Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. gimpyshotrods
    gimpyshotrods
    I may be in rough shape right now, but I am absolutely blessed to still be alive.
    My guardian angel deserves hazard-pay.
    My friends used to make fun of me for buying expensive hard shell helmets.
    ...used to.
    little red 50, mohr hp, BJR and 16 others like this.
  2. Years ago when my stepdaughter started riding behind her (then) boyfriend she was using a piece-of-**** helmet that her dad had. Uh uh, says I. I took her shopping to get a REAL helmet that was certified and fit properly, and when she saw the price she commented about how expensive it was. My simple reply was "If you've got a $50 head put it in a $50 helmet. Otherwise get the best helmet you can afford!"
  3. duecesteve
    duecesteve
    My new wheels it reminds me of and old Triumph lol
  4. High test 63
    High test 63
    Lines are more like a 45" HD
  5. swade41
    swade41
    from Buffalo,NY
    Founds some old videos of me and the Henry J, so I spliced them together for this montage
  6. Marty Strode
    Marty Strode
    I have a friend with a Ruby 7, I will show him this ! Thanks.
    Sharpone likes this.
  7. Person should get 25 to life in a Mexican prison for this along with daily torture.
    Good luck with your recovery!
  8. More please
    mad mikey and Sharpone like this.
  9. milwscruffy
    milwscruffy
    The owner is putting miles on it and working out a few small bugs. Probably take another video when things are 100% dialed in.I warned him about a .660 lift cam and power brakes. I'll let him install the vacuum canister now ! :D
  10. jeepster
    jeepster
    from wisconsin
    Saw the J run at the Meltdown some years ago. Absolutely love it!
  11. Low-Blow
    Low-Blow
    This is what I am currently working on. It's called the Krystal Coupe because it was owned by the Krystal Fast Food Restaurant Chain. They purchased the car in 1982 for the company's 50th anniversary. I have a publication of the two owners sitting in the car, with the Krystal license plate (which I have) on the door.
    The build plans are as follows:
    * Original Henry 32 Frame
    * 276 ci Flathead with Supercharger & Dual Stromberg 48's.
    * 39 Lincoln Zephyr Transmission with later LZ Gears.
    * 36 Rear Differential with Quickchange Center Section (from Quick Change Mike in Oregon)
    * 7.60-16 Firestones out back with 6.00-16 Firestones up front.
    * 35 Wires with Lyon Caps
    * 32 Spindles Adapted to Repro 39 Lincoln Brakes
    * Dropped 32 Heavy Axle
    * Unsplit Bones
    * Goliath Shocks
    * No Fenders / No Hood
    My plan, as ambitious as it may seem, is to have it on the road by late September in time for Old North State Invitational, then TROG, then The Gathering at The ROC. We'll see how it goes!!
  12. jeepster
    jeepster
    from wisconsin
  13. patsurf
    patsurf
    hrm2k, alanp561 and Sharpone like this.
  14. saltflats
    saltflats
    from Missouri
    Celebrated 37 year anniversary and smoked a small 8 lb. pork shoulder for the wife and I.
    Have a planned trip to town tomorrow to take another swing of the axe on the 62 Biscayne project. May get lucky and get the transmission and shifter in.
  15. enloe
    enloe
    from east , tn.
    IMG_0771.jpeg I got the linkage hooked up
    The header installed
    tomorrow evening we will get it put on jack stands and top off the transmission dope. We will get the exhaust pipe hooked to the header. I have to put the rubber boots around the clutch arm and adjust the parking brake.
  16. nochop
    nochop
    from norcal
    Working on final ***embly IMG_7732.jpeg IMG_7721.jpeg IMG_7722.jpeg IMG_7720.jpeg IMG_7724.jpeg
  17. osage orange and Sharpone like this.
  18. Tickety Boo
    Tickety Boo
    from Wisconsin
    Happy Anniversary Salty :cool:
    Does SS stand for Salty Smoker? or Super Smoker? :D
  19. Eating high on the hog - literally. I saw a '62 Impala 409 driving through Belton yesterday and thought of you. Belton Cruise Night on the 24th so I'll look to see if it's parked on Main Street then and forward a pic if I see it.
