C3 and newer Corvettes built for Racing With Turns
Discussion in 'Off Topic Hot Rods & Customs' started by snoc653, May 9, 2025.
  1. snoc653
    snoc653
    from Iowa
    Let's see some C3 and newer Corvettes used for road courses, rallies, and solo II type events. I have always had a fondness for racing with turns and momma's 81 Corvette has me reminiscing and dreaming at the same time. This car appears to have been ordered in Canada for someone to build a race car of some kind. I intend to get it back on the track with either myself or mamma driving. And as soon as I get the ***le work done and new VIN tags back on it, it will be driving on the street as well. Someone took the original VIN tags off the A pillar and Door jamb. The build plate on the door jamb matches the car and the VIN on the frame matches the car. So, I'm not sure why the tags are missing. But I don't want us getting pulled over with the VIN tags missing. They didn't inspect the car to ***le it, so I have plates for it. This is a web photo that is a cl***ic example of what Corvettes were meant to be.
  2. Kerrynzl
    Kerrynzl
    My ol' girl [nicknamed "the mistress"]
    1970 Roadster .125" over 454 [482"] dry sump, roller cam, ZL1 heads
    Quite low HP at 612 but 659 ft/lbs torque.
    Gutted out lightweight at 1170kg [2574 lbs]
    The highest terminal speed I got on a road course was 278 kph [172 mph]
    It has insane braking power
  3. Anderson
    Anderson
  4. snoc653
    snoc653
    from Iowa
    Awesome pics. I see both cars have hoods that vent air and fender vents that anre open. On my 80 I had in Germany the front would get very light at higher speeds until I got the air flow under control. I had the vents open with an oil and trans cooler in them and a cowl hood to let air out. I wound up using brake ducts to take air from the chin spoiler and vent it out through the wheels. The top louvers were not something I wanted to tackle with the fibergl***. You have to love a proper road course car.
  5. Kerrynzl
    Kerrynzl
    Mine bled off air from the grille via a slot in the cowl hood .
    The radiator got fed air from the air dam under all this ducting
    The rear was a parachute that was full of vents [there was a row of holes under the rear spoiler]
  6. chevy57dude
    chevy57dude
    Right away I thought about Greenwood Corvettes.
    snoc653 likes this.
  7. Anderson
    Anderson
    Some shots from the SVRA event at COTA over the years.
    CIMG5535.jpg CIMG5597.jpg CIMG5660.jpg CIMG5677.jpg CIMG5679.jpg CIMG5693.jpg IMG_3319.JPG IMG_3358.JPG IMG_0517.JPG IMG_0519.JPG IMG_0590.JPG
    foolthrottle, SS327, Ned Ludd and 3 others like this.
  8. SR100
    SR100
    Earl Pearson’s Super Production/Trans Am vette:
    porkshop likes this.
  9. Oneball
    Oneball
    Kerrynzl, snoc653, Deuces and 2 others like this.
  10. snoc653
    snoc653
    from Iowa
    That is a beautiful car! I am toying with thoughts of wide fenders, side pipes and some other handling upgrades if it turns out the car has previously been modified. If it is an original 52,000 mile car I'll probably leave it stock and let momma drive it.
    Oneball and Deuces like this.
  11. foolthrottle
    foolthrottle
  12. Anderson
    Anderson
    These two (and the first one I posted) are from the '77 24 hours of Daytona.
