Projects 1922 Dodge Bros Roadster (almost none of this is true)
Discussion in 'Traditional Hot Rods' started by fatassbuick, May 21, 2025.
  1. fatassbuick
    fatassbuick
    from Kentucky
    I picked up this heap off FB Marketplace in trade thinking I would slap it together, rust and all, and let er rip. Unfortunately, the body was pretty floppy, and finally broke when I was shuffling it around my already overcrowded shop.
    It was listed as a 1917 Dodge Bros Roadster, which I think only the Dodge Bros is correct. Ah well, it doesn't really matter, at this point.
    Screenshot_20241016_091846_Facebook.jpg Screenshot_20241018_202840_Facebook(1).jpg Screenshot_20241018_202835_Facebook(1).jpg
  2. fatassbuick
    fatassbuick
    from Kentucky
  3. fatassbuick
    fatassbuick
    from Kentucky
    I decided I wasn't going to run the speedway frame. Actually, I decided I was using nothing that came with the "car" except the body. Most of it. Well, some of it.
    I picked up a rough A frame and started making it fit. I'm thinking of running a T turtledeck, so I pinched the frame to fit better.
    I wanted to run a T rear crossmember and spring:
    I took all the X bracing I was trying to use to square it up and started on a different path. These were the body parts without the strap holding it together.
  4. fatassbuick
    fatassbuick
    from Kentucky
    Moving ahead, I was able to find an unfrozen flathead. I'd love to have found a matching 4 banger Dodge Bros drivetrain, frame and even a body, but then that would be a different project altogether. It side tracked me a bit to build a scrappy engine check stand, so I did my usual 50% and went back to working on the body.
    Got to bracing the floor a little better:
    Then started doing some Harbor Freight metal work:
    20250517_205921.jpg 20250517_205945.jpg 20250518_205114.jpg 20250519_154147.jpg 20250519_174805.jpg 20250520_172113.jpg
    Thats where I got last night. I've been wanting to do a build post, but I procrastinated because I wasn't sure if I was gonna work on this, with all the other***** I think I can work on.
    Uncle Ronn, ratster, flyin-t and 23 others like this.
  5. dwollam
    dwollam
    Your Dodge body is a '20-'22 Touring car front half.
    Dave
  6. 51 mercules
    51 mercules
    Cool project Here's my friends car mostly Dodge. 1924 or 25 Dodge Touring front half, he was going to use a 22 to 25 Ford turtle deck, he couldn't get the proportions right. Ended up using some 28 or 29 Ford Model A Quarters and deck lid. Sits on a shortened Dodge Frame with a quick change and has a Dodge Flathead Engine. image000000(1)~2.jpg image000001~2.jpg
    deadbeat, Uncle Ronn, jet996 and 36 others like this.
  7. patsurf
    patsurf
    i think you and anthony on here are real "do-er's"--congrats!
  8. fatassbuick
    fatassbuick
    from Kentucky
    Thanks, Dave. It's got a number on the firewall I want to research eventually.
    Wow, that's awesome!
    Hahaha...let's talk to my wife about that. Actually, these pics span over about 9 months, but thanks!
  9. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    I like your tastes.
    Thanks for the views.
    chryslerfan55 and fatassbuick like this.
  10. AccurateMike
    AccurateMike
  11. fatassbuick
    fatassbuick
    from Kentucky
  12. dwollam
    dwollam
    @fatassbuick the number on the firewall is just a body number. Nothing to do with year or serial number. Dodge Brothers stamped the serial number on the frame crossmember right in front of the passengers heels on '22 and earlier and on the right front frame rail by the shackle on '23-'27.
    Dave
  13. dwollam
    dwollam
    @51 mercules that is a slick conversion! I have a '25 DB roadster, fenderless, with 318. I have a bunch of early DB's.
    Dave
  14. fatassbuick
    fatassbuick
    from Kentucky
    Good to know! Ah well, I'm glad I picked up the toe board from Corn Fed.
    chryslerfan55 and dwollam like this.
  15. dwollam
    dwollam
    Serial number was also on a metal plate on the toe board!
