Technical 49 mercury exhaust
Discussion in 'The Hokey Ass Message Board' started by MercMan64, May 14, 2025.
  1. MercMan64
    MercMan64
    from Taylor mi
    Hey guys, looking for some good insight. I’ve been plugging away slowly at my 49 4 door. I’m quickly approaching the “it needs full exhaust” stage. The car has been lowered 4” in the rear and roughly 3” inches in the front with a set of Aerostar springs. I’ve got a set of lake pipes on it currently but have been planning to run it all the way out the back. I’m currently waiting on a set of reds headers to be delivered. However I need some insight. I plan to open up a few of the wholes in the stock cross bracing in the frame to keep the pipe tucked up higher, however I’m scratching my head on fuel tank clearance. The tank is offset to the drivers side of the car to compensate for the spare tire well. I still want the tank to be serviceable but I don’t want the tips to be pushed all the way to the outside of the body but I also need to ensure clearance with the ground with the car being lowered. Also entering splitting the pipes off to keep the lake pipes. IMG_7605.jpeg IMG_7638.jpeg IMG_7438.jpeg
    winduptoy likes this.
  2. Greg Rogers
    Greg Rogers
    Wow, not much room under there, huh?
    you make these oval holes on the other side.
    Exhaust runs thru the frame
    Make the tailpipes unbolt if worried about the tank
    Truckdoctor Andy and winduptoy like this.
  4. Connect the exhaust with these are something similar and you can service whatever all ya want
  5. MercMan64
    MercMan64
    from Taylor mi
    It’s not much, I can’t even get my floor jack under the car. I suppose the big thing I’m worried about is driveways. The lake pipes drag backing into the driveway here at the house
  6. MercMan64
    MercMan64
    from Taylor mi
    That was my plan, I do like the idea of the band clamps
    anthony myrick likes this.
  7. 2devilles
    2devilles
    Here's mine, front to back. Hope this helps.
    IMG_3318.jpg IMG_3317.jpg IMG_3316.jpg IMG_3315(1).jpg IMG_3314.jpg IMG_3307.jpg
    lostn51, winduptoy and 51 mercules like this.
  8. lostn51
    lostn51
    from Tennessee
  9. 2devilles
    2devilles
    Not at all, or at least they're close enough that it isn't noticeable to me or anyone else. If one was waaaay back and the other was in front, sure, but these aren't that much different on a mellow Nailhead....I think the fact the tailpipes are close in length from the end of the mufflers matters a lot more than whatever is ahead of them....I've got an F100 that the driver's side is about 5 feet longer in length than the passenger side (both pipes have to run down the passenger side since the gas tank is on the driver's side, so the driver side leaves the header, crosses over to the passenger side, then down the passenger side, then crosses back over to the driver side for the exit), and on that there's some difference for sure, but it's loud enough nobody notices it but me when it's bouncing off of buildings.
    lostn51 and winduptoy like this.
  10. 302GMC
    302GMC
    from Idaho
    When the cars were still fairly new, like '60s, we used 2 stock tailpipes. Cut crossmember holes to match stock side.
