I rebuilt them a few times over the years,but its been too long now ; my own falt for being lazy,from last time.
    Some more fun fix it time ;):D:cool:
  12. mad mikey
    mad mikey
    Yea Dana, funny you mentioned this kinda. I just changed the brake fluid on the coupe over the weekend, I do it every 2 years weather it needs it or not. Glad you got home ok and can fix the problem.
  13. saltflats
    saltflats
    from Missouri
    New patient in the shop. 63 power glide. I see future time at the parts washer.
  14. fastcar1953
    fastcar1953
    @saltflats Is that a shifter mount on tail shaft housing?
  15. saltflats
    saltflats
    from Missouri
    This one does use a tailhousing mounted shifter. It's out of a 63 Impala SS.
  16. fastcar1953
    fastcar1953
    449792161_8197684646922416_3334897836403534514_n.jpg Wished i had one of those for my nova. I have a 4 speed boot for a bench seat 63 Impala. It has a Powerglide in it.
  17. saltflats
    saltflats
    from Missouri
    I only have the transmission, just a rebuild for a friend.
  18. Think I like these old cal customs better
  19. Sharpone
    Sharpone
    Well sir you have a conundrum both are cool.
    Dan
  20. Almostdone
    Almostdone
    All good ideas/questions.
    Double shear would be better.
    The bolts were grade 8 from the hardware store, but the grip wasn’t long enough and it broke in a threaded section. I replaced with longer Grade 8 bolts from a better source.
    Gulp…. No suspension travel stops!
    Thanks folks.
    John
  21. saltflats
    saltflats
    from Missouri
    Got most of the parts cleaned up, now waiting on a kit to put it back together.
    swade41, porkshop, enloe and 8 others like this.
  22. Boneyard51
    Boneyard51
    I like working on standard transmissions. They are kinda like a puzzle!
    Bones
  23. Sandcrab
    Sandcrab
    I finished the vents in the hood and mounted the fenders to shape the lower edge of the sides. Then I widened the rear fenders and mocked up the original running boards. I will probably make new ones since the taper and extension would require a lot of welding on rusty and pitted pieces.
    Resized_20250502_131229_1746499600640.jpeg Resized_20250504_125239_1746499612270.jpeg
    I didn't like the look from the rear so I tried the original bumper. That seemed to help the look, but it is just a 2 x 3/16" strip of steel so no strength and not long enough. Maybe a g***er tube bumper is in the works.
    Tickety Boo, swade41, brading and 3 others like this.
  24. Let’s see, vehicle, check, build plan, check, rear axle, check, front suspension, check, engine, pending, transmission, pending, exhaust, pending, mufflers?, you don’t need no stinking mufflers. Carry on.
  25. Sandcrab
    Sandcrab
    Engine, check, 1962 Buick 215. Transmission, check, T5, exhaust, check, gl*** packs although I will have to check on the direction I installed them. Yesterday I dug out an old Toyota alternator that is no longer available that I was able to hang on one of the accessories mounting bosses on the 300 heads. It is a smaller diameter and not as deep as any of the later units and with an internal fan. A single groove pulley is on the way.
    Resized_20250506_171055_1746580997462.jpeg Resized_20250506_171109_1746580998897.jpeg
  26. Filtered air valve holder upper
  27. milwscruffy
    milwscruffy
  28. Yes. Was new. “Z28” springs. Changing to stock 80# springs. Finally read the cam recommendations.
    One less thing to blame a failure on.
    These “rv” springs were less than $2 from my engine parts supplier.
  29. saltflats
    saltflats
    from Missouri
    Playing with the plasma CNC with a alternator bracket 2.0
  30. 1971BB427
    1971BB427
    from Oregon
    Finally getting my '39 Chev out for the first time since last October! Weather is starting to look more summer like, so I'm pulling it into the driveway today for a thorough cleanup from all the dust and dirt it seems to ac***ulate in my metal shop building. Guessing a full day or more to prepare it for the first event Saturday!
    Tickety Boo, das858, Gotgas and 9 others like this.
