Termites and Bowties- Early Chevy Group
Discussion in 'The Hokey Ass Message Board' started by 29bowtie, Jan 7, 2009.
  1. Jay Altemus
    Jay Altemus
    I learned the 1964-65 Mustang roof skin makes a perfect steel roof. However, I’ve seen roof patches made from a minivan roof with ribs and I liked that too.
    Six Ball and 31chevymike like this.
  2. snoop74
    snoop74
    I have a ribbed roof insert in mine I think it's from a early suburban IMG_1832.jpeg
  3. tb33anda3rd
    tb33anda3rd
    the two I chopped and filled I used a second generation Camaro roof.....but they were cheap and plentiful in the eighties.:cool:
  4. Shitbox
    Shitbox
    from Nor Cal
    I’d chop it if it were mine. That said, have you got everything fitting correctly and hard tacked in place? If not, get everything squared up and fitting before you even think about cutting into it. Sounds like a longer path but it’ll save you tons of work and potential headaches in the future.
  5. Jay Altemus
    Jay Altemus
    Photoshop picture of a 2” chop.
    Six Ball, snoop74 and 31chevymike like this.
  6. I suppose that I need to chop my roof after his...
    Jay Altemus, Six Ball and snoop74 like this.
  7. Six Ball
    Six Ball
    from Nevada
    Ah, What the heck take 6".
    Jay Altemus, snoop74 and 31chevymike like this.
  8. snoop74
    snoop74
    Now we’re talking lol
    Six Ball, Jay Altemus and 31chevymike like this.
  9. Incredible White and Gold Trim Diamond Tuck Interior.jpeg Incredible Candy Gold Paneled Truck.jpeg
    Part of this issue is the real fact that I am 6'3" tall. Like Jay mentioned, a mild chop or a "rake chop" for me would be ideal for my cir***stances. The '59 Thunderbird bucket seats that I've had for years is waiting for the right upholsterer, and I may have found one in town. Just need to ask if they can execute the early style thin pleats in pure white or white pearl in metalflake, leaning toward the latter.
  10. snoop74
    snoop74
    IMG_1514.jpeg IMG_1512.jpeg That interior is phenomenal. Yeah I guess with you being that tall it would be an issue for you. I’m only 5’10 and I have a 5” chop. I had a ton of headspace before the headliner was added.
  11. Six Ball
    Six Ball
    from Nevada
    I was joking about 6". The 2" photoshop looks very nice and clean.
    31chevymike and Jay Altemus like this.
  12. Jay Altemus
    Jay Altemus
    So . . .
    If I stretch the roof with that staggered cut to align the A pillar, then the B pillar will move back. That will make extra work. I’d need to cut around the upper window to move it forward to realign the B pillar. Or I could try to keep the B pillar where it is and lay the back window panel down.
    If I change the angle of the A pillar, (which I’d rather avoid). Then the roof would not need a stretch.
    Advice?
    31chevymike, tb33anda3rd and Six Ball like this.
  13. Shitbox
    Shitbox
    from Nor Cal
    This may help.
    You can also work you chop out on paper as you started to with the photo copy’s. Take pics from front/side/rear with your layout taped up cut with scissors and you see what you need to do and how it’ll look. Way less work that starting and finding out you screwed up in the layout after you cut it up.
  14. Jay Altemus
    Jay Altemus
    His 3” chop on that 33 coupe turned out nice. I cringed when I saw what he had to do to that rear window. He can TIG and apply lead over weld seams. I don’t have those skills but I followed his process the whole way.
    I think a roof stretch would be my method of choice - like he did but probably with the staggered cut I showed. It was good to see that the sides lined up even with a 3” chop.
    Shitbox, 31chevymike and snoop74 like this.
  15. Jay Altemus
    Jay Altemus
  16. Jay Altemus
    Jay Altemus
    Got the door pillars installed to the sheet metal. Doors align pretty well. It’s coming along. The jack stands are just temporary.
  17. snoop74
    snoop74
    Lol Jay I seen a pic of the coupe on it's side did it fall off the jack stands?
    31chevymike likes this.
  18. Jay Altemus
    Jay Altemus
    You mean THIS pic?
    Well, . . . . Now that you mention it. Yes, that was MY coupe. Operator error. Not equipment failure. One dolly was up against a tire and I kept pushing. Slow graceful tip over. Zero damage. Back up on the stands 5 minutes later.
