Hot Rods Chrome removal
Discussion in 'The Hokey Ass Message Board' started by Chris Haynes, May 22, 2025.
  1. 20250523_151434.jpg Today I bought a shiny new part for my funky old Deuce. It stands out like a sore thumb. I tried soaking it in muriatic acid. I think that actually made it brighter. Other than paying a chrome shop a fortune is their a home way to remove chrome?
    It is the front hood hinge holder.
  2. Bandit Billy
    Bandit Billy
    An Exorchromism? Perhaps a young priest and old priest? Gives me chills thinking about it.
    You try hydrochloric acid?
    GordonC and Fortunateson like this.
  3. ClarkH
    ClarkH
    Depending on what the part is, maybe you could trade with somebody who has a funky one and wants to upgrade to shiny.
  4. deathrowdave
    deathrowdave
    from NKy
    Grinding and breathing the dust , is not the greatest health idea .This is my story and Im stickin to it
    5window and Budget36 like this.
  5. gimpyshotrods
    gimpyshotrods
    Um, Hydrochloric acid, also known as muriatic acid or spirits of salt, is an aqueous solution of hydrogen chloride (HCl).
  6. TCTND
    TCTND
    Bury it in a damp spot for a month or two.
  7. Rodney Dangercar
    Rodney Dangercar
    Plating shops do it in an electrolytic bath. The shop I worked in used a basic solution and reverse current to strip it and it just takes a moment. Once stripped the part was subjected to 'forward current' during the cleaning process so it could be plated again. Stripping it this way produces a toxic waste (hexavalent chromium), thus the extra charge to strip it.
    If you want to keep the underlying nickel I would send it out to a plating shop and pay to get it done right.
    Mr48chev and Jalopy Joker like this.
  8. redo32
    redo32
    What is the part? gimpy beat me. Muriatic is usually diluted HCl. If the muriatic was strong enough to dissolve the chrome, there is still shiny nickel under there. Sandblast and powder coat or epoxy and paint. If you insist on stripping the nickel : empty the sulphuric acid from the stash of batteries in the corner in a plastic bucket and use a reverse current from a battery charger.
  9. hotrodjack33
    hotrodjack33
    Use some 220 then 400 sandpaper and give it a less shiny, brushed aluminum look
  10. Rodney Dangercar
    Rodney Dangercar
    We soaked rusty chrome parts in HCl, rinsed them and dropped them in the chrome stripping tank prior to starting the cleaning and restoration process. The chrome was still on the part after the HCl soak. That and HCl attacks good metal at a 4 to 1 ratio when stripping rust off of it (IOW, keep it short).
    Soaking it long enough in acid might work but if any steel is exposed then you will lose good metal while doing it.
  11. redo32
    redo32
    @Rodney Dangercar I have stripped chrome in HCl since starting in a bumper rechrome shop in 1970. In the winter a cold weak solution will not eat the chrome. A heater or a fresh bucket of acid kicks it up. Reverse in a caustic (base) solution will p***ivate the nickel and can cause problems in a shop that is not big enough for a proper activation tank. Some shops will strip chrome and nickel in a sulphuric reverse tank. If the solution is not operated under optimum conditions it will eat the steel part dangerously. There are proprietary chemicals that will remove nickel and not affect the base metal.
    Any acid soak, plating or reverse current will lead to hydrogen embrittlement.
    Jalopy Joker and rod1 like this.
  12. '29 Gizmo
    '29 Gizmo
    from UK
    Google electrolytic Chrome removal for the right processes. Can be done at home.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    re sell it and buy a ****ty old part if that is what you really want... what part is it?????
    lostone, rockable, 1Shot-Scot and 3 others like this.
  14. guthriesmith
    guthriesmith
    Yea, trading it for a “not so nice” part seems like the best bet. Why ruin a good part?
    lostone, 51 mercules and Moriarity like this.
  15. Mike Lawless
    Mike Lawless
    The Muriatic acid will only strip the chrome, which isn't very thick. Probably a few micro millimeters and the chrome is only there to keep the bright nickel from tarnishing. You probably are already through the chrome layer since you went after it with the acid. The nickel, which is the "bright" part, will not be stripped.
    So you either go after that with a sander, or take it to a chrome shop and have the remaining nickel stripped.
  16. Jalopy Joker
    Jalopy Joker
    as requested above, what is the part? sometimes tough to be Cool.
  17. Squablow
    Squablow
    Maybe a buff on a stand buffer with some heavy cutting rouge?
  18. HOTRODPRIMER
    HOTRODPRIMER
    Why not spray a bonding primer like XIM and paint it your favorite color, that would be much cheaper than having the chrome stripped. HRP
    57Fury440 likes this.
  19. Rodney Dangercar
    Rodney Dangercar
    While what you said is true, a cold solution pickling slows all reactions. Not just the most reactive metals. Leave chrome in an HCl solution and eventually it will strip the chrome. But you will lose good metal if any reactive metals are exposed. While my experience was in the late 80's to early 90's, I was hired to manage the plating systems of a high end shop and jumped into doing everything because it was all new to me. I only left because it eventually sunk in while talking to older electroplaters that it's a killer occupation.
    No need to explain reactions, solutions, ionic equations, reduction reactions or endo/exothermic reactions or any of that to me though. I was cleaning up the shop the other day, consolidating storage containers and I tripped across these old things...
    Been to the rodeo, rode the bull and got the paperwork that goes with it. With that I will politely bow out of the conversation.
    leon bee likes this.
  20. Moriarity
    Moriarity
    SUPER MODERATOR
    have we heard yet what the part in question is?? maybe someone here has a ****py worn one that they would trade for a nice one....
    lostone likes this.
  21. warhorseracing
    warhorseracing
    from cameron wv
    rough it up with a Scotch Brite pad. Self-etching primer and your own flavor of paint.
  22. sidevalve8ba
    sidevalve8ba
    Sand blasting...........
  23. 51504bat
    51504bat
    Leave it outside and let the dog piss on it.:cool:
  24. stuart in mn
    stuart in mn
    Instead of messing up a good shiny part, this could be inspiration to spiff up the rest of the car instead.
    clem, Budget36 and Moriarity like this.
  25. stuart in mn, I don't think it needs any spiffing up. It is original paint.
    ct1932ford, swade41, clem and 2 others like this.
  26. clem
    clem
    Rear ………..
    front……..
    The part in question is a reproduction front hood bracket that bolts to the grill surround.
    The centre stainless strip slides into it, and there is a similar wider one on the rear above the firewall that bolts to the firewall and body
  27. Deuce Lover
    Deuce Lover
    Here on EBAY #388157044012
    RICH B likes this.
  28. clem
    clem
    have you tried it to see if the stainless centre piece fits on.
    I have the same one and it didn’t fit the original piece, hence a different one pictured above.
    I have original ones but wish to hold on to them at this time.
  29. Bandit Billy
    Bandit Billy
    Little piece like that, I'd toss it in the blast cabinet, hit it with the torch for a second and rattle can it with Krylon semi flat black. Done.
  30. swade41
    swade41
    from Buffalo,NY
    I would wire wheel it, then take an old house painting brush and lightly spray some dark brown paint on the end of the bristles, then dab it onto the part to simulate some rust.
