Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. Tim
    Tim
    from KCMO
    Yeah I’m just wondering if the banjo fitting is threaded you could put a different kind in.
    Six Ball and winduptoy like this.
  2. winduptoy
    winduptoy
    IMG_20250508_094223567~2.jpg braided stainless flex line with a mpt on one end and a flare on the other.
    I made up the carb inlet brazing the male flare on the ell inlet line...
    Clear as mud?
  3. Oneball
    Oneball
    You can get pre bent fuel hose, decide what angle you need and google say 45 degree fuel hose.
    winduptoy and Six Ball like this.
  4. Crusty Chevy
    Crusty Chevy
    I have inserted a piece of steel brake line inside the rubber hose then I can bend it to make it go the way I want it to. It comes out looking like a preformed line but is just the regular stuff off the roll from the parts house.
    enloe, Six Ball, winduptoy and 3 others like this.
  5. GirchyGirchy
    GirchyGirchy
    from Central IN
    Could use ni-cu as well, it's easier to work with.
    Six Ball, Kelly Burns and RodStRace like this.
  6. trevorsworth
    trevorsworth
    The old Jeep carbs I got for my car had brake line fittings inserted at the inlets to make the 90 degree turn. I guess the last guy was using steel brake lines for fuel.
  7. oliver westlund
    oliver westlund
    Bend a piece of hard line, cut the rubber line shorter, double flare the rubber hose end of the hard line and use a correct threaded fitting on the other end, slip the rubber hose ontp the hard line which is bent enough to fix your angle and put on a hose clamp. That or unscrew and rotate your fuel pump top
    Six Ball and Weedburner 40 like this.
  8. Untitled.png In my mind this makes sense, can you run a little longer piece and "roll" it or "spiral" it, between the two? You may go from a 2" piece to a 5" pieces of hose??
    And just me being picky, I would turn your hose clamps so the "extra" piece is pointing down and towards the intake, for a smoother, clean look.
    tr_rodder, enloe, The 39 guy and 7 others like this.
  9. Six Ball
    Six Ball
    from Nevada
    Who woulda' thunk there were so many options?
    Tim and winduptoy like this.
  10. 51504bat
    51504bat
    enloe, J.Ukrop, Outback and 2 others like this.
  11. Six Ball
    Six Ball
    from Nevada
    I hate seeing those old places go. They probably had square nails & Russel knives.
    J.Ukrop, Outback, Tim and 1 other person like this.
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Hi all, I'm back! Over the weekend, I celebrated my 32nd birthday with 31 friends in the backyard of our historic San Francisco apartment. IMG_9315.jpg
    It was a true feast with friends, and I was even able to bring back the now infamous Terrace Times bar that some may recall from the early days of this thread.
    Now that I'm a little bit older, I'm excited to post some updates.
    My actual birthday was on Monday, and I had the best day with Gen hiking Mt. Tam and eating BBQ oysters at the Marshall Store. When I got home, I knew I had to do something on the roadster. As luck would have it, my br*** terminal nut arrived in the mail. As easy box to check, but progress is progress!
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    The next update comes from down south. Last month, I reached out to @Dennis Lacy about making a battery box for the car. "No problem," he said, "but you do realize the master cylinder will be in the way?" I wasn't aware that his usual kit locates the battery near the pedals. Being that cl*** act that he is, he made a custom right-side mount for me. This will help me run shorter cables when it's time to wire. He's wrapping up painting and shipping it out this weekend! If you're looking for a setup like this, give him a shout.
  14. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Last two items for tonight:
    1) I figured out the fuel line. The fuel pump is indeed clockable. Thanks for the tip!
    It'll be getting a slightly longer piece of hose, and the clamps will get flipped next time I'm down in the garage.
    2) Traditional watermelon carrier, patent pending.
    That's all for now! This weekend, I plan to put in a lot of hours on the car, and maybe even stop by Pac Heights Hardware.
