Customs My answer to the Lake Pipe muffler question!
Discussion in 'The Hokey Ass Message Board' started by 29StudeDude, May 21, 2025.
  1. 29StudeDude
    29StudeDude
    I found these motorcycle baffles on Ebay. They can be ordered in different diameters to fit inside Lake Pipes. They even come with an installed collar, that we tack welded in, and slides flush into the pipe. They come closed on the ends, so I drilled them out for more flow. You can talk normally next to the '53 Buick with a SBC at idle, and it sounds like a full exhaust with gl*** packs KIMG0213.JPG KIMG0214.JPG PXL_20250518_001551609.jpg PXL_20250518_001605765.jpg PXL_20250518_001638934.jpg at full roar.
    Stock Racer, X-cpe, Stogy and 11 others like this.
  2. Blues4U
    Blues4U
    from So Cal
    Did you wrap the baffles in fibergl*** or pack steel wool around them before inserting them into the pipes?
    Stogy and Tow Truck Tom like this.
  3. 29StudeDude
    29StudeDude
    No. They just float inside the pipe.
  4. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Nifty, Be-Bop Baby.
    Stogy and 29StudeDude like this.
  5. Blues4U
    Blues4U
    from So Cal
    So they don't really reduce volume. I would try wrapping them or packing them to absorb higher frequencies, tone down the exhaust note. Some steel wool would probably be the easiest to find, but condensation in the exhaust will cause it to rust and then it will eventually blow out. Some fibergl*** packing would be great. Or go traditional and get some metal shavings from a machine shop and pack that in there. The way those baffles work is the holes allow sound waves to exit out of the exhaust stream, high frequencies travel faster than lower frequencies, so they will exit through the holes, and if you add some packing it will trap those frequencies and lower the exhaust volume and mellow out the tone. Try it.
    Stogy and Truckdoctor Andy like this.
  6. alchemy
    alchemy
    Don’t most lake pipes have a curve on the front and rear end? Hard to slide in right?
  7. 29StudeDude
    29StudeDude
    If I was allowed to post a video you would hear it is muffled just enough. No packing. It's not an open exhaust sound at all. I hate to tell you you're wrong, but you are. Lol.
    Stogy likes this.
  8. 29StudeDude
    29StudeDude
    Speedway makes these, and they have a straight section on the engine end. Plenty of room for these to slide in. I used a manual pipe expander inside, until it just slid in flush using the collar.
  9. Tim
    Tim
    from KCMO
    You just post it on YouTube and copy and paste the link here
    Stogy likes this.
  10. 29StudeDude
    29StudeDude
    I posted it on a few traditional groups on Facebook.
    Stogy likes this.
  11. 36 Tourer
    36 Tourer
    If you need material inside to baffle, I have used stainless steel scouring pads you can buy it in bulk at the hardware shop and it last for years
    Stogy, Speccie, X-cpe and 1 other person like this.
  12. jnaki
    jnaki
    Hello,
    Nice find and addition to your Buick Sedan. If it is a daily driver, watch out for the “idle aroma” to come into your sedan. It can be obnoxious and “silently deadly.” In So Cal, exhaust ahead of the rear wheel is not legal. Nice looking, but not legal. We tried back in our teenage days with lakes pipes open under a lowered 51 Oldsmobile sedan.
    The chromed lakes pipes lasted several weeks and then sold to a sedan owner whose car was not lowered. At the time, we all had legal extended muffler system in place, but a “Y” section in the welded, attached, exhaust lakes pipes allowed us to cap and uncap the ends.
    First, it looked cool, but the low rake stance was not friendly to the low pipes. Second, when we opened the caps, even with closed windows in the sedan allowed fumes to come inside and it was awful. So, be leery of constant fumes. Despite the cool sounds coming from the pipes.
    One of the first to install motorcycle baffles inside of straight pipes was added to these smooth flow headers. Similar in looks to the old Scotty’s Muffler Service Modified Roadster. But, these were for the smooth sounding T-Bucket of Fred Castro from the Prowlers Car Club of San Diego.
    I did a photo story of this cool looking design and the pipes were “baffling,” (pun intended) as to why straight pipes sounded so quiet. Standing next to the running motor, one would have thought real mufflers were in place on all 8 individual pipes. Not so…
    Going for a ride in the open t-bucket roadster was exhilarating to say the least. We were so low to the ground, I could almost reach out and touch the ground that was whizzing by quietly. We could actually have a normal voice conversation during our ride.
    Jnaki
    It was fun to photograph the cool, well built roadster for a photo story. Riding around in it taught me how creative hot rod folks could be with their builds.
    upload_2025-5-24_3-16-27.png Thanks, Fred…
    Note:
    At the time, our Harley Sportster was changed over from the stock muffler system to an individual exhaust pipe set with mufflers. They were rated 88 decibels. It was loud and sounded nice on acceleration and just sitting at a stop light. But, after a long 50 mile ride, it took some time to readjust to clarity in our hearing… not just “what did you say?” kind of conversation. YRMV
    Stogy, 29StudeDude and F-ONE like this.
  13. custom_lettering
    custom_lettering
    from Wall, NJ
    I just ordered dirt bike silencer fibergl*** to wrap mine with. I need to kill the high tones of the lakester pipes on my AV8 roadster. I must be getting old.
