Projects 1938 plymouth coupe project
Discussion in 'The Hokey Ass Message Board' started by gas man, May 7, 2025.
  1. lemondana
    lemondana
    from Lincoln NE
    Slant 6's don't fit in these cars very well. The 3.9 V6 would be better but no aftermarket support. Good small block Mopar will work as well as any. Don't need no stinkin Chevy in it! I look at a lot of old Mopars on you tube and for sale cars. If it has a Small Block Chevy-I scroll right on by. JMO!
  2. caprockfabshop
    caprockfabshop
    especially with the quick-access gun storage: bs46pm3-gun-cds.jpg
    lemondana, bobss396 and vtx1800 like this.
  3. Dooley
    Dooley
    from Buffalo NY
  4. 1930artdeco
    1930artdeco
    from Lynden, Wa
    Great looking car! Rebuild the brakes and with a stockish engine you will be fine in todays traffic-as long as you drive within the car's rated specs. I have become a much better driver due to me driving my Model A with stock brakes. I make sure I know what other drivers are going to do before they do. Obviously, disks are better though and if you can I would.
    Mike
    osage orange and lemondana like this.
  5. I’d rock that flat 6 amd drum brakes.
  6. RodStRace
    RodStRace
    To my mind, any time you do a swap, as in an engine/trans that wasn't stock or has bolt in access, it better be worth the effort. The slant is a good engine in a light weight car, but isn't a huge jump from a flathead six. For the same effort, you can put in a V8 and get similar MPG, more power, better resale.
    It's not as supported for swaps, so it's actually a bit more difficult.
    So quick, easy and satisfactory for many uses, flathead.
    Step up, more gears in the trans
    Step up from there, V8 auto
    Step up, V8 stick
    Further is modified V8s or more esoteric stuff for the wow factor.
  7. gas man
    gas man
    from socal
    It's only hot 3 months out of the year to the point where I would want a.c. and I just avoid driving it on the blazing hot days.
    I'm going to run a 230 flat 6 from a 59 dodge truck. I will be keeping the stock brakes for now.
    I've been working away on the fenders. I hate working with body filler.
  8. Kosmos55
    Kosmos55
    Listen to Mr. Myrick. Keep it ‘30s/‘40s and get it low as possible in the rear.
    And remember, real hot rods have 3 pedals.
    Cool car by the way.
    osage orange and anthony myrick like this.
  9. Grumpy ole A
    Grumpy ole A
    Nice find on the car. The flathead 6 is a good motor. Keep us informed on your progress.
  10. glendale
    glendale
    that was a buddy's car. I installed a t5 and dual carbs on it. it was a fun car to drive.
  11. SLIPPERY SLOPE!
    Ben
  12. caprockfabshop
    caprockfabshop
    What transmission you going with? The 1959 truck transmission may not fit in the 1938 ch***is physically.
  13. Wher ya located at. A friend has a 33 Plymouth flat 6 and trans pulled from a running car.
    Complete set up
    Birmingham Al
    Ive got a desoto fmat 6 and trans
    and there are overdrive versions for the 3 speed
  14. RodStRace
    RodStRace
    Anthony, says So Cal. :oops:
    anthony myrick likes this.
  15. Jeff34
    Jeff34
    ‘38 Plymouth brakes are fine. My old ‘36 Ply sedan had them and stopped great.
  16. Long way from bama
    RodStRace likes this.
  17. RodStRace
    RodStRace
    A fair piece, I reckon.
  18. I had a guy in my neighborhood in the 50's who put a new 57 Cad dual quad engine in a 38 Plymouth coupe, he did it to fool everybody at the stoplight races. But when it's all said and done you are going to wind up with a 38 Plymouth which was never hotrod material.
  19. ^^^ must still be bitter about getting dusted by an old Plymouth :)
  20. gas man
    gas man
    from socal
    I think im going to go with bags in the rear. Lower the front to driving height and tail drag the rear when I want. Now the question is call nostalgia sid to lower my plymouth axle or go with a chevy drop axle.
  21. Sid stopped doing drops full time
    The Plymouth is a hollow tube
    Might have to try the forged Chevy
  22. choptop40
    choptop40
    Can you relocate perches , flip ontop of springs , fab up shorter bump stops . Might work !
  23. gas man
    gas man
    from socal
    Bummer. I really want to keep my front end plymouth. Id like to lower it 4 to 6 inches in the front. Got any ideas ? Chevy axle ends reamed to fit the plymouth king pin and spindle ?
  24. gas man
    gas man
    from socal
    Axle can't go on top of springs. Tube axle will hit the oil pan
  25. Well, a friend of mine claims he used mopar spindles on a ford axle.
    Those are transverse spring
    I have seen a mopar with a ford style x-member and axle set up. But would probably need a front style spring to clear the engine. Just spitballing
    Those can be bought reasonable and stretched
    There’s other folks that drop axles besides SID
  26. But then ya got this
    screen shot from a video of a guy building a 38 Plymouth
    Looks like a regular aftermarket tube axle. Those can be found with either ford or gm king pin options
  27. earlymopar
    earlymopar
    I wonder if there might be dropped spindles available that could be adapted to the double-dip?
  28. earlymopar
    earlymopar
    I know Butch's used to make quite a few pieces for 30's era Mopars but closed in 2022 after 37 years. It appears at that time the remaining inventory was sold to another business as noted here:
    Hot Rods - Butch's cool Stuff | The H.A.M.B.
  29. Dos Cincos
    Dos Cincos
    Things have escalated quite quickly by the looks of these pictures.
  30. gene-koning
    gene-koning
    Dodge 1/2 ton trucks used a solid beam axle up through the 1971 model year. I have no idea how, or if a drop could be done, or if it would even be needed. Those 68-71 Dodge trucks had great drum brakes with the correct wheel bolt pattern.
    Maybe just another option.
    A dropped Ford axle converted to the parallel leaf springs may be a good option too. With those you could keep your Plymouth spindles.
    tr_rodder likes this.
