Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. nrgwizard
    nrgwizard
    from Minn. uSA
    Secrets of your "success-es" ? :D .
    Marcus...
  2. atch
    atch
    Storage tip:
    I have about a half dozen log chains. I imagine most of you have that many or more. I used to hang them up but that was a real h***le getting them down and hanging them up.
    Now I put each one in a 5-gallon bucket. I stack the buckets so all of the chains combined require the footprint/real estate of one bucket. As you all know each bucket has a couple of inches showing above the bucket below it. On that space I've written with Sharpie the length and link size of the chain in that bucket. Even if I want the chain in the bottom bucket it's not a problem to pick up the upper buckets (one at a time) and put them all back after they are used.
    y'sguy, jet996, vtx1800 and 16 others like this.
  3. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    While responding to a thread from @krylon32 I remembered this old remedy.
    So thought I'd hustle over to leave it here.
    When cars with plastic fuses became common, one of my delivery van Buddy's blew a fuse in his older gl*** tube equiped Ford.
    The load has to roll and lighting is key to a ticketless day.
    We deduced that taking a plastic fuse and forcing it piggyback ( w/old fuse) into the old gl*** tube panel was the Bomb
  4. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Fffnn electric cords. I finally had enough of these Fffnn electric cobwebs all over my work bench. Dugout a dried up 2x6, run over it with the power planer. Then carved out the back. D82797EB-DED7-4FD7-828D-F5069439D34D.jpeg 6C80D6BD-1A9E-44C5-8510-0D8DE081E6F1.jpeg 6CFF5466-5FDB-435A-B7BB-8B47EB5A93AA.jpeg 95A56F3C-D890-4B4A-960B-7DA0EA4A42DB.jpeg
    scotty t, enloe, pivir123 and 18 others like this.
  5. Six Ball
    Six Ball
    from Nevada
    They can also function like a coil. I hate excess cords & hoses in the shop.
    enloe, brEad and '28phonebooth like this.
  6. Thats a 2-wire cord, so current going both ways, it won't create an electromagnet or coil, but it will get hot being wound up and recessed into the wood.
  7. Six Ball
    Six Ball
    from Nevada
    Good to know. Thanks!
    enloe and Tow Truck Tom like this.
  8. Fabber McGee
    Fabber McGee
    Likely not enough load to heat much.
    Rated draw on my identical DCB107 charger is 0.5 amps.
    According to the National Electrical Code (NEC), 18 AWG copper wire has an ampacity of 7 amps. However, the overcurrent protection for 18 AWG copper conductors should not exceed 5.6 amps for continuous loads. This means the maximum allowable current a fuse or circuit breaker protecting 18 AWG wire can be is 5.6 amps.
    Some of you guys act like old women working in a Civil Service office. So sour after 20 years and so bored that you can find nothing to do but pick at each other and look for ways to feel superior and important. Personally, I think @Onemansjunk came up with a good and elegant solution to a problem that bothered him and executed it at very minimal cost. Isn't that what this forum is based on?
  9. Hollywood-East
    Hollywood-East
    Well said Sir....
    enloe, loudbang, HemiDeuce and 2 others like this.
  10. Six Ball
    Six Ball
    from Nevada
    How strange you bring that up. I just recently began to identify as an old woman working at a Civil Service office.
  11. Fabber McGee
    Fabber McGee
    Haha, I think the DMV develops some of those same personality traits over long careers, except they target the public.
  12. oldpl8s
    oldpl8s
    A word of caution, I left some linseed oil soaked rags on my workbench. The next day I smelled some thing smoldering and saw smoke coming from the rags. I threw them outside and they burst into flames. I now properly dispose of them right after using.
  13. atch
    atch
    Since oldpl8s brought up smoldering/fire I'll relate something stupid I did a while back:
    I used to cut nylon/plastic rope/string with a knife and then melt the ends to keep it from fraying. A while back I started putting the end in a vise and using a butane lighter to melt it in half. I did that recently and went about my business using the rope that I had cut off. I left the shop and went to use the rope. A while later I went back into the shop and the end I had left in the vise smoldered (I guess) and eventually caught on fire. The plastic reel it was on also caught on fire. It had burned and melted down the front leg of the bench and had charred the leg about 1/4" deep. The vise also had a coating of black that didn't come off easily.
    Fortunately the leg was 4x4 and structurally it wasn't really hurt. I s****ed the leg and used a DA to clean it up. I also dis***embled the vise, sandblasted the pieces, repainted it, re***embled it, and reinstalled it.
    It's just lucky God was watching over me when I was too stupid to watch out for myself that led me to go back into the shop before the whole thing burned down.
    Lesson learned: I may still use the same way to cut rope but I'll dip the end in the water bucket attached to the leg of the grinder stand nearby to make sure it'll never burn again.
