Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. NealinCA
    NealinCA
    Circling back on topic...
  2. Squablow
    Squablow
    My ignorance is really going to show hard here, but what exactly do you hone in one of those machines? It doesn't seem like there's a vice/fixture for holding things in place while they're being honed, so I don't get how it works. Do you have to hold parts in your hand while the machine is running?
  3. RodStRace
    RodStRace
    @Squablow Yes. Any part that has an internal bore with a tight tolerance. Most obvious here would be a connecting rod big end after it's been resized. Machining can get you close enough in most cases, but for a thousandth (0.001") or less, you hone. It's a very light pressure operation, and holding it provides feel feedback.
    EDIT: the honing is removing at under ten thousandths, sneaking up on the measurement or fit. Think sanding with very fine wet sandpaper.
  4. Outback
    Outback
    from NE Vic
    Not being able to see if there's a bumper on the car made me smile :D
    Beautiful work on the Hone
  5. A Boner
    A Boner
    If you are a careful driver, you don’t need a front bumper. The rear bumper is a different story!
    Stogy, 31chevymike and porkshop like this.
  6. dirt car
    dirt car
    from nebraska
    Probably not traditional but a (3) tube sort of see through nerf bar bumper that would mimic the exact 32 bumper contours with pirated rolled ends yet keeping underpinnings in at least partial view.
    Stogy, 31chevymike, Outback and 2 others like this.
  7. Shadow Creek
    Shadow Creek
    With the level of detail this thing has, it would be great to see it side by side with @Cody Walls ardun killer coupe as it is also a highly detailed traditional rig.
  8. NealinCA
    NealinCA
    The hood.
    Josh Carrillo @carrillocustoms made up some 19 gauge blank hood sides.
    IMG_20250504_083251(1).jpg IMG_20250504_083940(1).jpg 20250427_103655.jpg 20250427_161153.jpg 20250427_161923.jpg 20250427_161827.jpg
  9. NealinCA
    NealinCA
    The louvers.
    I've been kinda obsessed with early style 4 and 5 inch louvers for quite some time. I was on the hunt for them 15-20 years ago when I was building my RPU. There are modern 5" dies, but not the shape and spacing of these. Most had only 1/8"-3/16" spacing between louvers. I describe the look as louver, louver, louver. Not louver, space, louver.
    Screenshot_20250501_142129_Instagram.jpg zorro.jpg CABRIOLET (418).jpg COVER OF HOT ROD (2).jpg DeuceSedan louvers and antenna(1).jpg 31 Roadster 5 inch louvers.png
  10. NealinCA
    NealinCA
    The purple hood.
    I found these purple hood tops at the Turlock swapmeet 15 years ago. I decided this car needed matching louvers on the hood sides, similar to some of the examples above. With no luck on finding the correct dies, I had my friend Joe Ny digitally scan the louvers on the hood tops and then have pieces laser cut to make dies. After much trial and error, we were able to punch some test panels. Then I approached Kewi Kev to see if he'd be willing to help out with the use of his famous louver press. We built adapters to mount my dies and Josh and I headed down to Ventura for the day. Between Kevin, Josh and I, we made it happen and got the hood sides done
    20221121_094126.jpg IMG_20250504_085811.jpg IMG_6572 (1).jpg e1125c69-9fff-4633-bc6c-61717dd064bd.jpg 20250322_174150.jpg IMG_20250504_083608(1).jpg IMG_20250504_083622(1).jpg IMG_20250504_083631(1).jpg IMG_20250504_083637(1).jpg
  11. NealinCA
    NealinCA
    The result
    I'm sure some don't get it, but it's the quirky 50's look I was after. I think the hood really brings it all together.
    The chop. The rear fenders. The hood.
    20250502_194446.jpg 20250502_194425.jpg 20250502_192017.jpg 20250502_191917.jpg 20250502_191812.jpg 20250502_191528.jpg 20250502_191645.jpg
    Your thoughts?
  12. NealinCA
    NealinCA
    The next step
    We tore the car apart yesterday, in preparation to send off for body and paint work
    20250503_190704.jpg 20250503_190716.jpg 20250503_182741.jpg 20250503_182724.jpg
  13. Black Panther
    Black Panther
    from SoCal
    Neal...im obsessed with old louvers too..and how they were laid out. I luckily later scored a louvered hood from the guy who I got my '38 Chevy from...it was intended for my car. They just don't lay them out like they used too..and normally use way too many louvers for my taste. The way your side louvers line up with your hood top louvers is magic. Awesome as always.
    Stogy, 31chevymike, brEad and 4 others like this.
  14. The37Kid
    The37Kid
    The hood looks great! I'd really like to see how the hinge is rolled in to match the original top pieces.