    Upcoming tasks include:
    • Installing radiator brackets
    • Installing radiator, hoses, grille shell, and headlight bar
    • Install p***enger-side header
    • Ride my motorcycle
    • Finalize fuel pump stand
    • Drink a cola
    • Sit in the sun
    • Torque and cotter all backing plate bolts
    • Torque more bolts
    • And much, much more!
    Oh, and Petaluma swap meet for a little bit on Sunday. See ya there?
  15. winduptoy
    winduptoy
    Happy belated birthday Joey....or early for next year.....you, young man, are living the dream...
    carry on!
    41 GMC K-18, Outback, J.Ukrop and 4 others like this.
  16. 51504bat
    51504bat
    And use a wide five for Texas size melons?:cool:
  17. Jeff34
    Jeff34
    Hope to see you there!
  18. Happy Belated Birthday, enjoy working on the roadster this weekend
    41 GMC K-18, J.Ukrop, Outback and 2 others like this.
  19. Dan from Oakland
    Dan from Oakland
    Is the plan to access the battery thru an opening cut in the seat pan on the p***enger side or ??
  20. Tim
    Tim
    from KCMO
    That sounds like a plan for back to back excellent weekends!
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    It will be accessible through a cutout in the floor on the p***enger side. I'm going to make a little trap-door panel for it.
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    What a whirlwind of a weekend. It was filled with hot rodding on Friday, Saturday, and Sunday. I'm leading with a picture of this vintage Craftsman brake fitting wrench because I thought I mislaid it. Come to find out it was in the top tray of my toolbox the whole time.
    On Friday night, I bolted on the radiator brackets and put my new Johnson's radiator into position. At that point I realized that a few things needed to be adjusted. First, the lower hoses were about two inches too short. Second, the radiator needed to go back an inch to be closer to the fan. I had everything roughly mocked up in the fall, but now that I'm finishing the car, it's important to get this right.
    With the sun out on Saturday morning, I made my marks and adjusted the brackets.
    Clean bracket install.
  23. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Next, I called a couple of parts stores looking for 1-3/4 radiator hose. As luck would have it, my local O'Reillys had three feet in stock. IMG_9456.jpg
    A quick rip over and I was in business.
    One of the newer employees took interest in my roadster project. He has a 1954 Chevy, and he told me to drive the A-V8 over when it's finished. I promised him that I would.
    Back at the house, I bent the new brake line that will slip under the radiator hoses. Backyard hot rodding. IMG_9462.jpg
    And front door hot rodding too. Here I used the school's fence as I created a brake line support tab.
    Oh, and the vise too.
  24. Tim
    Tim
    from KCMO
    One piece at a time! Good stuff your getting cloooooose
  25. denis4x4
    denis4x4
    from Colorado
    I would highly recommend installing remote battery posts and a battery switch. I jump started a dead Subaru using the remote posts and made the owner take a photo! DO NOT use the cheap plastic battery switches. Too, buy the mouting bracket for the remote posts, makes for an easy installation.
  26. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Sorry, I wasn't able to finish my upload last night.
    And here we have it. The whole process took longer than anticipated. Looking at this picture, you'll notice the correct fan-to-radiator clearance (about one inch), the shortened upper radiator hoses, and the new brake line. It's spring-wrapped to protect it from rocks and vibration, and I made sure there was ample clearance for any radiator movement.
    IMG_9536.jpg Best of all, you can remove the brake line without removing the radiator, and remove the radiator without removing the brake line. This thing will inevitably be coming apart, so I'm planning for the future.
    Next, I'll be m***aging the grille shell to improve the fitment. That's all for now!
  27. Mikko_
    Mikko_
    from Sweden
    Getting there, piece by piece.
  28. Tim
    Tim
    from KCMO
    Good stuff man, lots of little details that a guy will keep finding every time they stop and look at your car again
  29. GirchyGirchy
    GirchyGirchy
    from Central IN
    That's true for nearly everything I've ever worked on.
    Great work, it's a pleasure following along.
  30. Six Ball
    Six Ball
    from Nevada
    For the battery "trap door" I plan to use the lid and part of the metal floor board from a '47-'54 Chevy?GMC pickup. Partly because I like the way they work & look and partly because I have them.