    The precarious “jack stands on dollies” is a VERY temporary solution. I needed some walk around room so I could square up the doors and door frames and my shop is too cramped.
  19. I doubt it brother, that body is precious (any original steel body for that matter)... Speaking of steel bodies, I had some friends over from the Gilbert area, where I used to work, to stay over for two nights for a Championship Fishing Tournament on the Colorado River this past weekend and got some needed help to take my coupe body from the ch***is, back on the body cart. Now I can finish up the last tasks on the ch***is and very psyched about that!
    Six Ball likes this.
  20. FRANKTHECRANK
    FRANKTHECRANK
    from EAST COAST
    Just for comparison sake and relevance to the two inch chop being done to the 5 window above, this is a two inch chop on my 3 window 33. And yes, the three window doors are larger/longer than the 5 window, and me being 6' 1", a three window is much easier for me to enter and exit the car.
  21. She's a nice-looking hot rod Frank. For a steel body, the door gaps are excellent, looking so much like a fibergl*** body. Dig the "seaweed" flames, like Larry Watson did in the 50's and 60's - also considering this on my '31. Mounting the body channeled over the frame by the firewall looks tough as well, would love to do this on my '31, most likely cannot be done with an original style wood floor that I replaced in '96. LONG LIVE CHEVY HOT RODS!!!!
  22. Jay Altemus
    Jay Altemus
    Just so you know I’m still working on my 34 coupe . . .
    I patched this original DS rear door frame support bracket this weekend AFTER returning from a weekend of Chevy truck fun in TN.
    I hope to square up the door frames and doors this weekend.
    TFoch, 31chevymike, snoop74 and 5 others like this.
  23. Last edited: Jun 8, 2025
  24. Jay Altemus
    Jay Altemus
    I had a productive day in the shop. I had planned to square up my doors and door frames. I decided to mount my rear leaf springs and axle instead. The rear frame brackets had to come off because they interfered with the planned location for the rear shackles.
    I used a small bubble level to find the highest point of my frame arch. The body is pretty much where it should be. The highest point of the wheel well lined up with the frame arch which was what I was hoping for.
    I dropped a plum line and lined up a carpenter’s square with the plum line. Then measured according to the instruction sheet. The front brackets were mocked up with a single screw so the bracket can swivel. I’ll tack weld the front brackets in place AFTER the rear shackles are attached to the frame. That way I can be sure the front brackets are perfectly lined up with the rear shackles.
    I think the axle and tire look centered in the wheel well. I am pretty happy about that. If anything has to change, it might be that the body might move forward 1/4” - 1/2” max.
    My 87 Camaro rear axle is too wide. So I might search for an S10 4x4 axle which is supposed to be just right. I like the 3.23 Camaro axle gear and disc brakes, so I might have it narrowed.
    IMG_9597.jpeg IMG_9598.jpeg IMG_9600.jpeg IMG_9615.jpeg IMG_9614.jpeg IMG_9611.jpeg IMG_9616.jpeg IMG_9621.jpeg IMG_9622.jpeg IMG_9623.jpeg IMG_9624.jpeg IMG_9626.jpeg IMG_9627.jpeg
    TFoch, snoop74, 31chevymike and 2 others like this.
  25. Jay Altemus
    Jay Altemus
    Here’s a technical question.
    The bottom flange of my frame is not perfectly parallel to the earth. Therefore the leaf spring front brackets are not parallel to the earth. Do I need to add a shim to make them level?
    TFoch, 31chevymike and tb33anda3rd like this.
  26. tb33anda3rd
    tb33anda3rd
  27. Great job so far Jay! You're nailin' it!
    snoop74 and Jay Altemus like this.
  28. Not sure if I ever posted this video on our Chevy thread that my brother Scott found for me on the net A LONG TIME AGO... I posted this video on my YouTube Channel of a group of teenagers who helped with the build of their buddy's '31 Chevy 5 window coupe back in 1959 - 1960. Look at the background cars to show the timeframe of this vid. It's a bit corny, but something most hotrodders/hobbyists don't see too often, and should bring some smiles too!
    (1) The building of an early 60's '31 Chevy HOT ROD filmed in 1959 - 1960! - YouTube
    Six Ball, Jay Altemus and snoop74 like this.
  29. snoop74
    snoop74
    haha that's awesome
  30. tb33anda3rd
    tb33anda3rd
    great video and cool car!
