Technical What's the neatest/coolest/cleverest/pretty way to route plug wires on a SBC?
Discussion in 'The Hokey Ass Message Board' started by atch, Apr 13, 2025.
  1. Frames
    Frames
    Made my own stainless steel 2003-12-31 23.00.00-158.jpg looms
  2. patsurf
    patsurf
    THAT deserves a more close up shot--nice!
  3. Blue One
    Blue One
    from Alberta
    The Ford Y block engine has the neatest system for routing plug wires.
    You should check them out, maybe you could adapt the idea to your SBC.
  4. May as well show what i did on mine. I also put two P clips on the pan each side to hold the front wires tidy and out of harms way. JW
  5. winduptoy
    winduptoy
  6. atch
    atch
    Interesting you should post this pic Larry. Just yesterday I was perusing these wire holders and I think I'll order a set.
    winduptoy likes this.
  7. Wireless sender and receivers on 8 different frequencies needs to get invented so no wires are required.
    Lil32, clem and 26 T Ford RPU like this.
  8. atch
    atch
    After burning three wires I gave up and ran them the ugly "over the valve covers" route. Oh, well, this engine isn't pretty anyway. Just functional. You'll notice that I turned the looms so that the wires "pointed" towards the plugs but apparently the wires have a mind of their own and just go wherever they want.
    Tim likes this.
  9. gnichols
    gnichols
    from Tampa, FL
    I like the way many drag racers do it... running the plug wires under the headers along the side of the block. Just some wire loom nylon clips where needed. Nothing over the valve covers or between the header pipes.
  10. atch
    atch
    Well; yeah. We all do but there just wasn't a good way to run them under the pipes. I tried and burned wires. There just wasn't any way to run the #3, 4, 5, & 6 wires under the pipes without burning them. When I say "block huggers" these REALLY hugged the block.
    Anyway, this ain't no show car and I almost never raise the hood when anyone else is around; like at car shows. For the most part I'm the only one who ever sees this engine.
  11. RodStRace
    RodStRace
    @atch, you did what you could with the limitations of your setup. Better than the show pony with pretty everything that can't even idle!
    427 sleeper and atch like this.
  12. 49ratfink
    49ratfink
    I like the way the factory did it.
    X-cpe, 427 sleeper and Hollywood-East like this.
  13. atch
    atch
    Well, I do too, but that just didn't work for this engine/header combination.
    427 sleeper and 49ratfink like this.
  14. Splitbudaba
    Splitbudaba
