Reviving 1965 F100 Ranger field truck
Discussion in 'Off Topic Hot Rods & Customs' started by GlassThamesDoug, May 12, 2025.
  1. GlassThamesDoug
    GlassThamesDoug
    Working on getting this old dog running.
    Rough old steed. Has a V8 old style FE set up. ....rough rough rough.
    Rac****s won't catch it again. That mouse and rac**** mess is calling for a high pressure car wash.
    Bucket Seats Need redone
    1Nimrod, Gasser 57, Okie Pete and 4 others like this.
  2. Wanderlust
    Wanderlust
    Rough? That’s near pristine where I come from:eek: worked until unsafe for the road then given to kids to learn to drive around the farm and herd cattle till they won’t move anymore, pushed in the bush and robbed of parts, that’s how I find em:(
  3. GlassThamesDoug
    GlassThamesDoug
    Floors were patched, was a weird hill billy bucket seat set up, only thing it needs us a cooler out back, and 60ac of hay to bale.
    1Nimrod likes this.
  4. Wanderlust
    Wanderlust
    Guess we all have our own definition of rough IMG_0523.jpeg IMG_0565.jpeg what I brung home
  5. GlassThamesDoug
    GlassThamesDoug
    Bed looks nice on that. Like the rear bumper.
    Looks like a lot of Birch trees there... reminds me of WVa.
    1Nimrod and Squablow like this.
  6. GlassThamesDoug
    GlassThamesDoug
    I need a temp fuel tank out back, then run 4gal gas thru it, change oil & filter again after its all warmed up.
    Running good. Oil looks good still, runs about 1/2 way on temp guage sitting still.
    4 ways flash.
    Heater motor works...
    1Nimrod likes this.
  7. snoc653
    snoc653
    from Iowa
    I’ll second the sentiment of that isn’t rough. Yep it has a few custom deletes like the bed and parts of the floors, but it has straight-ish panels, most of the trim and all of the gl***. That is a find. Can’t wait to see her come back to life.
  8. gene-koning
    gene-koning
    Looks like a really good starting point!
    I never had that good of a starting point.
    Could be a fun project.
    What are your long term plans?
    The old motor turns over & could run??? What a score!
    An old fuel cell or boat gas tank (or a 2 gallon gas can) would supply enough gas to get it running.
  9. GlassThamesDoug
    GlassThamesDoug
    I guess its relative to how these vehicles handled ed rust. I found steering wheel horn retainer online. Wonder horn ring is not busted. Somebody commented they liked the auto column. Radio is missing, but it evidently had one at one time.
    1Nimrod and Okie Pete like this.
  10. gene-koning
    gene-koning
    The bucket seat tracks could have come with the bucket seats. The other brackets are probably for a center console and could have came with the console. Lots of newer trucks have carpet, bucket seats, and consoles. Bench seats are pretty hard (and expensive) to come by that fit into old trucks.
    I have not seen anything I would consider as outside of normal, in an old truck, up to this point. What I see is a truck that did its service and was turned out to pasture, then someone though it would be a great cruiser (or work truck for themselves). They pulled it out of hibernation, patched up the floors, probably redid most of the mechanical stuff, replaced the shot seat with something they had, or found, and made it a usable truck again. It probably outlived their use, and got parked for you to find. There may have been many owners between the guy that bought it new, and the last guy before you, that had a hand in making it survive this long. What has been done to it in the past may be an interesting journey, but the most important thing to us is what you plan to do with it.
    Its your turn to make it the ride in your vision. You could redo what the last guy did, or do something completely different. Its an open canvas that is a great starting point for you to create from.
    So, what are your plans with the truck? What do you want it to be?
    Just a few examples for you. One guy (here on the HAMB) that uses a truck about the same year as your truck, to work on a 200+ mph Bonneville Salt Lake record. A different guy (here on the HAMB) is using his similar truck as a daily driver that is well past the mid point on a 3,000 mile road trip, right now!
    1Nimrod and GlassThamesDoug like this.
  11. GlassThamesDoug
    GlassThamesDoug
    Always liked bench seats in trucks, they were usually the best choice.
    1Nimrod likes this.
  12. GlassThamesDoug
    GlassThamesDoug
    Grandpa always liked his 352s.