    Stogy, 31chevymike, porkshop and 2 others like this.
  15. hotrodA
    hotrodA
    Beautiful hood! I like the at***ude of can’t find something, just make it!
    Can’t wait to see it painted.
  16. -Brent-
    -Brent-
    The story on the hood as well as making it with buddies is the best... and it looks rad, too.
    Stogy, 31chevymike, akoutlaw and 3 others like this.
  17. 19Eddy30
    19Eddy30
    from VA
    The RollPan under frame is interesting,
    I wonder just Cosmetic, for exhaust header , To look cleaner ?
    If so wonder why builder did not continue to the rear tire.
  18. NealinCA
    NealinCA
    Josh made up dies for his Pullmax for the upper and lower details. He even made dies to stamp the inverted Y-shape behind the latch catches.
    IMG_20250504_112955(1).jpg IMG_20250504_113009(1).jpg IMG_20250504_113004(1).jpg IMG_20250504_112915(1).jpg
  19. Looks perfect on the car Neal! It was a pretty stressful day, my press was maxed out, straining to cut those 5” louvers. It took a couple of hours setting it up so the dies would stay in adjustment. I had to add a back brace with a length of tubing and a couple of come alongs to help with the extra flex. It was very nerve racking when Neal started punching the side panels, we sharpened the dies several times during the process. No one could relax until the last louver was punched. It is very rewarding seeing the end result! It was fun spending time with you and Josh, 2 very smart, cool and talented guys! Welcome back any time.
  20. Robdski
    Robdski
    The hood is perfect!
    That’s an amazing amount of talent in one place, at one time. Excellent work.
    Stogy, 31chevymike, SDS and 2 others like this.
  21. Tim
    Tim
    from KCMO
    Absolutely nailed it. That hood all together 100% looks off the cover of a little book. Well worth the effort!
    Stogy, 31chevymike, akoutlaw and 5 others like this.
  22. NealinCA
    NealinCA
    Thank you. That was the intention.
    Just like the 50's, bro...haha
  23. NealinCA
    NealinCA
    I had one last project to finish up before paint. Since I'm not running a stock front valence panel, I needed to finish up my version. I had made up panels to cover the insides of the frame rails, but never addressed the small triangles at each side of the grille shell. You could see the crossmember and spring, as shown below
    I had an original valence from an old showcar that had been modified. The thing I liked about it was that they added some little ears on each side that go up under the corners of the shell, filling in the corners where you could still see the crossmember.
    I didn't use much of it, but it was easier to cut one up than start from scratch
    20250504_115944.jpg 20250504_124519.jpg 20250504_154834.jpg 20250504_155706.jpg 20250504_155733.jpg
    A lot of work to cover up two tiny triangles, but I'm happy with the results. The frame cover pieces will be chrome, the valence piece will be painted body color.
    Hey @-Brent- I'm trying to copy your look!
  24. Tim
    Tim
    from KCMO
    Man that’s a lot of work for something that is nearly impossible to notice, but looking at the before and after it clearly looks more finished now. Good on ya
    Stogy, 31chevymike and Outback like this.
  25. TERPU
    TERPU
    They look great!
    I get the spacing, while it is a thinking man's layout though. The first Louver lines up with the front of the Louvers on the Hood. Then you play the start of the second Louver while taking into account the swoop of the Fender. This line both sets up the end for the top row and start of the bottom. Keeping both in line with the hood dimensions front and back and playing the fender swoop into it all. Then ending the lower row in line with hoods last Louver at the row closest to the firewall. - This is the Engineering Major version I am quite certain :)
    Or in short, just laid them out so it looks *****in' !
    Quirky - I think not.
    However you slice it, BUENO
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Impeccable craftsmanship on the hood. Thank you for the insight into the process. I love that this isn't a traditionally inspired car—it's a traditional one.
  27. The detail on this build Neal is above and beyond, the fact you didn't shortcut on the side louvers is exceptional, those details! The sides are perfect collaboration between you, Josh & Kev, all you should be proud! That apron/valance filler perfect touch. When you finish this people will ask when was it featured in the 50s & where did you find it? This build is truly exceptional! The bare metal shots are so inspiring, this car is a future icon if not already!
    Stogy, 31chevymike, NealinCA and 3 others like this.
  28. brady1929
    brady1929
  29. BigJoeArt
    BigJoeArt
    Looks great neal. Can't wait to see it in color.
  30. It's been said before in this thread, but the attention to detail in this build raises the bar for all traditional builds going forward. Truly an 'all time' 32.
    Stogy, 31chevymike, Robdski and 2 others like this.
