Projects 39 Ford Conv build (update 5/8/25)
Discussion in 'Traditional Hot Rods' started by ronzmtrwrx, Jan 10, 2021.
  1. ronzmtrwrx
    ronzmtrwrx
    Thank you sir. There are many folks on here much more talented than myself. They push me to try to do things better each time.
    neilswheels likes this.
  2. 6sally6
    6sally6
    Brother....you KNOW you can work some sheet metal !!! ;)
    GREAT WORK.......
    6sally6
    ronzmtrwrx likes this.
  3. ronzmtrwrx
    ronzmtrwrx
    Just a little update on some progress. IMG_0196.jpeg IMG_0197.jpeg IMG_0203.jpeg IMG_0201.jpeg IMG_0207.jpeg IMG_0216.jpeg IMG_0221.jpeg IMG_0220.jpeg I did a little bit of finessing on the sheet metal here and there.
  4. ronzmtrwrx
    ronzmtrwrx
    I rented a big compressor for last weekend so I could get the rest of the body sandblasted inside and out. Not a fun job, but just part of it I guess. IMG_0252.jpeg IMG_0254.jpeg IMG_0256.jpeg IMG_0257.jpeg IMG_0258.jpeg IMG_0262.jpeg IMG_0264.jpeg IMG_0263.jpeg IMG_0260.jpeg
  5. ronzmtrwrx
    ronzmtrwrx
    Monday I decided to take the day to get some epoxy primer shot on the sandblasted areas to keep everything protected. I used black PPG EPX epoxy on the cowl section and the rear wheel wells and some Sherwin Williams industrial epoxy on the rear floor/interior metal as well as underneath. I then used some white EPX on the inside of the firewall area because I’m planning on painting that area with a Wimbledon white eventually. It will make it much easier to see under the dash when working under there. IMG_0293.jpeg IMG_0294.jpeg IMG_0295.jpeg IMG_0296.jpeg IMG_0297.jpeg IMG_0299.jpeg IMG_0300.jpeg IMG_0301.jpeg IMG_0302.jpeg
  6. Wow, that's beautiful metal work Ron. Speaking of painting the underdash area white to help see better...My buddy just finished his roadster build (the Kenny G roadster that competed for AMBR this year). He added an adhesive strip of led's to the bottom inside of his cowl. Invisible until the flip of a switch, then suddenly his underdash area was lit up like a film set. I'm thinking I might copy that idea.
  7. ronzmtrwrx
    ronzmtrwrx
    Thanks. Those lights would be pretty cool, as long as you could get them in the right color temp. 3-4k would probably work. l wouldn’t want anything much whiter than that though.
  8. 59sedandelivery
    59sedandelivery
    Just AMAZING WORK!!!!!!!!
  9. joel
    joel
    That metal finish looked too nice to paint. Great job! I think the worst part of sand blasting is getting all the sand out afterwards :)
    ronzmtrwrx and The 39 guy like this.
  10. The 39 guy
    The 39 guy
    Outstanding metal work ! thanks for the update!
    woodz and ronzmtrwrx like this.
  11. ronzmtrwrx
    ronzmtrwrx
    Thanks. I agree, getting the sand out is tough. That’s the main reason I left the tail pan off until after I blasted it. It made it a ton easier to blow it out the back. I still have a good bit of metal work left to do, but I’m planning to get the body setting down on the frame before I put the rumble lid back on. Then I can finish the work around the opening. And then there’s the doors……lol. I’m a long ways from having a car but hopefully I’ll get there one day.
  12. MMM1693
    MMM1693
    Just outstanding!