    Stogy likes this.
  14. Mr48chev
    Back 60 years ago I had a little 4 cylinder car that I put a 4 ft scavenger pipe on as a straight pipe and rolled up a square of hardware cloth and slid it into the pipe and drilled holes for a bolt to hold it in. That was a fairly effective low buck muffler at the time.
    Stogy, 29StudeDude and williebill like this.
  15. 29StudeDude
    29StudeDude
    I'm 55 but still love loud pipes. Is that why I keep saying, "What?!" all the time?
  16. Stogy
    Stogy
    https://www.carchemistry.com/3-disk-insert-2-3-4-diameter/
    I put these in my pipes about 6" behind my mufflers...like those you used there are numerous ways to install them wrapping, packing using different combinations of rings and caps...very tunable really...I opted for no wrap/packing and they still brought the decibels down to 90 from 110 which was pretty dramatic but its still loud and pushes 100 at speed with some of it due to wind whistling through the unsealed seams of my rolling brick...yours being a much later Custom is no doubt sealed and deadened but I get wanting the rumble as it's part of the ambience...
  17. Stogy
    Stogy
    I always get confused with Lakes Pipes and what I have is I believe called Lakes Headers...completely different but I guess pipes and headers is the separation of the two realities...I wonder if Lakes was a company that produced both...
  18. RodStRace
    RodStRace
    @jnaki Do you remember more about the baffle he used in the T pipes?
    I've seen them for 6 bucks to 60 bucks and hate to spend much on them (times 8) and find out they don't work or block too much.
    Stogy likes this.
  19. Rand Man
    Rand Man
    Can you post a pic of the end, looking through them? I tried this and it was way too restrictive. The ones I bought reduced the inside diameter too much. The engine would lay down at full throttle. I can’t have that ****. I used stainless steel wool , made for muffler packing. Worked best for me.
    Stogy likes this.
  20. Stogy
    Stogy
    I'll never forget this old timer Hotrodder that I met at a cruise in Guelph Ontario running header into pipe somewhat similar but shorter to what RodstRace just shared and I saw him coming in and wondered how he got them so quiet...he said he used old baffles and wrapped them in asbestos and put them in the pipes...:eek:...needless to say Hotrodding may be hazardous to your health...heck maybe it was a lot more common than one would imagine...
  21. jnaki
    jnaki
    Hello,
    The history of this roadster was that the owner loved driving it. I could see why first hand when I rode in it for a ride in San Diego. It was a combination of the wind in the hair type driving around and the low rumble of the motor while we were zipping past the traffic.
    When we got back to the gathering, I had to ask how it was so quiet. And the answer were those baffles. There are a lot of baffles on the market and he found some that fit the size of his pipes. Restrictions, yes, anytime a baffle is used in a straight pipe the flow is altered.
    Jnaki
    I cannot remember the name of the baffle or where he got it, but in our own desert motorcycle racing days, there were guys that took out a skinny baffle out of a stinger muffler and that made the flow better. In the case of the V8 motor and straight pipes, it sure did not feel like there were any restrictions as we went down the road. The power was there. But, it was also a very lightweight roadster, too.
    For the So Cal old guys, this roadster and the pipes were always on the highway from San Diego to the greater Los Angeles/Orange County area for the hot rod gatherings. It was meant to drive, not just for show, although the quality of the build, one would think it was an immaculate, spotless, “garage queen” and “show bunny…” YRMV
    Stogy likes this.
  22. I installed 2 harley drag pipe baffles per side, in the pipes on my 51'. I cut the pipe right after it curves, welded it back together and used ignition coil chrome cover sleeves to hide the seam. Not real noticeable. If you look at the one pic you can kind of see it. I like the sound, not real loud, and I have a cam in the motor
    williebill, Stogy and 29StudeDude like this.
  23. Tim
    Tim
    from KCMO
    Stogy I’ve always ***umed the lakes referenced the dry lakes.
    if you look at one of the books covering early salt activity like “the birth of hot rodding” a lot of them ran 4 bangers with long chrome pipes down the side.
    I can imagine looking at these sorts of headers that the “lakes headers” and “lake pipes” both were born from that general look and idea.
    Stogy likes this.
  24. Man, those must kill power!
  25. Rand Man
    Rand Man
    They will if there’s only a three-quarter inch hole to the center.
  26. 29StudeDude
    29StudeDude
    The car actually GAINED power over the previous under car dual exhaust setup.
  27. BJR
    BJR
    ANSWER TO THE LAKE PIPE MUFFLER QUESTION
    I didn't know there was a lake pipe muffler question. Learn something every day.
    banjorear likes this.
  28. 29StudeDude
    29StudeDude
    As you can see by the responses, since they were invented, people have asked how to muffle them and came up with their own solutions. You need to get out more I guess and stop watching re-runs! Lol.
    BJR and patsurf like this.
  29. custom_lettering
    custom_lettering
    from Wall, NJ
    I just posted a thread with a comparison using baffles and then baffles with fibergl*** wrap in lakester style headers.
    29StudeDude and RodStRace like this.
  30. RodStRace
    RodStRace
