Projects 390 fe
Discussion in 'The Hokey Ass Message Board' started by 57Buick, May 7, 2025.
  1. 57Buick
    57Buick
    from Alabama
    IMG_2229.jpeg IMG_2231.jpeg Got it home and it's in the garage, just out of truck. Makeshift til I get it on my stand.
    Gonna clean it up and see what I done got :)
  2. Boneyard51
    Boneyard51
    Looks like a very good starting point! Protect that air cleaner and the valve covers! Did you ever cough the number of engine mounts ….on both engines?
    Bones
  3. Mr48chev
    The Never say die Ford V8 workhorse.
  4. Oneball
    Oneball
    Everything seems there which is nice car. Doesn’t look like it’s been stored in a swamp either. Looking at the mounts I think that’s from a TBird, in which case I think I’m right in saying the intake will be flat for a 64.
  5. 57Buick
    57Buick
    from Alabama
    No but I will and get back
  6. mad mikey
    mad mikey
    390? Hell yea , great engine. Running right , a real torque monster.
  7. deathrowdave
    deathrowdave
    from NKy
    Swap on aluminum water pump , intake , tube headers she’s a light weight cool as it gets screamer
    Spooky, saltflats, loudbang and 3 others like this.
  8. Blues4U
    Blues4U
    from So Cal
    *****in engine. Can you get a rear sump for those?
  9. 57Buick
    57Buick
    from Alabama
    I like all those ideas !
    mad mikey and Sharpone like this.
  10. 57Buick
    57Buick
    from Alabama
    Not sure, I am just now getting started. I am not very knowledgeable about it but will be learning :)
    mad mikey, Blues4U and Sharpone like this.
  11. Boneyard51
    Boneyard51
    Kinda! The four wheel drive truck engines were rear sump. But the oil pump obviously stays in the front, for a little bit of depth!
    If you buy one….its the sump, the pan and the bolt!
    Bones
    Sharpone and Truckdoctor Andy like this.
  12. Okie Pete
    Okie Pete
    4x4 pickups have a rear oil pickup tube and oil pan .
  13. willys36
    willys36
    The most frustrating part of your build will be stabbing the distributor on that stinking hex shaft!!
  14. 57Buick
    57Buick
    from Alabama
    Ha, sounds interesting
    Boneyard51 likes this.
  15. Aaron65
    Aaron65
    from Michigan
    Ugh, and you can only hope that the collar to hold it in place is pointed in the right direction. Whoever built the 390 in my T-Bird installed the pump shaft with the collar on the oil pump end, so anytime I pull the distributor, I listen for the "clunk."
    One of these days, I'll pull the pan and flip it around.
    jet996, warbird1, saltflats and 2 others like this.
  16. 57Buick
    57Buick
    from Alabama
    Good idea !
  17. Pontmerc
    Pontmerc
    from Finland
    Air cleaner is 60-early63.
    Intake is slanted.
    Im pretty sure that is a 63 galaxie "thunderbird special" 4v 300hp engine.
    Engine mounts look like 63-64 type.
    deathrowdave, Spooky, 57Buick and 2 others like this.
  18. 57Buick
    57Buick
    from Alabama
    That is exactly what I thought. I was told it came out of a 64 Galaxie so it looks to be true. Thank you for looking at it.
    Oneball and Sharpone like this.
  19. saltflats
    saltflats
    from Missouri
    This does help but these are still heavy blocks. My comparison was a trip to the machine shop with a 428 block and a 409 Chevy block, the Chevy was much lighter.
  20. Boneyard51
    Boneyard51
    There is a very easy procedure for stabbing Ford distributors ! But us Ford guys try to keep that secret from the brand x guys! lol
    Bones
  21. Boneyard51
    Boneyard51
    James , do you know if you put aluminum heads, intake , water pump on an FE , it will weight about the same as a stock small block Chevy !
    Bones
  22. willys36
    willys36
    I'm a hemi guy so ignorant of Blue Oval tricks!!
    Sharpone likes this.
  23. jaracer
    jaracer
    I always thought that just putting an aluminum intake on an FE would not only make the engine quite a bit lighter, but it would also lower the center of gravity of the whole car.
    Spooky, warbird1 and 69fury like this.
  24. Don’t have to care about weight in a low low
    the more the better
  25. Several ways to install a Ford dist. 1st: Take a deep socket the same size as the shaft and tape it to an extension so you can't drop it. Turn the shaft slightly until you reach the desired spot. 2nd: Install dist. where you think it will be correct, hold slight pressure on the housing and use a breakover to turn the crankshaft some until it falls in place. Turn the engine backwards to the timing mark you choose and see if you have the desired location.
  26. Compared to most of its '50s contemparies it's a lightweight. Yes, it weighs more than a Chevy 'W' motor (the lightest of the 'big inch' '50s design motors and basically a reworked small block) but is lighter than nearly all the rest. And unlike most of those, it's fairly easy to shed weight off a FE.
  27. The OP is planning on a 4-speed behind whichever 390 he elects to use, and I have been giving him some pointers about what to do for over a year. The only thing CRS has reared up on is the flywheel. @Crazy Steve maybe you can chime in on whether the T-10/Top Loader change also required a like flywheel?
    57Buick and Sharpone like this.
  28. Well, you have the various flavors of trans/bellhousing bolt patterns, car or truck bell to deal with, but FE flywheels are pretty straightforward. There are two ring gear tooth counts, the '58-64 153 and the '65-up 184. You want the later count, that allows the use of the later style starter (cheaper/easier to get/more reliable). It will fit any bell. You can swap ring gears on a manual flywheel if needed, cut the old one off and heat the new one to install. The flywheels themselves are all interchangeable with the single exception of the 428 flywheel. That motor is externally balanced at the flywheel, all the others are internal.
    Pretty much everything you'll need to know is here.... Technical - FE Manual Bellhousings: What are the REAL differences between them? | The H.A.M.B.