  13. sheza65
    sheza65
    from Utah
    Nice! It looks clean to me.
    1Nimrod likes this.
  14. sheza65
    sheza65
    from Utah
    Are you going to find an original bed or make it a flat bed?
    1Nimrod likes this.
  15. GlassThamesDoug
    GlassThamesDoug
    Not sure. Flatbed might be easiest.
    1Nimrod likes this.
  16. gene-koning
    gene-koning
    A flat bed until you can find a replacement bed is a good idea. You can drive the truck while you look for a bed in good condition, then replace the flat bed on your own time frame.
  17. GlassThamesDoug
    GlassThamesDoug
    Looks like it could be nice if restored to this level.
  18. vtx1800
    vtx1800
    compared to my "slick", yours is pretty nice, mine is a 1962 unibody, lots of rust:(
    GlassThamesDoug and 1Nimrod like this.
  19. gene-koning
    gene-koning
    Could be restored, but what fun would that be? Hauling (not driving) it all over the country to enter in shows where everything is awarded by how perfect it has been redone, and hanging around a bunch of guys that are only interested in how much the truck is worth and how much it cost to to get it into the condition its in. To do well in that game, everything has to be do***ented. If indeed it was some early dealer promo for a future option, how will you be able to prove that? Unless you can prove the seats and console are a per-production promo, a real points award show will deduct the "incorrect seats and console" from your point total, and the other show guys will look down on you for not accurately restoring your truck. Doesn't sound like too much fun to me.
    I can't imagine how expensive it would be to restore that truck into an award winning prize. Every part would have to be period correct Ford NOS or reproduction parts. If the Ranger guy thinks it should be restored, tell him to give you a better condition equivalent truck and then he can have the one you have and he can restore it. I'm betting he will p***, he just has parts he wants to sell you.
    Sorry, my suggestion to you is to build it to what ever level and style you want (and can afford). Then drive the wheels off of it and enjoy the journey.
  20. GlassThamesDoug
    GlassThamesDoug
    Shows can be painful.
    1Nimrod, ALLDONE and ottersea like this.
  21. GlassThamesDoug
    GlassThamesDoug
    I do have the gold options tag, it has Bucket seats and Radio on it. It matches SN on door tag. Ford Truck Guy sent back note 9" Ford rear 3.25 ratio. Auto Trans, 352 2V. Bucket Seats, Console Custom Cab. Shipped without paint, painted at Dealer. Short wheel base as well, probably not designed for hauling much.
    1Nimrod likes this.
  22. SS327
    SS327
    Never knew ford had a bucke seat option on those trucks.
    1Nimrod, GlassThamesDoug and porkshop like this.
  23. GlassThamesDoug
    GlassThamesDoug
    I had not previously ever saw one in person. Kinda like the Chevy Buddy Seats. I heard they used Falcon Car seats?
    1Nimrod, porkshop and SS327 like this.
  24. GlassThamesDoug
    GlassThamesDoug
    Today:
    - Replaced Horn Ring retainer.
    - Door locks lubed, orig key actually works.
    1Nimrod, porkshop, loudbang and 2 others like this.
  25. GlassThamesDoug
    GlassThamesDoug
    Found this still wired to inside of drivers door.
    1Nimrod, SS327 and porkshop like this.
  26. RodStRace
    RodStRace
    Sounds like a neat truck. Glad you got it running already.
    The seats didn't surprise me near as much as the 'shipped without paint' thing. Was that really a thing?
    As said, if it's really a special from factory, see if someone is willing to step up and take the reins for a historic resto, but it's your truck to do your way.
    What happened to the pics? I thought you had included one in the original post.
  27. GlassThamesDoug
    GlassThamesDoug
    Carb kit & Ign Switch has arrived.
  28. GlassThamesDoug
    GlassThamesDoug
    Carb inspection and Update.
    Economize Valve (power valve) was bad.
    Accel Pump diaphragm was bad, spring was reversed.
  29. GlassThamesDoug
    GlassThamesDoug
    Color under primer is Gold/Bronze.
  30. GlassThamesDoug
    GlassThamesDoug
    Going to rip rest of gold carpet out. Need to soak floor with good soap, smells so bad.
    I see the Rear springs are available at General Spring.
    Change oil today.