  20. hrm2k
    hrm2k
    A traditional hot rod show is coming back to Latimore Pa. It was the Jalopy Showdown. Probably the most fun you could have with your clothes on…..some didn’t !!! Now, it’s the Hot Rod reunion. Since the only running car that I own is my Caddy, I actually cleaned it up. Washed it….3rd time in 11 years, waxed it ( paste wax, no sissy **** ) and even cleaned the interior. With 45802 miles showing, it cleans up well…..NOTE: paint is factory lacquer
  21. gimpyshotrods
    gimpyshotrods
    Mocking up the drive. Excuse the temporary hardware.
    I still need to put the pulleys in the lathe and take off an inch. There really is only room for a 2-inch belt, and that's on the way.
    I will need to spend some quality time in the hose aisle. The current upper hose would just touch the blower belt.
    It's a slow go, given my current condition.
  22. Dooley
    Dooley
    from Buffalo NY
    Getting the motor back in my car 20250515_183047.jpg 20250515_183044.jpg 20250514_192228.jpg 20250511_170000.jpg
    20250515_183047.jpg 20250515_183044.jpg 20250514_192228.jpg 20250515_183047.jpg brewing 20250515_183044.jpg
  23. dana barlow
    dana barlow
    from Miami Fla.
    Up date from #5255.
    New Master cly got here,did the bleed in vice,added to rod and bleed;to clean out old an add new,all 4 wheels,got pedal ,so test ride around block tommow. If all feels good,will finish cleaning a do show sunday AM/ Cars n Coffee at Internasenl Mall/Miami 8am to 10;30 AM= Good show;often 200 + cars;mostlyVetts n stuff like that,yet a few rods{ give or take,5 to 10 old school's
  24. Paul
    Paul
    Editor
    another refresh, this one a '57 371 Olds for a friend.
    hone, re-ring, hand polish crank, new rod bearings and lap valves.
    should be firing it up next week.
  25. chevy57dude
    chevy57dude
  26. mohr hp
    mohr hp
    from Georgia
    This is just too crazy, thank God you're still alive. I ride around my subdivision 4 days a week. I nearly had a head on with a neighbor in her new van 2 weeks ago, she was looking down at her phone when she got really big in front of me. I took an evasive to the smooth gr*** nearby, but I could tell she was pretty shook. You hang in there, and keep fighting through the rehab. I know you're pretty tough. Keep going.
  27. enloe
    enloe
    from east , tn.
    Well we got everything done on our list this evening.
  28. swade41
    swade41
    from Buffalo,NY
    I got the black beast fired up today, was the first time this year, last November I was able to get it around the block a couple times before it was put away into winter hibernation.
    No leaks so it looks like I have a green light to give it a few more shakedown miles and get it inspected so it's all legal like again.
  29. shorrock
    shorrock
    20230121_160438.jpg 20250501_162614.jpg 20250515_203744.jpg The serpentine belt that drove the blower and the clutch started slipping at 3500 last year. Due to the high tension of the lousy belt the waterpump bearing started to fail as well so the engine was pulled and modified. The french flathead was converted to a 2" toothed belt and made the blower ratio a bit faster as well. I ground the cam for a bit more lift by grinding the bottom lobe. Sounds angry and has a nice rumble. Now I have a small belt running pumps and alternator and the toothed belt for the blower. Managed to pack it very tight so the engine got only 1,5" longer. The 9,5" clutch was replaced by a 11" clutch so hopefully this will hold the power. The firewall was remodeled around 2,5" so there should be no space problem - will find out this weekend. View attachment 6401416 View attachment 6401416 20250501_162614.jpg 20250515_203744.jpg
  30. saltflats
    saltflats
    from Missouri
    Got the spacers cuts and new long bolt's also got the turnbuckle adjuster. Think it turned out pretty good.
