Delivering the Kiwi goods.
Discussion in 'Off Topic Hot Rods & Customs' started by woodbox, Dec 8, 2024.
  1. woodbox
    woodbox
    You were right on the money JW! It had been a couple of busy days.
    After removing the panels from the mol***es bath I set to with sander, wire wheel, scotch pads and stripping wheel.
    While the hood went in the mol***es looking like this......
    ...After mechanical and chemical intervention it now looks like this!
    I have broken the hood down to its component parts to enable the application of paint and removal of flash rust behind the frames.
    I am really impressed with the job the mol***es does and the over all condition of the panels, dented all over the place but not so much as a pinhole of rust right through any panels.
    This afternoon I have done a rust kill acid wash over all of the panels and wiped them down ready to apply etch primer tomorrow. IMG20250509171325.jpg
    A little bit of lead in a couple of spots, a few holy patches where the screws have been used to straighten! IMG20250509171312.jpg
    So, etch and epoxy going on in the morning.........
  2. KiwiGlen
    KiwiGlen
    It's looking great. Very impressive work. :cool:
    Glen.
    26 T Ford RPU and woodbox like this.
  3. 26 T Ford RPU
    26 T Ford RPU
    A lot of those panels look so good they look like repro's. :cool: JW
    woodbox likes this.
  4. woodbox
    woodbox
    Today we picked up the ch***is from the painter. So after a major shuffling of the deck chairs it is back in the shop, down side up on stands so I can add the UHMWPE strips to the underside of the rails without having to lay on the floor.
    Black, shiney and coated in dust from the unpaved road.
    The package of UHMWPE turned up on the courier as I was unloading the ch***is.
    Slung on the hook to get off the trailer.
    All the ***ociated pieces in the back of the ute.
    Back on the stands ready for the strips to be fitted.
    One side done.
  5. SS327
    SS327
    What are those strips for? Never saw those before.
  6. woodbox
    woodbox
    High density polyethylene for when the bottom side of the ch***is inevitably comes into contact with the ground when around speed humps I can happily drag the car over them without damage to the car.
  7. woodbox
    woodbox
    I had a couple of pieces of off cut material, so made a couple of narrow strips to go under the center cross member as well.
    All done with the UHMWPE strips now so time to flip it over and get back on the job.
    First up is sorting out an issue on the diff then blow some paint on it before final fit-up.
  8. Zuffen
    Zuffen
    from Sydney
    I like your chopped sticker in the window of the Ute.
  9. woodbox
    woodbox
    That one? From our last trip to visit friends on Kauai island in Hawaii.
  10. woodbox
    woodbox
    Time for a catch up.
    After a full epoxy rebuild, the diff is back in its spot, rear bumper and trailer hitch receiver bolted on, rear engine mount bolted to the frame, front cross member and swaybar/radiator support mount back on.
    To hold the diff cradle onto the frame is 4 x 14mm bolts with 6mm rubber under the washer and between the ch***is and cradle to minimize transmission of noise, I also put a layer of heat shrink on the shank of the bolts to also try to avoid direct contact with the ch***is.
    With the diff done, for now, I moved my attention forward to the front cross member.
    Once I bolted the cross member back onto the frame I started to re***emble the arms etc. Getting the main pivot back through the cross member and lining up the washers was made a lot easier with this bullet that threads over the nut end of the shaft.
    Machined and tapped to fit over the 9/16" thread.
    Once the shaft is in position the bullet simply unthreaded and landed in the drawer with all the other specialty tools
    One each of these 2 go between the bush and the cross member tube, then the small hole one goes under the castle nut.
    Continuing with the ifs parts, the obligatory reference picture for later.
    All the bits have been through the mol***es bath and are now getting a comprehensive and thorough epoxy rebuild! Don't worry, I have ordered new top and bottom ball joints.
    More ***embly tomorrow.
  11. 26 T Ford RPU
    26 T Ford RPU
    Very impressive Wade.:cool: JW
    woodbox likes this.
  12. woodbox
    woodbox
    Apologies for the absence chaps!
    We took a week off and spent it laying on a few beaches in the middle of the Pacific Ocean!
    While we watched a few sunsets.
    It wasn't all margaritas and sunsets though.
    Back to reality now and back on the job getting the ch***is ready for our indoor event 2 weeks away.
    Swapped another SBC with b&m blower on it into the ch***is.
    Better looking than the mock up engine anyway.
  13. woodbox
    woodbox
    Driveshaft painted, re***embled and back in the car today. Trailing arms painted, ready to go back on tomorrow. Then a couple more bits on the front so we can steer it at the venue for the show next week.
    Okie Pete, Deutscher, James D and 4 others like this.
  14. 26 T Ford RPU
    26 T Ford RPU
  15. woodbox
    woodbox
    Running out of jobs on the ch***is now!
    26 T Ford RPU likes this.
  16. woodbox
    woodbox
    Delivering the kiwi goods today! A sneak peek for the team.
    On a set of borrowed wheels and tires from a club members 57 nomad.
    A couple of small jobs to do on the rear bumper over riders/tow hitch points.
    No front springs yet, just sitting on the bumpstops. Like a snow plow!
    I am painting the radiator support bracket and a 6 cylinder radiator out of the coupe to help complete the look.
  17. KiwiGlen
    KiwiGlen
    That's looking great! I can't wait to see it in person at the show next weekend. :cool:
    Glen.
  18. 26 T Ford RPU
    26 T Ford RPU
    Looking super nice, pics of it at the show please and get Glen in one if you can.:rolleyes::cool: JW
    woodbox likes this.
  19. Deutscher
    Deutscher
    from Germany
    Wow, what a great job.
    Regards Harald
    woodbox likes this.
  20. woodbox
    woodbox
    I will see what unfolds!
  21. woodbox
    woodbox
    Cheers Harold. It keeps me sane!
    26 T Ford RPU and Deutscher like this.
  22. woodbox
    woodbox
    On the trailer and on the way to the hot rod round up.
    All set up with the flock ready for the beady eyes in the morning.
    Nice little comparison, from run-about, to racecar! My friend set up his 27 roadster next to mine!
    The ch***is looks pretty good too!
    Looking forward to a couple of days of talking **** and hanging out with our car mates at the show.
  23. 26 T Ford RPU
    26 T Ford RPU
    Looking good, Have a great weekend. :cool: JW
  24. KiwiGlen
    KiwiGlen
    My eyes are already beady o_O
    I'm just waiting for 9.00am now! :cool:
    See you later :)
  25. woodbox
    woodbox
    A great couple of days at the round up. All packed up now and back home in the shed. IMG20250621141937.jpg
    We had a great time shaking hands and talking cars.
    The ch***is got a piggy back ride home behind the coupe.
    The fleet all out and about made the workshop look a bit empty.
    The club did an amazing job all weekend.
  26. 26 T Ford RPU
    26 T Ford RPU
    A good looking show and no doubt you will get some more well deserved ink in one of our Mags.
    For those who don't know ,Wade and better half are front left. :cool::D JW
    KiwiGlen likes this.
  27. 26 T Ford RPU
    26 T Ford RPU
    I don't think i showed you this one, was at a swap meet/car show at Fielding ten ago. JW
  28. Fantastic work!
    woodbox likes this.
  29. KiwiGlen
    KiwiGlen
    It was a great show, I really enjoyed it :cool:
    Glen.
    woodbox likes this.
  30. woodbox
    woodbox
    This one belongs to Tony and Tina from Timaru now, Tony is the nzhra president.
    KiwiGlen and 26 T Ford RPU like this.
