Projects Ford Victoria Door Panels
Discussion in 'Traditional Hot Rods' started by Jeff Knepper, May 20, 2025.
  1. Jeff Knepper
    Jeff Knepper
    Hi
    I’m in need of a set of door panels for a 1951 Ford Victoria.
    Any help is greatly appreciated.
    thanks
    Jeff
    (832)914-4915
  2. eaglebeak
    eaglebeak
    They would be the same as a tudor. The back seat side panels are different.
    They are the same as a convertible. The whole back sear is different from a tudor.
  3. 5window
    5window
    You might look on the appropriate board on the Antique Automobile Club website aaca.org or in Hemming's
  4. Incorrect, convert seat cushions and side panels are different to each other. The top rams p*** through the side panel and the back cushion is narrower. Victoria is Victoria only. Door panel board are very easy to make and then upholster as needed. Pretty common in the trades. I had nothing to start with and here's what I did with it. You can do it too.
    oldsmobum likes this.
