Hey guys, I blew a rod on my 1959 F100's 223 and am switching to an FE. Having said that, I have a number of parts for 223 and 300 Fords. I also have some other random stuff. Just trying to fund my engine swap. Most of this is OBO. Ships on your dime. Thanks! Holley 1904 w/ Rebuild Kit: $175.00 Ford 223 Air Cleaner: $30.00 Ford 223 Water Pump: $50.00 <-- I installed this brand new right before the rod blew. Holley 1904 Knock-off: $50.00 <-- Ran great, best reviews on Amazon. Ford 223 Intermediate Shaft: $10.00 <-- New not used Jegs Ford 240-300 Distributor set up for 223 Ford: $150.00 MSD Digital 6AL: $200.00 Pertronix 1261 for Ford 6 cyl: $100.00 <-- New not used 65-67 Ford 240-300 Rebuilt Distributor (stock): $285.00 <-- Never used it. Ford Thunderbird Headlight: $50.00 Sealed Power 224-41117: $75.00 1959 Ford F100 Speedometer with gl***: $25.00 Ford 223 Flywheel: $30.00 Ford 223 Starter Core: $40.00 1959 Ford F100 Gas Tank: $100.00 <-- some surface rust on the inside, but usable 1959 Ford 3-speed manual trans: $250.00 <-- Worked fine before engine blew, spins freely Ford 223 Bellhousing: $50.00 Ford 240-300 HEI Distributor (Speedway): $100 <-- Works fine, needs gear pin