    Dave
  16. 51 mercules
    51 mercules
    Turned out really nice. Originally my buddy wanted a turtle deck. I found him a couple of 1922-25 turtledecks to modify to fit the frame and fit the width of the cab.Just didn't look right, then my buddy Shug who was putting the car together for JJ suggested Model A quarters. We thought he was crazy. My other buddy had some Model A quarters and Shug tacked the buddy together and actually worked to our surprise.
  17. fatassbuick
    fatassbuick
    from Kentucky
    Yes sir, it is
  18. Outback
    Outback
    from NE Vic
    Looking forward to seeing how this comes along
    chryslerfan55 and 51 mercules like this.
  19. noboD
    noboD
    As Dave said the number on the firewall is just a body number. If it were stamped with T 123 it would be the 123rd Touring car that year. If R123 it would be the 123rd Roadster. Cool project.
  20. I have a 1925 touring and there is the number on vertical outside face of the passenger side frame rail, near the rear hanger for front spring, on the top of the frame rail in the same area but under the fender, also the toe board tag and engine block. My engine block not original matching. Dad purchased the car in 1964 out of the contested estate of Joan Davis,died 1961, vaudevillian, movie and film actress. The California DMV in Palm Springs had the****le all messed up because they could not find any database in DMV records for 1920's Dodges. Pinning down production numbers to dates then was near impossible. Joan Davis had been driving it on California Dealer plates ! ! Took almost 2 years to get the paperwork fixed. Now clubs have all that pinned down.
  21. oliver westlund
    oliver westlund
    Heres mine, 25 dodge cowl to b pillars. 27 chev roadster quarters 20250513_134801.jpg
    dwollam, burl, Squablow and 5 others like this.
  22. NoSurf
    NoSurf
    Looks great so far.
    Thanks for sharing.
    fatassbuick and oliver westlund like this.
  23. noboD
    noboD
    C & M, the club now has records that sets an early car by month and sometimes week. The later cars like my '29 DB almost to the day. There's also records for those later cars that would tell color by the day or week it was built. For example, all sedans were painted one color for a specific number of days or weeks, then switched to another color. Same with all the other body styles. That's if that floats your boat and need that info. My '29 was painted black with red wire wheels and pinstripes for 4 days in that run. Doesn't make a difference for a hotrod but the info is available.
  24. dwollam
    dwollam
    BTW, DB engine numbers are never the same as the serial number. They were usually about 50,000 higher give or take than the serial number.
    Dave
  25. That roadster combo parts look really smooth, like a factory built car. Mixing loose parts like this is really satisfying. When I was a young kid, I tried putting a 28 Sports Coup body on a 37 hump back chassis. Now that did NOT work !
  26. Mine really does not match, its out of a 1926 sedan. Back about 1959 they pulled parts from a local sedan for swap outs long before Dad ever saw it. All of that stuff was original to the Indio and Palm Springs area from the 1920's and 30's. We later found a Fast Four with transmission from a date grove junk pile.
  27. 51 mercules
    51 mercules
    Nice!
  28. fatassbuick
    fatassbuick
    from Kentucky
    Thanks everyone!
    After I got all my fancy parts tacked in, the door was out of wack pretty bad. It stuck out abouy a half inch on the bottom, and took both hands, a shoulder and a knee to force it to barely latch. I messed around with it for a few hours and finally got it pretty decent; closes fairly easy, gaps are acceptable (to my sorry eyes) and doesn't grind while swinging open. My next option was to cut it all out and start over.
    20250524_182348.jpg 20250524_182358.jpg 20250524_182413.jpg 20250525_154814.jpg 20250525_190043.jpg
    I had a week off, and was hoping to get something done on it, however I ended up doing practically everything BUT working on it. Ah well..it waited 100+ years for someone to violate it, a few days won't matter much.
  29. dwollam
    dwollam
    That's as good or better than factory fit!
    Dave
    oliver westlund and fatassbuick like this.
  30. noboD
    noboD
    Dave, I was thinking that but didn't say it. I think as long as the door stays closed when you hit a bump it's perfect. I sell the rubber door bumpers if you want them.