    Just Gary, Bugguts, drdave and 11 others like this.
  14. Six Ball
    Six Ball
    from Nevada
    I went to the Carson City NV DMV to renew my license yesterday. To my amazement I was in and out in less that 30 minutes. All 3 people I talked to were friendly, polite, and helpful. I had to sit in my pickup for as few minutes to think about what had just happened. I even got out a walked back in to make sure I had gone to the right place. When I got up this morning I rechecked all the paper work and evidently it really happened. :eek:
  15. Fabber McGee
    Fabber McGee
    I saw an ad on TV last week for a new comedy coming out next fall about a DMV office, so it must be painful to go in those places everywhere.
  16. Six Ball
    Six Ball
    from Nevada
    What was the animated movie where sloths ran the DMV? Zootopia? Funny as hell!
  17. j hansen
    j hansen
  18. RodStRace
    RodStRace
    When I first moved here to the Prescott area and went to the MVD, I was pleasantly surprised. Short line, knowledgeable staff.
    This has degraded over time. The staff are still helpful, there are just as many, but the slaughterhouse treatment of patrons has been ramped up. An online kiosk at the front (if I could do it online, I wouldn't have driven here), followed by a self check-in which asks questions and spits out a number to stand in a twisting line that herds you toward the front slowly. The last one, the clerk took my paperwork and disappeared for 10 minutes. When she returned, she explained it was to train another person in how to spot fakes. So no explanation to start, a long wait, then an alarming twist. After that, she then said everything was okay. I was not happy, but sure didn't want to press the matter.
    They also collect and sell your data without ANY Terms Of Service. warning or disclaimer.
    Note the ***le, then what is in the article
    https://azmirror.com/briefs/arizona-mvd-doesnt-sell-records-to-third-parties/
    In Arizona, a little more than 762,000 requests for driver license records were made to the motor vehicle division from Sept. 10, 2018, to Sept. 10, 2019, according to Arizona Department of Transportation spokesman Doug Nick. The requests brought in more than $2.3 million for the agency.
    Sharpone, alanp561 and Six Ball like this.
  19. Six Ball
    Six Ball
    from Nevada
    Thanks!
  20. Adriatic Machine
    Adriatic Machine
    Here’s a tip for to increase the longevity and function of those generic casters from all the big box stores (aside from lubricating the axles).
    Squirt some grease in the swivel bearings and wrap it with an o-ring.
    It may not swivel as easily at first but it won’t fill up with dust, preserving the action for miles of smiles.
  21. Dave G in Gansevoort
    from Upstate NY
    Hand smack to forehead, “why didn’t I think of that!” Moment…
  22. mohr hp
    mohr hp
    from Georgia
    IMG_4886.png IMG_4887.png IMG_4888.png IMG_4889.png Been waiting awhile to do this one until I got some pics to explain; Here's what I came up with to create a hose barb on a metal line for the cooler lines on a T400. I use a br*** compression fitting ferrule. Just the ferrule. I crank the fitting down, take it apart and carefully cut off the nut. Voila! just be sure to give it a test tug to ensure it will stay put. Works for me, and costs a lot less than a tool to bead the tube. I've used them lots of places.
  23. alanp561
    alanp561
    Very cool, Steve. :cool:
    Six Ball and Sharpone like this.
  24. Adriatic Machine
    Adriatic Machine
    Since I’ve been so busy procrastinating on making a 5/16” bead tool, maybe I’ll do it this way instead.
    Six Ball, alanp561 and Sharpone like this.
  25. oldiron 440
    oldiron 440
    When I had my shop it was inspected by the fire department about every three years but one time the chief was in getting his wife’s car repaired and noticed that the wall clock in my office had its cord still wound up he made me unwind it on the spot and said he’d seen an actual house fire start that way. About a week later I was inspected again and of course the clock in the shop, bench grinder and something else had to be taken care of. They didn’t like how I had the power cord permanently attached to the welder and d****d around the tank until I showed them how I had to remove it to use it anywhere in the shop. I never understood how low draw clock would be a problem but they said they would rather see the cord cut off and a new plug installed on it.
    I don’t know
    y'sguy, Six Ball and alanp561 like this.
  26. patsurf
    patsurf
    dis he actually have the address of the burned house....?
    Fabber McGee likes this.
  27. arse_sidewards
    arse_sidewards
    from Central MA
    Nobody who asks tough questions like that lasts long employed by the government.
  28. patsurf
    patsurf
    :):D
  29. Onemansjunk
    Onemansjunk
    from Modesto,CA
    E2B1C6AB-8462-450D-9B30-18209759CBA2.jpeg 31EC36C9-147D-4325-B0CE-42303138B20E.jpeg 998A0DAB-250A-47FE-B046-32062A238A55.png 41190EFB-FB6E-4491-A9A2-989B225AFD5D.jpeg
