I'd like to present our latest product, the Auburn Dash. This is a nearly perfect replica of the original. These are stamped steel to the correct gauge and chrome plated, each dash comes with the Dimond pattern trim riveted to the panel just like the original V-8 series Auburns with the exception of the blank DIY (Drill It Yourself) panels, these have the trim plate loose. Panels have studs welded to the back and come with mounting clips. To Purchase please contact me here or at Sales.MurocMfg@Gmail.com as of right now we take check & Venmo. If using PayPal we will have to unfortunately add a 6% increase due to their high rates. We are currently working on releasing our own line of gauges, reproducing the Iconic 1940s 2-5/8 Smooth Bezel Gauges. Our website www.MurocMfgCo.com Instagram updates on new products @Pat_Pryor and @Muroc_Mfg_Co I will be adding better promotional pictures over time. These are Limited Quan***ies. Plain without holes and trim not riveted "DIY" - $575 (Comes with Rivets) 2-5/8 with 3-3/8 center hole pattern is $600. 2-1/16 with 3-3/8 center hole pattern is $600. 2-5/8 with Auburn 3-5/8 center hole & Auburn rear mount studs $625 Original Auburn Hole pattern with all studs $675
