305 Cylinder head
Discussion in 'The Hokey Ass Message Board' started by silvermachine, Oct 29, 2006.
  1. silvermachine
    silvermachine
    from UK
    Hi all, first posting and will look pretty lame to you experienced engine builders!!
    I've just pulled the heads off my Chevy 350 and the casting on the heads relates definately to a '76 305.
    As far as I am aware the block is a 350. I've checked the casting number on the block (3970014) and it seems to be a 1970-73 two bolt mains 350.
    Were the heads interchangeable? ....is it likely that 305 heads would have been dropped onto a 350 block?
    Confused :confused:
    Thanks guys ....
  2. Fat Hack
    Fat Hack
    from Detroit
    305 heads on a 350 isn't all that uncommon anymore. Real "pro" engine builders will quickly tell you that a 305 can only make a maximum of about maybe 15 horsepower, whereas a 350 with the same equipment routinely produces about 600 ponies for two thousand dollars less than a 305 costs to build...or whatever ******** they wanna spew forth today!:rolleyes:
    Bottom line, you got a small block Chevy with small block Chevy heads on it. Most 305s have small chambers, so someone may have swapped the heads along the line hoping to bump up the compression some.
    Another possibility is that the heads were swapped at some point to make the engine compatible with today's unleaded gasoline. All one needs is a calendar to realize that it's not the 60s anymore...but while we wait for some to catch up to the times, you may wanna do an intro before the trolls rise up to shake their fists at ya!!!
  3. Phil1934
    Phil1934
    If youpulled the head, then the bore is either 3.74" (305) or 4" (350)
  4. silvermachine
    silvermachine
    from UK
  5. 40Standard
    40Standard
    from Indy
    check your casting #. that will tell you if it's a 350 or 305
  6. 57Dan
    57Dan
    I have a set of 305 heads on my 350,casting #601,they have 54 cc ***bustion chambers,they been worked though,fully ported and 1.94 valves.
  7. Phil1934
    Phil1934
    I've got 305 heads on a 400.
  8. TooMany2count
    TooMany2count
    from Cahokia,IL
    dont always believe that, i have a 307 block that the casting #### say its a 327....joe
  9. TooMany2count
    TooMany2count
    from Cahokia,IL
    thats the same site that said my 307 was a 327, so dont believe everything u read........joe
  10. squirrel
    014 is a 2 bolt 350 block used in the early 70s, just like he said...4" bore....
