Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Wanderlust
    Wanderlust
  2. jazz1
    jazz1
    Finally finished the frame,,,thought i had enough epoxy primer…not so..misted a thin coat on for now…. IMG_3484.jpeg IMG_3199.jpeg
  3. CharlieBob
    CharlieBob
    “Working on” motivation to finish my longer, lower, wider jailbird. Need to put aside an OT project.
  4. jeepster
    jeepster
    from wisconsin
    Glued up a door panel.
  5. choptop40
    choptop40
    That look ks sweet..
  6. BigRRR
    BigRRR
    Picked up a multimeter/dwell meter last summer. Last month found a rusted up Craftsman tool box in curbside free pile. Sandblasted/painted and just installed meter tonight. Perfect size for timing light and miscellaneous tune up tools. IMG_2547.jpeg
    4 pedals, alanp561, enloe and 19 others like this.
  7. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Sharpone and porkshop like this.
  8. 1pickup
    1pickup
    @BigRRR That material is the bee's knees!
    Wasted my time on this today:
    Before (left) & after (right). It looked much better in my mind's eye, than it did to my real eyes.
    401 Nailhead piston tops & cheap filters so my flathead can breathe better than with the old bonnet style.
    It looks better on the engine. I'll get some stainless acorn nuts for the top to finish them off.
  9. Dick Stevens
    Dick Stevens
    When you get them polished they will look much better! Oh and use acorn nuts instead of plain hex nuts to retain them.
    swade41, porkshop and Sharpone like this.
  10. jeepster
    jeepster
    from wisconsin
    Need some door pull handles. Luckily I had a old die in my stash to make the pull ends. IMG_2093.jpeg IMG_2091.jpeg
  11. Paint.... sanding...... same ****, different day :D 20250519_161021.jpg
  12. scofflaw
    scofflaw
    from Ohio
    That's beautiful Lloyd!
  13. swade41
    swade41
    from Buffalo,NY
    I like it, I agree that if you polish those it'll look even better, I might go rummage my junk pile and see if I have any pistons in the correct diameter.
    mad mikey and Sharpone like this.
  14. jeepster
    jeepster
    from wisconsin
    Installing door panels
    porkshop, enloe, mad mikey and 8 others like this.
  15. choptop40
    choptop40
    PXL_20250522_150204610.jpg Steering column sourced.... undecided on it ...Gauges look like they came from factory. .Took some doing. ..
    61Cruiser, porkshop, vtwhead and 3 others like this.
  16. Off the road temporarily...
    Got a bit of spring work to be done in the front end...
    OzMerc
    porkshop, enloe, Stock Racer and 7 others like this.
  17. swade41
    swade41
    from Buffalo,NY
    I went a little backwards and went back and welded in this missing fender brace bracket that I robbed from the old fender.
    I probably should have done that before painting the fender lol, I also stripped the braces and gave them a coat of Por-15 primer and a couple coats of satin black.
    Screenshot_20250519_200733_Gallery.jpg 20250522_145848_01.jpg 20250521_170634.jpg 20250522_152945.jpg
    While waiting on paint to dry I made a new bone for the shrunken head out of the paintbrush handle.
  18. F-head
    F-head
  19. deathrowdave
    deathrowdave
    from NKy
    IMG_2813.png Just for anyone with mice they need to get rid of .
  20. HOTRODPOWELL
    HOTRODPOWELL
  21. RMcCulley
    RMcCulley
    Sharpone and 427 sleeper like this.
  22. Sandcrab
    Sandcrab
    Dave, must be that time. I found this in my metal pile inside the shop. I have had Rattlesnakes, but this turned out to be a Bullsnake. They eat the rattlers so I turned it loose.
  23. Oneball
    Oneball
    My AC has lost its gas, seems that the o ring around the plate that holds the crank seal in on the compressor has failed, pulled it off and took it to my friendly AC guy who is going to get a rebuild kit. Every now and again you’re really lucky and find someone who knows their stuff, especially on 50 year old AC systems; “had that problem before on combine harvesters” was his response.
    4 pedals, porkshop, saltflats and 8 others like this.
  24. shorrock
    shorrock
    Got the engine back into the car, had to re-adjust motor mounts and all fittings as the motor is 2" further back due to the blower beltdrive. Luckily all my guesswork was right, no big problems or tight spaces. After shortening the drive shaft I was able to test the car - lots of power! There is a bit extra noise from the beltdrive but only when the blower is working hard. When cruising there is almost nothing to hear. So far I am very happy! 20250521_101619.jpg 20250521_101630.jpg
  25. Greg Rogers
    Greg Rogers
    Eye candy!!
  26. dsiddons
    dsiddons
    from Indiana
    Doing some upholstery. Now I know why I see a lot of seats that look like deflated ***s. What a Royal pain in the *** this has been.
    porkshop, MMM1693, saltflats and 11 others like this.
  27. Onemansjunk
    Onemansjunk
    from Modesto,CA
    It’s a shame that you take nice material, wrinkle free, fresh off the roll, glue it to foam. Then have to wad it up, turn it inside out, roll it up, just to get it through the machine. It reminds me of the old Samsonite luggage commercial. The gorilla mangling the **** out of it. Just looking at it, adds some kind of blemish.
  28. dsiddons
    dsiddons
    from Indiana
    Well look at you throwing down some beautiful top s***ches! I did a beautiful door panel with 1” pleats and when I stuck it on the door, it just enough radius to put a billion little wrinkles in it. This is an art that didn’t get enough respect in my opinion.
