Projects 3rd car, the "Local" Build
Discussion in 'Traditional Hot Rods' started by jim1932, May 6, 2025.
  1. jim1932
    jim1932
    Not sure I can live up to the name, but I sold the deuce. I want to try to build something from scratch.....
    Toms Dogs, AHotRod, Okie Pete and 8 others like this.
  2. jim1932
    jim1932
    So, not sure I can live up to the ***le, but I found a motor and 39 trans on marketplace 4 miles from my house.
  3. jim1932
    jim1932
    IMG_8292.JPEG IMG_8277.JPEG couple days later took my tractor to the cemetary a mile down the road ot clean up some stuff and saw this over the bank. The owner of the property indroduced my parents. Pretty sure it will be "Free just drag it out". The car gods are shining on this one.
  4. jim1932
    jim1932
    IMG_8254 (2).JPEG Trans has rust but looks real good, was out of a truck.... if you don't mind surface rust.
  5. jim1932
    jim1932
    Hoping to do a Model T turtle back on an A frame.... but we will see what pops up.
  6. Wanderlust
    Wanderlust
    :(I’m pretty sure you will find that those gears will be s****, sorry been there
  7. inthweedz
    inthweedz
    Fill the gearbox with oxalic/water mix, or vinegar for a few days, then see what they look like..
    enloe, lothiandon1940, TERPU and 4 others like this.
  8. jim1932
    jim1932
    It is all apart and soaking in rust dissolve (911). They look good, it is rust flakes from the tower, which was rusted tight. I got it all moving smoothly and soaked it as well. Diesel soak/scrub next.
  9. pprather
    pprather
    Sorry to see the Deuce go down the road, but this should be an interesting build. I'm following.
  10. jim1932
    jim1932
    Just registered this trailer my next door neighbor gave me 3 years ago. I may need to open it up to see if it is viable for the car....... if not al least there are two wheels and hubs LOL
  11. jim1932
    jim1932
    exercising patience on the one stubborn stud on this side, but motor looks good so far. The rtv on the head gasket on the other side is worrisome, but we will see.
  12. From here i can just see the shadow of hydraulic style brake backing plate so that makes it a 1939 Ford rear end. Finding everything so close to home is a blessing in this day and age. Time saving at its best.
  13. jim1932
    jim1932
    of course there are no gears in it and the springs are welded on........
    IMG_8315.JPEG IMG_8314.JPEG Nothing but water in the rearend. No gears either though. Wheels are good and have all the hub cap clips.
  14. jim1932
    jim1932
    Unless I run the wheels form the old wood splitter......LOL gotta love resourceful New England farmers.
    On the bad site the gears in the 39 Trans are all pitted and a tower fork is cracked. At least I got a 78 case and parts. Tempted to get his side loader trans to see if that has good gears in it.
    34 GAZ, enloe, Nailhead A-V8 and 9 others like this.
  15. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    May the wind be at your back.
    The road you've chosen will take you to unknown places.
    Enjoy the journey. No one can sell experience to you:)
  16. jim1932
    jim1932
    Yep... pitting on almost all of them. I only paid $150 so with a good case I figure I am OK. The guy had a side loader Trans too so I will check the gears on that one and maybe get one a good trans out of the two.
  17. Wanderlust
    Wanderlust
    Here’s hoping from a fellow scrounger:)
    At present I have the best bits of 5 side loaders cobbled together to keep my truck on the road:D
  18. jim1932
    jim1932
    wonder what this was.......
  19. jim1932
    jim1932
    My guess was a long sitting motor that they tossed new antifreeze in and got it running then pulled. Pretty green antifreeze, then this........ water pumps turn and look ok though.
    enloe, Okie Pete, porkshop and 5 others like this.
  20. jim1932
    jim1932
    I did get the stubborn stud out and 4 on the other side, then my stud puller fell apart. it did about 5 engines before breaking, so I wordered another. (Not that I have built 5 Engines, I took 5 apart, LOL).
    enloe, AHotRod, Okie Pete and 10 others like this.
  21. winduptoy
    winduptoy
    I won't say what that looks like Doctor....
    bio******, not fatal
    G Baese and Wanderlust like this.
  22. hotrodharry2
    hotrodharry2
    from Michigan
    Budget Build! Love it.
  23. jim1932
    jim1932
    I did say "cough"
  24. jim1932
    jim1932
    I guess I can keep track...$600 so far.
  25. oliver westlund
    oliver westlund
    Im game! Neat build
    chryslerfan55 and winduptoy like this.
  26. You're lucky! So much of the farmland here has been bought up over the last 25 years by the N.Y.C Watershed (New York City's drinking water comes from upstate) by the city people themselves, or for wedding venues and the homemade wagons from Ford parts have been s****ed! I was buying them when I found them.
    You can always tell when an old house or farm has been sold because the metal dumpster at is full of vintage stuff, I have saved a few things a set of 33/34 wishbones, an axle, 63-67 Corvette bumpers, and some old race programs from the newspaper container.
  27. jim1932
    jim1932
    My older neighbor is one of those guys that people call when they are trying to get rid of stuff, as he is willing to take stuff to fix some day. The trailer and the splitter are examples. His winter project was a 1920's tractor that had a frozen motor. Someone gave it to him. it is running now. He is very resourceful in finding, repairing or making obscure parts.
  28. jim1932
    jim1932
    Slowly tearing down the motor. All 48 studs came out. I did break one stud removal tool...LOL
    Looks like Standard pistons. Grabbed my hand crank and everything rotates like it should. The oil looked OK, not sludge filled. Dropping the oil pan next so I can get the pressure plate and fly wheel off. At that point I will decide if I take it all the way down and get it dipped and checked. I am not sure it will end up a "Budget" build, but certainly not a show build. I want something to play in the dirt with.
  29. jim1932
    jim1932
    Yes I need to clean out my garage....LOL
    Outback and hotrodharry2 like this.
  30. winduptoy
    winduptoy
    I don't understand this statement....
