Projects The "Red '34". 1934 Ford 5 window project.
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Dec 1, 2024.
  1. flamedabone
    flamedabone
    Sadly, a mechanical pump ain't happening. I'm not a big electric pump guy, but the alternator needed the space more than the pump did.
    -Abone.
  2. panhead_pete
    panhead_pete
    Thanks mate, been looking at relocating mine there due to changing up my steering and that was something I couldnt work out when I saw setups like yours.
  3. RodStRace
    RodStRace
    Lower rad hose is going to be interesting, too.
  4. flamedabone
    flamedabone
    Here we are, regular old Sunday night update.
    Set up the master and slave for the clutch. This is by far, the easiest clutch set up I have ever done. Simple, quick, no drama.
    Engages the clutch right in the perfect spot.
    Rear ladder bar kit.
    And there you go, the FlamedAbone US Military/rock crawler/monster truck style ladder bars. Good for about a 1000 horse more than the little small block makes.
    Now, the fun part. Quick changes are super simple to set up.
    Start by chillin'
    And grillin'
    Slam the two together and drill the retaining bolts.
    Cook the center section and install the pinion and lower shaft.
    Start ***embling the guts
    Shim the whole ****eree to 12 thou.
    Do the shim dance until you get 4 to 6 thou of pinion back lash.
    Real Magnesium Color, Eddie?
    Nuttin but the best, Clark.
    All together
    The 8 inch and leaf springs gotta go.
    Better already.
    Monster truck ladder bars ready for action.
    Yea!! A roller, finally, and the Quickie in her new home.
    Not sure what's next, but it will likely be somthin'
    See ya, -Abone.
  5. Tim
    Tim
    from KCMO
    Bang a rang!
    Stogy, rod1 and Tow Truck Tom like this.
  6. Robdski
    Robdski
    Sheesh, no over thinking, just getting it done.
    Looks great!
    Just Gary, Algoma56, Stogy and 3 others like this.
  7. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Gotta Love It.
    Admire your decisions and skill.
  8. rod1
    rod1
    Here's to A-bone. The Model 40s best friend.
  9. lothiandon1940
    lothiandon1940
  10. panhead_pete
    panhead_pete
    Wow whoever is going to end up with this will be happy. QC is a bonus!
  11. flamedabone
    flamedabone
    I'm sure there is an exhaust kit for a '34 Ford with a Chevvie, but I'm a roll your own kind of guy.
    Work around some obstacles, but nothing major.
    Man, this sure was a lot of hard work. It was..... exhausting.....
    Now for the shin catcher.
    Adios, mofo.
    Carve it up until it looks like it is supposed to.
    A little more high and tight.
    Shows off the quickie a bit.
    Not sure of the origin of this fire wall, definitely some sort of re-pop as it has a BIG *** distributor notch.
    Some of it had to go to fit the little Chevvie motor.
    And there you have it and not a single in progress shot. And, I'm out of welding gas, so tacked is all you get. Use your imagination and pretend that it is fully welded and metal finished.
    Next up is floor boards.
    See ya, -Abone.
  12. Tim
    Tim
    from KCMO
    Killer
    Tow Truck Tom likes this.
  13. panhead_pete
    panhead_pete
    That *** end came up really well. Nice job. @flamedabone did you cut that rear bar a few times to get the curve in it or bend it another way?
  14. flamedabone
    flamedabone
    Yep, that is a cut and weld job.
    -Abone.
  15. panhead_pete
    panhead_pete
    Thanks.
    chryslerfan55 and Tow Truck Tom like this.
  16. Robdski
    Robdski
    Looking Great!
    Thanks for the updates.
  17. Bad Bob
    Bad Bob
    from O.C. Baby
    The only guy I know who can make a sandwich out of 1/2 a slice of cheese! Must be nice to have the skills fix anything, lol....No matter how bad it is or whats missing. Love your builds, *****.
  18. Bad Bob
    Bad Bob
    from O.C. Baby
    Chop....No chop?
  19. My favorite part of these builds is that you hardly ever see any tools or equipment or anything in the pics? But then ****!!! Bad*** hotrod! Is like magic or something?! ;)
  20. Tim
    Tim
    from KCMO
    It’s all a “clean shop” filter lol. Blue screen magic
    ratster, Apenaut, drdave and 4 others like this.
  21. alchemy
    alchemy
    My Pop's coupe has a similar rear treatment, but the flange is removed.
  22. motoandy
    motoandy
    from MB, SC
    That looks super clean with a gangster lean.
    chryslerfan55 and jim snow like this.
  23. Keep the awesome updates coming.
  24. flamedabone
    flamedabone
    Alchemy, your Pop's coupe is a bad mofo.
    -Abone.
    chryslerfan55 and Thor1 like this.
  25. flamedabone
    flamedabone
    Floors aren't very exciting, but you gotta do em. I like to start just forward of middle to give the toe boards and trans tunnel something to weld to.
    Then, I like to finish the whole project and forget to take any pictures.
    Once the floorboard is done, that ****er is a whole car.
    From the FlamedAbone, Primitive Yet Functionable Collection (tm), here are the seat mounts.
    And, a set of store bought buckets. Yea, I know I'm kind of a bench guy, but I thought I might switch it up a bit for this one.
    The little car is now mostly mocked up with all the sheet metal attached, so that means this is probably the last pic you will see of the stock roof. All you " don't chop it" guys should quit looking at this thread, because I'm fixin to whack this pile.
    See ya, -Abone.
  26. Robdski
    Robdski
    Man-oh-Man, that is coming along nice!
    I sure hope you do***ent the chop. Thanks for sharing the progress!
    427 sleeper and panhead_pete like this.
  27. warhorseracing
    warhorseracing
    from cameron wv
    No more than 2" please. That is the perfect look IMO for these cars. Any more and they look too cartoonish.
  28. AmishMike
    AmishMike
    Chop seems good - question: extend roof or tilt windshield back? I like the tilt look
  29. ModelAMitch
    ModelAMitch
    Please do***ent the chop! Can't wait to see this.
