Projects Glass '32 5 Window
Discussion in 'The Hokey Ass Message Board' started by Splitbudaba, Feb 6, 2017.
  1. Splitbudaba
    Splitbudaba
    New Towel City Cheater slicks arrive tomorrow. Right door is almost ready to hang. Latch and handle were a challenge. Had to install a 1/2"x1/2" aluminum angle to stiffen the inside panel.
    shortypu, swade41, brEad and 3 others like this.
  2. Splitbudaba
    Splitbudaba
    Just got my new Towel City Cheaters. Very cool. Now
    to get them mounted. PXL_20250516_221842841.MP.jpg PXL_20250516_221846921.jpg
  3. Tim
    Tim
    from KCMO
    Awesome!
    Kelly Burns likes this.
  4. Splitbudaba
    Splitbudaba
    Got them mounted. A guy at the tire store has a drag Nova. Gave him the old slicks. Stabbed one on. I like it!! PXL_20250519_181554622.jpg PXL_20250519_181601976.jpg
    catdad49, shortypu, Just Gary and 9 others like this.
  5. Bandit Billy
    Bandit Billy
    Yeah, that's a great tire. You will like the way they ride and perform. I have zero complaints with mine. I guess if I got real damn picky, I would like the side walls polished. They are kind of grooved and don't look bad but If I had a preference, I would like them polished. I have done some tire de-lettering and polishing but not on that sort of surface. I could mess them up irreparably, so they are best left be. Nice choice on rubber.
  6. Splitbudaba
    Splitbudaba
    Thanks! I plan on polishing my side walls. Starting with the inside first, just in case! I have a feeling the outer sidewall is ground in case you opt for a white wall. I was debating spinning the rear at idle, while lightly hitting the surface with my DA sander, starting with 220 grit and work my way up. Stay tuned!!
    loudbang and Bandit Billy like this.
  7. Bandit Billy
    Bandit Billy
    I'll be watching. Smart idea starting with the inside. I think this will really make them look sharp. I lubricated the sandpaper with armor all instead of water. Not sure if that helped but in my mind it did. :cool:
    Just Gary, brEad and Splitbudaba like this.
  8. Splitbudaba
    Splitbudaba
    I will try that armor all, water, wd40. Different grits sandpaper. Maybe a sanding block instead of a DA.
    Bandit Billy likes this.
  9. Splitbudaba
    Splitbudaba
    Anybody running these towel city 1000x15 cheaters have any pressure recommendations?
  10. Bandit Billy
    Bandit Billy
    You will have to experiment with the weight of the car, ride desired and usage. I am down to 25 PSI. They have a stiff sidewall, they don't need a lot of air. But due to the stiff sidewall, you need to be vigilant about pressure. I had one with a hole in it and almost zero pressure that was barely noticeable from mere observation. Local tire shop had no issue repairing it BTW.
  11. Splitbudaba
    Splitbudaba
    Thanks, gives me a place to start. Good tip on the pressure check interval. I haven't had the car on scales yet, but I think I shouldn't wait too long.
  12. Splitbudaba
    Splitbudaba
    Tire balancing day, fun leveled the fixture. Fun, then level the base. Place the weighs, stick them on check the balance, clean them up, and put them on. Test drive soon. PXL_20250523_180717489.jpg PXL_20250523_180721628.jpg
    catdad49, shortypu, Just Gary and 6 others like this.
  13. Splitbudaba
    Splitbudaba
    Well found another screwed up body detail. Check out the rear vertical post width at the top and bottom. No big deal, 10 minutes with a jigsaw, a piece of duct tape, some resin with some gl*** fibers and some finish bodywork and away we go. That's what a cheap body kit is like. Good I am not bad at fibergl***! PXL_20250601_000112948.jpg PXL_20250601_000124074.jpg
    Just Gary, swade41, brEad and 4 others like this.
  14. Splitbudaba
    Splitbudaba
    Going to hang the right door tomorrow. Finished up all structural gl*** work and a little body work. Primed it, have the latch and handles ready to go too. PXL_20250608_001025984.jpg
    catdad49, shortypu, loudbang and 3 others like this.
  15. Splitbudaba
    Splitbudaba
    Here's a before and after pic of that wonky door post taper. PXL_20250608_003315120.jpg PXL_20250608_003334311.LONG_EXPOSURE-02.ORIGINAL.jpg
    catdad49, shortypu, 2deuces64 and 8 others like this.
  16. Splitbudaba
    Splitbudaba
    Got the door hung, working on latch install, handles and b pillar latch catch. Got all four tires and wheels balanced and installed. Ready for a test drive!! Really like the new cheaters! PXL_20250622_030531543.jpg PXL_20250622_030546071.MP.jpg PXL_20250622_030554223.jpg
  17. Bandit Billy
    Bandit Billy
    Those are fatties! And you know what to do with fatties...Roll 'em up and burn 'em down.
    I am biased but I like that look! I forget, did you say you were going to have a go at polishing those sidewalls? I am really looking forward to watching that.
    Splitbudaba likes this.
  18. swade41
    swade41
    from Buffalo,NY
    Tire looks good tucked to the body too
  19. Splitbudaba
    Splitbudaba
    Yes, I plan to polish them, when I am in the mood!!
  20. Splitbudaba
    Splitbudaba
    I don't like when the tires stick out either!
    swade41 likes this.
  21. Splitbudaba
    Splitbudaba
    Got the original 32 Ford door latches mounted and operating, lower upholstery tack strips fit. Next window runs and regulators. Handle out side is repro, but looks great. Looks OK for fibergl*** . PXL_20250705_145931030.jpg PXL_20250705_145950097.jpg
    catdad49, charleyw, loudbang and 5 others like this.
  22. RodStRace
    RodStRace
    Looks great!
    Can't win with a repop handle on a 'gl*** body :), the henry guys would say the OG handles should be saved for 'real' cars! Do the best you can and enjoy.
    There's a reason companies developed a business plan, invested and produced replica bodys. There was a market demand that exceeded supply. The repop parts would not be as viable if there was only Henry steel.
    The next step in that argument is that OE high point restored is the only proper way to revere the design. Gatekeeping! I think the HAMB group would be unhappy with that line in the sand.
  23. Splitbudaba
    Splitbudaba
    Reinforced latch area, gl***ed it in. Shaped it and a coat of primer. Swung the door and it latched perfectly. Some days all goes well!! PXL_20250713_031735858.jpg
  24. Splitbudaba
    Splitbudaba
    Well life brought us some grief. Tomorrow I get to put my Daisy down. She got diabetes, now she's blind and in pain. She's only 8, that's about half life in my mind.
    Dogs have a bad time with diabetes. I have remembered what it means to cry!!! PXL_20250724_003416111.jpg
  25. Bandit Billy
    Bandit Billy
    Sorry man! Tough time parting with a pal, regardless of species. No words.
  26. Splitbudaba
    Splitbudaba
    Agreed!!
    catdad49 and Bandit Billy like this.
  27. Weedburner 40
    Weedburner 40
    I feel your loss, we had to put ours down a little over a year ago, still miss him.
    catdad49 and Splitbudaba like this.
  28. Tim_with_a_T
    Tim_with_a_T
    Sorry to hear. Pets are better to us than most humans are these days. We don't deserve them. Thanks for giving your dog a good life.
  29. Splitbudaba
    Splitbudaba
    Our pleasure!!!!!
    catdad49, shortypu, Motorwrxs and 2 others like this.
  30. Splitbudaba
    Splitbudaba
    She's with God now. I closed her eyes and said farewell. Hardest damn thing I have done in 25 years. I miss her!!
